Question about Vacuums
Vax is not leting water out
Will not let any water out
How do iput water in a vax hard floor advance+steam cleaner s3s+
look for a big knob that you can unscrew. When you locate this knob unscrew fully and add water......then screw tighten and you are ready to turn on appliance.
Dec 06, 2014 | Vax Vacuums
How do I put water in a Vax steam hard floor mop
GO HERE> http://www.vax.co.uk/video-gallery/
Sep 30, 2014 | VAX Appliances Vacuums
Vax co uk support
There are a number of possibilities. I have this appliance and I'm not a fan of it!
  1. Check the water filter isn't void, which is behind the main water tank at the front. It should have a sandy colour to it and if it is low or discoloured, then it requires to be replaced.
  2. Fill the water tank with water and the back tank (if fitted) with clear "white" vinegar and switch on. If there is only one tank fill half with water and vinegar. Then press the trigger on the handle. If nothing comes out, You will need to buy a new water limescale filter which can be purchased from Vax UK.
Oct 31, 2013 | Vacuums
I need an instruction manual for a Vax Rapide Classic carpet cleaner
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
Sep 11, 2010 | Vacuums
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Water lesking from vax rapide carpet washer
i have been using a vax v26 carpet cleaner and the washing water is leaking from the bottom then the solution will not come out has the pump given up?
Jun 07, 2009 | Dirt Devil CE5500 Floor Keeper Upright...
Vax 6151sx water inlet tube
Have taken Vax to repair shop. Not easy to do at home, unless a qualified mechanic. The motor has to be taken apart.
Mauz
Feb 10, 2008 | VAX Appliances Vacuums
Open Questions:
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
