Question about Pioneer 2 Handle Satin Nickel 6" Rain Head Shower Faucet+Valve....
Getting handheld showerhead plus rainhead - which valve? - a pressure reliefvalve or thermostatic valve
Which valve helps maintain water pressure the best?  a pressure relief valve or a thermostatic vavle?
This is for a dual system of handheld showerhead AND a rainhead shower faucet.
  • 4 Answers
I installed a 2 thermostatic valves in our shower. Two of us can use both showerheads simultaneously without being frozen or scalded.
Kind Regards,
IT_handyman
Posted on Dec 17, 2008
No water flow from new american standard marquette showerhead
I think fitting of your shower is not proper. You have to fit it properly if you can or you can call a nearest Plumber to solve your problem.
Mar 13, 2014 | American Standard Home
Loss of pressure in boiler, no obvious leaks, water pressure switch changed plus pressure release valve
Check that your make up water is on.
Make sure your fill valve is working but it sounds like it is not. Your min pressure should be 15 psig. on the boiler. Fill valve will maintain a15 psig on the boiler. Water and pressure does get out of the boiler when radiators are bleed. When fill valve is not working people will keep bleeding the radiators trying to get heat but only lowering the boiler pressure with no water make up.
Make sure your boiler is getting water and has pressure when running.
If it isn't...SHUT DOWN and have a professional look at it.
Pressure relief valve is factory set ta 30 psig and opens when pressure is above 30 psig. This is a safety valve.
Feb 17, 2011 | Heating & Cooling
I bleed my raditors,but no air or water came out ,,,plus no heat from 2 raditors,,,
You have a problem with your fill valve or pressure reducing valve...it is not uncommon for these valves to plug up or fail to work right.... this valve's job is to maintain 12 psi in your system.
Here is a tip that will help you with that also...
Valve Pressure Reducing or Pressure Reducing Valve
heatman101
Nov 06, 2010 | Heating & Cooling
When we hang up the handheld showerhead the
It depends on the model you have. Most have a large "nut" that will tighten down on the ball swivel. It should have finger grips. Tighten that nut some (clockwise) and it should get much stiffer.
Jul 04, 2010 | Water Pik WaterPik& Ecoflow Hand Held...
Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Jan 20, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
New House The women is complating that then she shower at any of her bathroom tub shower unit the faucet become cold for a little while on all her Moen chateau faucet. We have change all valve cartrige
The problem is most likely with "the back pressure from the flow restrictor in the showerhead causing the spool in the cartridge to sense a false pressure drop. This is forcing the spool to shift, restricting a full hot water temperature from coming out." Believe it or not, I got this information from Moen. Their solution was to send out a valve without the multi settings of the original and that didn't work very well. I can only tell you that I used an older showerhead without the water saver feature and the valve and cartridge worked fine. The problem your having is with the cartridge/showerhead combination and short of using an older showerhead there is not a satisfactory solution. Maybe your plumber has a better solution.
Dec 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Water does not come from the shower head
If your showre head has an external adjustment (usually on the face of the head) make sure that it is opened. Shower saver type valves have a push button on the pipe from the wall to the showerhead, usually close to or are a part of the showerhead. Make sure that it is opened, if you have one. Once done, remove the shower head and turn the water on. If you get water, look into the shower head. Most come with a water restrictor and it can come out of position and block the passage of water. The restrictors can vary in appearance, but usually they consist of a rubber washer and plastic disc, and are in the back of the showerhead where it unscrews from the piping from the wall. If you can get water without the shower head on, but no water through the showerhead, you can take it apart and look for restrictions or just replace it. If you cannot get water after all that, the problem is in your faucet or piping. Most Delta single handled faucets that I'm familiar with have a spring and cup washer valving arrangement. Those equipped with scald gard are somewhat more difficult to work on. Parts are available from H/Depot, Lowe's and similar. Hopefully the problem is in the showerhead proper, and not in the valve.
Best 'o luck, --W/D--
Jul 24, 2009 | Delta & Single Handle Shower Faucet
No water flow through the showerhead bracket
blow air through the part that attaches to the bracket and see if there is any air coming out if not you probably have a clog in the tube or the head.
Apr 26, 2009 | Water Pik Waterpik& Elements& Handheld...
I have one turn handle in the shower. When I turn it to the right for cold wter, the cold water comes out fine - good pressure. When I turn it to the left to get some hot water, the water goes down to a...
Alot of newer shower controls have a tempering valve on them. You need to open up the front of the unit (hopefully you have your owners manual and adjust the inner workings) this should solve your problem
Jan 04, 2009 | Water Pik Waterpik& Elements& Handheld...
Pioneer 2 Handle Satin Nickel 6" Rain Head Shower Faucet+Valve.... Logo
249 people viewed this question
Top Pioneer Plumbing Experts
Donni Steen
Tom Chichester
Are you a Pioneer Plumbing Expert? Answer questions, earn points and help others
