Water doesn't stop
The hot water keeps running into the washer. The water keeps running into the washer even when the washer is powered off. Please help.
  • intrprtr4u Oct 25, 2008
    Thank you for your help. It was very useful.
  • 958 Answers
You have a defective hot water inlet solenoid valve. you have to replace that part.
tnx 4 using fixya,
drcool
Posted on Oct 25, 2008
  • francis rivero Oct 25, 2008
    tnx 4 the rating
    drcool
Washer model wf5443tp nano. water continously running into machine even when programme finished
This is symptomatic of a malfunctioning (not closing completely) water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Take all power off the washer then turn one or the other off and see which one is causing the problem. Sorry but it needs replacing. If it only happens when there is power supplied to the washer, a service call is required to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 06, 2011 | LG Washing Machines
Cold water constantly runs even when the knob is pushed in to turn washer off.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing. The cold side can fail independently of the hot side.
Oct 14, 2009 | Frigidaire FWS833A Top Load Washer
Hot water running into washer continuously.
Yes there is it is the water valve the part that your hot and cold water hook up to.You will need to replace that part Hope i helped:)
May 11, 2009 | Washing Machines
Hot water runs even with the power off
strange...however, I think there is something stuck in the valve keeping it open.  If you can't fix it replace the valve assembly.
Mar 30, 2009 | Roper RAX4233PQ Top Load Washer
Water doesnt stop
defective inlet vavle or ( FILL VAVLE ) replace..onthejob
Feb 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
E70 error code repeatedly comes up when attempting to start a load and you have to cancel and restart 4-6 times before the load washes; again at the end of a load it will come up with the E70 error and to...
Means you are not getting cold water into unit..Either cold water hose is connected to the wrong hose or cold water faucet is not turned on..You can solve this by connecting hose to cold water faucet and cold water inlet on washer..
Nov 06, 2007 | Frigidaire GLTF2940ES Front Load Washer
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Feb 19, 2007 | Maytag Performa PAV2200
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
