Question about Volfenhag ZX-4712 Car Subwoofer
12"volfenhag subwoofers I dont have the red and black connectors n the back how can i tell what is what
    Guru:
  • 200 Answers
Use a 9volt battery, touch both wires to the battery connections, if the speaker jumps upward and away from the magnet, the wire on the positive (+) terminal of the nine volt is positive (Red), if the speaker jumps inward towards the magnet, then the wire on the positive (+) terminal of the nine volt is negative (Black). CAUTION: only TAP the wires to the nine volt terminals briefly, if you hold them on there it may damage the speakers voice coils, (or other parts.) best of luck!
Posted on Oct 25, 2008
What size wire should i have for two 12 volfenhag subs
I would use 10 to 12 gauge wiring. As fare as your amp's fuse...Check to make sure you are using the correct amp fuse. Make sure your subs are wired to a ohm load your amp is stable with. Check your ground and positive connections. Check and make sure your amp's gain settings are correctly set. Your amp's gain should not be turned all the way up.
Sep 25, 2012 | Volfenhag ZX-4712 Car Subwoofer
Specs for Volfenhag 2500 watt 12
me pu ha ayudar con las medidas especificas de este bajo es 12 volfenhag de 2500 wats gracias
Jun 07, 2012 | Volfenhag ZX-4812 Car Subwoofer
How do i remove the red ring protecting the screws from the sub so i can put it in a new box?
oh its just a rubber ring you just use you fingertips and peel it back one screw at a time. use a power screwdriver or a cordless drill and your fingers wont get as tired cuz its tough stuff-
Dec 11, 2010 | Volfenhag ZX-4812 Car Subwoofer
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
Dont know how to connect daul voice coil on a icbm-5612 performance teknique.
If you want a 2 ohm total load..wire it from the amp positive(red) to the first coil positive(red) and then to second positive(red). Amp negative(black) to first coil negative(black) and then to second negative(black). This will give you a 2 ohm total load on the amp.
Apr 21, 2010 | Performance Teknique ICBM-6112 12" 4 Ohm...
Best way to connect a 15'' kicker cvr15 4 ohm dvc [single sealed box] and a volfenhag zx-4712 1000w 12'' 4ohm+4ohm dvc to my pyle 885 1000w 4 ch. bridgeable amp and how to wire the voice coils that are in...
best way is to just run the volfenhag with a set of wires for 2 channells(one set per coil) left and right @ 4 ohms per channell. The CVRs you can parallel the coils(2 ohms) and run a set from each sub to the amp in stereo left and right. This will give the kickers a little more juice than the 12 but should be fine.
Jan 25, 2010 | Rockford Fosgate Car Audio & Video
Sub box dimentions
12 " subs need 1.5 cubic feet sealed box...
Jul 17, 2009 | Volfenhag ZX-4812 Car Subwoofer
Is my amp powerful enuff for woofer
That amp should work fine for that sub, but you should make sure that the amp has a good power system going to it, and the box for your sub is the right one. Either one of those things could cause problems if not done correctly.
-Dynami
Apr 02, 2009 | Volfenhag ZX-4812 Car Subwoofer
Subs not working but power to amp and cap are
when u press down on the cone do u here the speakers if u do and u have to let go off the cone and you dont hear noting just some bass im tinking ur subs are burn out(they dont work)
Feb 18, 2009 | Volfenhag ZX-4812 Car Subwoofer
I need a wiring diagram for a Pioneer GM-A200 Amplifier
For a Pioneer GM-A200, pls use below wiring scheme:
  • Green & Green/Black - Left Speaker;
  • Gray & Gray/Black - Right Speaker;
  • Yellow - Illumination B+12;
  • Red - ACC B+12;
  • Orange - Always ON B+12;
  • Black - Ground/Chassis.
For the 8P INPUT DIN connector:
  • 1 - SWD +B;
  • 2 - Left Input
  • 3 - Audio Ground
  • 4 - Mute
  • 5 - Right Input
  • 6 - UN SWD +B
  • 7 - Illumination B+12
  • 8 - NC
  • Body - Ground
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 23, 2008 | Car Audio & Video
Volfenhag ZX-4712 Car Subwoofer Logo
106 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
