I have an onkyo reciever HT-S580,that I want to connect up to my TV & my Bell reciever to get my surround sound system working.Where do I get a visual
A visual wire up plan showing how to connect my onkyo reciever with my TV & bell reciever
  • 356 Answers
You can download the owner's manual for your Onkyo a this link:
http://www.intl.onkyo.com/downloads/manuals/pdf/ht-s580_manual_e.pdf
It has drawings on how to connect just about what ever you want.
Good Luck
Posted on Feb 17, 2012
  • 319 Answers
SOURCE: Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Posted on May 07, 2008
SOURCE: Best Way ti connect a Denon AVR-1602 Surround Sound system with a Bell Express View Satlite reciever and Plasma TV
Is the sub woolfer out powered? My sub woolfer is not
Posted on Jun 25, 2008
  • 239 Answers
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Posted on Mar 06, 2009
  • 153 Answers
SOURCE: Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Posted on Apr 21, 2009
  • 5 Answers
SOURCE: What is the remote code for my TR-Sx507 AV
Try one of these: 4034, 4039, 4043 or 4084.
Posted on Sep 07, 2009
Onkyo HT-R693 (HT-S7700) receiver will play video but no audio on Netflix and YouTube. However, sound comes through when connected to Comcast cable and even Pandora. I have tried the different channels...
  • Check your cable connections
  • set the input selector to the proper component sources your using.
  • set your speaker settings to either 5.1 or 7.1, according to your speaker configuration via Onkyo's AccuEQ automatic setup tool- because the same binding posts can be used for hooking up the Atmos height or surround back speakers; you'll need to tell the Onkyo system which setup you're using.
Mar 08, 2015 | Onkyo Audio Players & Recorders
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
When i connect my onkyo ht-5300 system to my 60"sharp aquos tv with hdmi cables i get no video or sound
You need press the input button on your TV's remote.Then you need to select the input setting for HDMI.On mine,there is also an HDMI 2 input so depending on how your's is wired,it could be either one but that should get you what you want to achieve.Good luck,Greg
May 02, 2011 | Onkyo HT-S580 System
How do I connect my TV to play through the surround sound?
What kind of tv?
I HOOK cable to MY DVD-R which has a Cable IN jack then use audio out to my MY RECEIVER which repoduces the TV & audio signal, I then set my TV to the S-video mode to watch.
Aug 21, 2010 | Onkyo HT-S790S System
Connecting LG 42PG20 TV to Samsung HT-Z320 receiver
output on TV cable digital reciever to home theater digital reciever in via an optical cable.lower the volume on the TV cable digital reciever to get the most out of the surround sound system.
Oct 15, 2009 | Samsung HT-Z310T Theater System
No sound from Surround speakers of my onkyo reciever
Check speaker wireing make sure all positive and negative connections are correct. What cable are you running from tv or DVD player.check to see that wireing is correct on receiver for sorround speakers. Run audysee sound calibrator set up. Make sure correct settings for sorround sound in bluray player/DVD player
Sep 13, 2009 | Onkyo HT-S990THX System
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
Problem with Onkyo HT-SR700
Can you explain how you have the DVD player connected to the reciever and what the label on the jacks read on each.
Sep 16, 2007 | Onkyo HT-SR700 System
Channel Levels
You should adjustb it to what sounds good to you, as industry standards with a sound pressure meter says to start out at 0 db level. You should read this link and others at this other site. http://www.techlore.com/article/10037/
Sep 23, 2006 | Onkyo HT-S580 System
242 people viewed this question
 Grubhead
Grubhead
