Question about Nordic Track NordicTrack Treadmill, A2550
Stops dead during workout
E3100 runs then stops dead panel continues to work
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
Dear Sir:
Most of the problem with this situation is lack of lubrication and regular maintenance.
The treadmill is very complex electronic equipment. The friction between deck vs walk belt is Enough for to protect the equipment, the electronic design shut down the treadmill, for to avoid damage to the electronic components.
2nd failure is main motor board. But you must lubricate your equipment, see your instruction manual or user guide. If you do not have you can download free from Nordic: www.Nordic.com, go to service customer, then parts%Manuals, give your model, etc, and download for free.
sincerely. God bless you
ernesto cuadra
managua, nicaragua.
Posted on Feb 15, 2012
I am having problems with my treadmill when some one gets on it then it slow downs and dosen
The first place to look would be the condition of the walking belt and deck. If they are worn, dry or several years old the friction between the walking belt and deck might be causing the drive motor to slow down during your workout. If the walking belt and deck have never been replaced we would recommend starting with that repair since these are parts which will need to be replaced anyway during the life of the treadmill. if you continue to experience problems following this repair, there may be a problem with a weak drive motor or in some cases a motor control board which is failing to send the appropriate amount of current to the drive motor during a workout.
Sep 12, 2012 | Life Fitness T5-0 Treadmill
Treadmill stops dead during workout
Dear Sir:
The most likely cause of the problem is a worn treadmill belt and deck.
Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics.
Feb 14, 2012 | Exercise & Fitness
My e3100 treadmill stops during workout
Dear Sir:
Please the first thing you must do: is Lubrication.
This cause enough friction between deck vs walk belt, by that reason the electronic design for to protect the system shut down the treadmill.
Of course the 2nd cause: can be the main motor board.
Try the first . sincerely. God bless you
ernesto cuadra
managua, nicaragua
How does the e3200treadmill fat calories work with the regular calories burnt.
Add incline. Instead of keeping the treadmill on a flat surface, maintain an incline as you walk, jog or run. This will serve to replicate the wind resistance and terrain variation that you encounter when you run outdoors. Keep an incline of at least 1.5 percent on your treadmill throughout your workout.
  • 2 Increase your speed. If you run at the same speed every time you workout, your body will not be challenged and you may reach a fitness plateau. Up your speed by a quarter-mile per hour every few weeks.
  • 3 Vary your workout time. In order to challenge your body in different ways, variety is key. If you run for half an hour three times a week, opt for a one-hour run for your fourth workout. This will help to condition your body for endurance training, resulting in more calories burned.
  • 4 Use intervals. Interval training can dramatically increase your calorie burn in an average workout. Instead of running at a steady pace for your entire workout, mix in sprints. Jog at a steady pace for two minutes, and then increase your speed to a full sprint for 30 seconds. Return to the steady pace to recover. Your heart rate will rise on your intense sprint intervals and stabilize on your longer recovery periods.
  • 5 Incorporate incline into your interval training. You can use incline in the same manner that you would speed to interval train. Walk or jog at a 5 percent incline for two minutes. Increase the incline to 10 percent for two minutes and then to the 15 percent maximum for one minute. Decrease the incline back to 10 percent for two minutes and finally back to 5 percent for two minutes. Repeat this same pyramid interval a few times.
  • 6 Wear a heart rate monitor. This will monitor how hard you are actually working as well as how many calories you burn in each workout. You can then adjust your speed and incline accordingly to maximize your calorie burn.
  • 7 Drink plenty of water before, during and after your treadmill workout. If you are dehydrated, you won't perform as well as you can. You'll work harder and burn more calories if you're hydrated
  • Nov 03, 2011 | Exercise & Fitness
    MY sharp aquos LC45GX6UTV will not turn on, the power light continues to keeping flashing red
    Thr power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
    Hope this workout.....
    Oct 16, 2010 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
    Healthrider s5001 treadmill stops during workout, shuts down. Will run for appx. 10 min.
    check manual for maintance on walking belt lubercation- mtr shutting down to over heating-pulling too many amps to rotate rollers/belt and to move you. Friction problem
    Jan 08, 2010 | Quantum ® 3.3ESD Treadmill
    My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
    my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
    Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
    Total elevation gain consistently way too high (20+ percent)
    I have the same garmin, and have the same problem.
    The high changes even during flat runs so when added you have this overamount of climbing.
    I just reduce the points of the track and then the addition is more accurate.
    My problem now is that the GPS stops working during runs (turns itself off). Awful!!!
    Aug 03, 2009 | Garmin Edge 205 GPS Receiver
    Manual Treadmills vs. Motorized Treadmills
    Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
    Dec 01, 2008 | Endurance TF3i Folding Treadmill
    Nordic Track NordicTrack Treadmill, A2550 Logo
    236 people viewed this question
    Top Nordic Track Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Electro Med Services...
    Paul Sikkema
    Paul Sikkema
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
