Question about Dishwashers
CID45B10 DISHWASHER WILL NOT DRAIN
Hi, My dishwasher does not appear to be draining - any ideas what I should do? We had to fit a longer drainage pipe when we integrated it to reach the sink so just wondering if this might affect it? Thanks CP
5 Suggested Answers
SOURCE: Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
Posted on May 22, 2007
  • 121 Answers
SOURCE: water build up in dishwasher- clogged drain
I would not recomment putting chemicals in the dishwasher. There is usually some kind of filter in the bottomt at you can easily take out and clean. It's common to have parts of labels and plastic clog this up.
Try removing and cleaning this first. It may also be reached from a separate hatch in the fronc of your dishwasher, depending on the make and model. Just make sure it's securly back in place before you start it afterwards, or you may flood your kitchen.
You may also try to disconnect the hose and blow through it to see if you may be able to blow back any objects stuck there.
If none of this helps your problem may be in the pump, and then it's usually a job for professionals.
Posted on Nov 07, 2007
  • 4 Answers
SOURCE: Neff Dishwasher won't drain
I've had this problem a couple of times with my dishwasher. In both cases, the cause was a shard of broken glass that had managed to get past the filters and jam itself underneath the impellor. Hard to see, but easy to fix. First ladle out the water.
Pull off the lower rotor arm, unscrew the filter and take out the filter bowl, tray and cylindrical filter. Get as much water as you can out of the filter cavity.
Then, using a Torx-20 driver, remove the screw holding the impellor cover and lift the cover off. (this is the small bit of plastic at the left end of the filter cavity.) Check whether the impellor can rotate freely by spinning it with your finger several times - if it jams or grinds, then there's probably something jammed under it. (It may seem to be fine at first, so do check thoroughly, as any debris can move around with the water flow and only jam occasionally) You may have to use a cocktail stick or similar to poke out anything that's stuck underneath.
Glass is a particular problem, since it's almost impossible to see when there's any water around (it's easy to cut yourself too!)
Anyway, that's worked twice for me now - and I didn't have to even move the machine out of its cupboard to fix it.
Hope that helps.
Posted on Mar 14, 2008
  • 3 Answers
SOURCE: Dishwasher
you can buy the drainage hose ( B&Q) by the per / m if you can not install a drainage pipe closer.
Posted on Jun 06, 2008
Drainage-won't drain
Check the dishwasher drain line, it may be clogged. You will probably have to pull the dishwasher out from under the cabinet to remove it and check it fully. If it still doesn't drain, it is then probably your drain pump. I just replaced one of these and it was pretty easy. I bought from appliancepartspros.com because of their good return policy and prices. They can also help you diagnose your problem.
Apr 28, 2015 | KitchenAid KDTE404DSS 24 6-Cycle/6-Option...
Dishwasher Whirlpool quiet partner 2 will not drain
Check your drainage hose going to the kitchen sink. It should be routed up to an air gap on kitchen sink, or ran to the highest point as possible under the kitchen sink counter and then slope down into the disposer or branch wye tailpiece on your drainage piping depending on what your drainage configuration is. Not going up to the highest point, or an air gap, before draining into your drainage piping allows the water inside the dishwasher hose to drain back into the unit.
Feb 21, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher will not empty, already check basket and drainage hose.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Dec 20, 2010 | Kenmore 24 in. 16272 Built-in Dishwasher
Dishwasher will no longer drain completely
The pump is bad and needs to be replaced. The pump is not pumping out all the water from the system
May 05, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Dish washr
Can you access the drain hose without moving the dishwasher out? Is it close to the garbage disposal. You probably have a plugged drain. I would begin by plugging the sink that the garbage disposal is in and filling it full of hot water. Then I would unplug it and turn on the disposal and continue running water in it. This should clean the disposal drain well.
If you can access the dishwasher drain hose, you will need to disconnect it and look for a plug. If you can unplug the dishwasher do this first. It may be hardwired in, but some are not. It will all be behind the adjacent cabinetry. Have towels and a bucket handy. It is a good idea to always run some water through the disposal after running the dishwasher (they usually drain into that sink.)
If you cannot access the drain, I would clean the disposal and check all other household drains for slow drainage before calling a plumber. or your dishwasher repairman.
Good luck to you and thank you for using Fix Ya.
Aug 22, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
My dishwasher smells after use
Dishwasher Problems - Water will not drain out
heatman101
c
Aug 06, 2008 | KitchenAid KUDS01DJ - Multiple Color...
Bosch Running a LONG LONG Time and Watering Remaining
You could try running the machine with the drain hose leading to a large bucket. If it works OK in this situation then the blockage will be most likely where the drain hose joins the house drainage system - often at a junction under the kitchen sink. With the drain hose disconnected you should be able to see the blockage and clear it with a suitable pointy tool.
Let me know if this sorts it. Thanks, D.
Jul 31, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher
May 30, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher doesn't drain
how do you check to see if the pump is pumping? The drain is not clogged or blocked and the line is not kinked. The garbage disposal is not clogged either.
Oct 06, 2007 | Dishwashers
Dishwashers Logo
57 people viewed this question
Top Dishwashers Experts
