Question about HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop
Not able to take print on both side in hp 9000 normal series
I am trying to print on back to back i set the option print on both side,
i re-installed the novell clinet and printer drivers printer is HP 9000Normal.
but it is comming in two different pages.
Thanks in advance
Help me out
Divya.N.
  • 52 Answers
You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it.
Read below:
Shown at left:
HP LaserJet 9000 series, base unit—
LaserJet 9000
base unit =
• 50 ppm print speed
• first page out in less than 8 seconds
• built-in RIP-once technology
• 300,000 pages-per-month duty cycle
• 64 MB memory
• EIO expansion slots
LaserJet 9000n = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
• 100-sheet multipurpose tray
LaserJet 9000dn = base unit +
LaserJet 9000hns = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TXnot able to take print on both side in hp 9000 nor - lj9000hns.jpg
• 2000-sheet input tray
• 3000-sheet stapler/stacker
Posted on Dec 16, 2008
How do I stop my HP ENVY 4500 from printing on two sides?
in Control Panel, look for devices and printers. You should find your printer under there. Right click on the icon and go to printer properties.. you'll find some settings for double sided printing in there.. you may have to click on an advanced button to find the exact setting.
Sep 21, 2014 | HP Envy dv7-7230us 1.9GA-Series Quad-Core...
Hi there! Printer: HP Laserjet 4100 Problem: does not want to make both side printing. Used settings: Printer Properties->Finishing->Print on Both Sides (click) Thanks for your...
To automatically duplex, you need the optional duplexing mechanism.
If you don't have this, your only option is to print the odd pages first, put the papers back in the tray, then print the even pages.
When you put the pages back into the paper tray, make sure they are print side up.
Try with a 5 or 6 page document first to be sure you get the orientation right.
If you HAVE the optional duplexing unit (which sticks out the front just above the main paper tray) then post a reply here and I'll try to help you further.
99% of the people that own this unit do NOT have the optional duplexer!
Mar 12, 2011 | HP LaserJet 4100 Printer
Using a C3100 series HP inkjet printer, I'm trying to print HP Iron-on Transfer Paper but when I select that option, I cannot get the appropriate reverse image need for ironing on the transfer. What's...
The steps vary by printer. I've got a c7280 installed and the options for me are to click Print > Preferences > Advanced > Mirror image. When you click on Mirror image, you change it from 'off' to 'on'. Click OK to save the setting and print. Be sure to change it back after you're done printing your transfers.
I am an HP employee. I do not represent HP on this site.
Sep 14, 2010 | HP Photosmart C3180 All-In-One InkJet...
HP LaserJet 1500... prints color yellow ONLY
It's possible that the toner in the cartridge is not evenly distributed. You can redistribute toner if you gently shake the cartridge from side to side, then reinstall it to see if this affects performance. Please also see this article.
You might wish to use the guided troubleshooting option available from HP support here. Or have a look at the troubleshooting section in the user manual here. Then clean the engine & calibrate the printer, as described pg. 88.
If that's no help, please see this forum post and the linked attachments within.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 01, 2009 | HP LaserJet 1500L Color Printer
Duplex printing in HP 2420dn
I had the same problem. It was due to incorrect properties in the printer settings.
  1. Go to Start >> Printers and Faxes
  2. Right-click on the HP 2420 printer and select Properties.
  3. Go to the Device Settings tab.
  4. Under Installable Options, set Duplex Unit to Installed.
Also, make sure that the Printing Preferences are set to Two Sided Printing:
  2. Right-click on the HP 2420 printer and select Printing Preferences.
  3. Go to the Printing Shortcuts tab.
  4. Select the Two Sided (Duplex) Printing option.
That should do the trick.
HP - please change your setup so that this is set by default!!
Brian Z
Mar 10, 2009 | HP LaserJet 2420 Printer
How do i get an hp laserjet 4550n duplex to work ?
duplex printing in your model is optional im afraid
for the ff model pls see:
HP 4550 / 45500N: Optional
HP 4550DN / 4550HDN: Yes
unless otherwise that you have the duplexer installed and the selection from your properties selected like what you said, then there is no reason why this would not print back to back
keep inspecting your unit pls
cheers
Aug 28, 2008 | HP Office Equipment & Supplies
Double side printing issue with HP 2420
Try to default on your page setup.
May 23, 2008 | HP LaserJet 2420 Printer
HP laserjet 5000 series PCL 6 driver
have you tried from the print command dialog box from pc
Apr 28, 2008 | HP LaserJet 5000dn Printer
Print Odd or even pages only
There is no option in the printer to chose eve or odd pages bout if you print under windows environment you can do that from the able cation example if you use Microsoft world go to file chose printer then chose eve or odd from print comp box
Mar 12, 2008 | HP LaserJet 4050tn Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop Logo
452 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
