Question about HP Office Equipment & Supplies
How to insert inkjet print cartridge - HP Office Equipment & Supplies
  • 903 Answers
Open the printer cover>press the button with the ink logo/picture and the carriage will move to the middle and stop. Open the cover of the releveant ink you want to change and remove it. remove the strip with the arrow on the new cartride (should tell you how to do this on the box or foil wrapper), and gently push the new catridge back in place. Close the ink cover then close the printer cover then press the ink logo again. This should send the carriage back to the right hand side. Some models then automatically send out a test page.
I hope this helps
Posted on Oct 25, 2008
Why can't I insert ink cartage in slot?
please open the door of printer and push the cartridge slowly and then the cartridge push down, the cartridge come out.repeat this same process to insert new ink cartridge.
Oct 01, 2015 | HP Deskjet 2540 Inkjet Multifunction...
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
During printing, I got a message"cartridge error". i replaced both ink cartridges and the message occurred again. Now nothing will print.
Hi
be sure you have strip tape from your cartridges
if you had
follow these steps
1.take out your cartridges
2.disconect printer of power supply
3.take a wet paper towel (not to much wet)
4.clean cartridge metal site and cartridge carrier
5.insert power supply
6.insert cartridges in the printer
try printing
If I had help you pls vote me
Oct 04, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer software will not install
Hello Sir,
Plz follow this step
  • Step 1 Power up the printer. Plug the power cord into the back of the printer and press the power button one time to turn the printer on. If the printer does not respond, make sure that the power cord is completely plugged into the printer and the power outlet.
  • Step 2 Insert inkjet print cartridges. If you have an inkjet printermag-glass_10x10.gif, unwrap the print cartridges that came with your printer and securely fasten them in the printer cartridge carriage inside the printer. How to insert the inkjet cartridges will vary depending on the model of your Lexmark printer. Regardless of the model, you should not manually drag the print cartridge carriage over to install the cartridges. All inkjet models have a carriage that automatically moves to allow you easy access for installing cartridges. Be sure that the ink cartridges are firmly secured in the carriage before using the printer.
  • Step 3 Plug the USB cable into the printer. Plug the type B connector end (the smaller square-shaped end) of the USB cable into the designated port on the printer. Do not plug the USB into the computer until prompted to do so by the installation CD.
  • Step 4 Insert and run the installation CD. Most computers will run the setup program automatically after you insert the CD. If your computer does not automatically do this, select your CD drive and explore the contents of the CD. Double-click the "setup.exe" file. Follow the instructions the installation program provides.
  • Step 5 Print a test page. After you have completed installing the software for your printer, you will have the option to print a test page. This will confirm whether your installation and setup was successful. Be sure that you have loaded paper into the appropriate tray before printing a test page
  • Read more: How to Install a Lexmark Printer | eHow.com http://www.ehow.com/how_4699546_install-lexmark-printer.html#ixzz0tFYWphq9
    Jul 09, 2010 | Lexmark X5470 All-In-One InkJet Printer
    Won't print
    Turn the printer off.
    Wait 20 seconds.
    Turn the printer on.
    Lift the cover -- hopefully, the print-head will move to the position where the cartridges can be accessed.
    Remove one cartridge.
    Re-insert that cartridge.
    Close the lid.
    If you still get the "blinking", re-open the lid, remove the other cartridge, and re-insert that cartridge.
    Otherwise, see: http://www.usa.canon.com and enter your model-number, and download the manual (PDF) and follow its directions, or read the online-help for your specific PIXMA.
    Apr 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    Continually says align print cartridges
    My guess is that the color cartridge is either defective or not inserted correctly. I have a 6110 and know that inserting a print cartridge is a little tricky. If it isn't completely inserted and the top latch fastened correctly, the cartridge either won't work or produce errors.
    Try reseating the color cartridge so it's inserted in exactly the same way as the black cartridge and run a print job again.
    Open the following web page and go to Step three to see the instructions for cleaning the electronic contacts on the cartridge and print carriage.
    Ink Cartridge Alignment Fails
    Those seem the most likely causes and solutions to me. Good luck.
    Oct 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
    71 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
