I have been running autocad 2008 on my old pc under windows xp cannot get it to start under vista ?
    Genius:
  • 1,226 Answers
Maybe you need an updates to run in windows vista..please see documentation operating system requirements.
melnavz
Posted on Oct 25, 2008
AutoCAD Windows 7 64bit
AutoCAD 2008 is not supported to run on Windows 7 (2010 is the first release that is). Try running the OS in XP / Compatibility Mode for increased performance.
Philip
AutodeskCare' Community Manager
TW ' PI ' YT ' BLOG
Aug 17, 2012 | Autodesk AutoCAD 2008
Autocad 2004 and win vista
Apparently, autocad is not compatible with vista.. Might as well, go back to wndows xp.. Please see the required specs to run autocad 2004
Mar 22, 2010 | Autodesk AutoCAD 2004 for PC
Unable to load autocad 97 on windows vista
I don't believe Autocad will work at all on Windows Vista.
The only other solution I can think of is to download Virtual Box from http://www.virtualbox.org/
You will need to have an XP cd to install, and basically you will be installing an XP virtual machine, at which time you can then install Autocad 97 onto that virtual machine.
Hope this helps!
Jul 19, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
AutoCad R14 to Vista - bab-Mem-Pointer error message
You are still using AutoCAD R14? If you are that might be the problem. If you are running Vista, then AutoCAD R14 might be too old of a version to run. You will probably need to upgrade to a newer version of AutoCAD. I know this isn't a solution, but I am just trying to look at it from a different point of view. You can also go to autodesk.com and join their discussion groups. It is free and you can post questions. You usually get a fast response with an answer that really helps. I will do a little more research and add more when I get a chance. Good luck and I hope that I helped.
Feb 22, 2009 | Autodesk AutoCAD LT 2008 - Upgrade for 5...
32 bit program to 64 bit opperating system
From the Autocad webiste:
System Requirements AutoCAD® Civil and AutoCAD® Civil 3D® 2009 Recommended System Requirements Recommended configuration (excluding server components used with project management capabilities):
  • Intel® Pentium® 4 (3 GHz or higher); AMD Athlon™; multiple processors supported, dual-core supported
  • 32-bit only: Microsoft® Windows Vista® Ultimate/Business/Enterprise, Microsoft® Windows XP (SP2)
Note: Windows XP 64 and Windows Vista 64 are supported in 32-bit compatibility mode only.
Here's how you should be able to run it in compatibility mode:
1. Right click on the Autocad Icon in your start menu
2. click on Properties
3. click on the Compatibility tab at the top
4. check the box next to Compatibility Mode and select Vista 32 bit if it is given as an option.
I don't have Vista here, but that is how it works in XP and I did do a search and it appears to be the same in Vista.
Feb 07, 2009 | Microsoft Windows Vista Home Premium with...
I have a Windows Vista 32bit machine ive installed autocad2008 but i plotter wont plot
IS the driver for the plotter installed? Can you plot using any other program? Is there a test feature in the plotter driver so you can test the plotter? What plotter is it?
Nov 14, 2008 | Computers & Internet
Help me for this problem please
Hi Hamzawork Autocad 2004 is designed to be used with Microsoft Windows XP (Professional, Home Edition, or Tablet PC Edition), Windows 2000 Professional, or Windows NT 4.0 (SP6a or later) therefore I'd suggest to run your Autocad 2004 using Compatinity Mode --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
Nov 07, 2008 | Autodesk AutoCAD 2004 for PC
I am running Vista and when Panning in AutoCAD 2008, the window goes diagonal as when 'switching between windows'. How do i disbal this Vista feature when I'm using AutoCAD? Any assistance would be...
check the option in the video card drivers i dont think vista has
that option, usually Nvidia or ATI has a control panel for fixing the
way LCD's behaviors
Jun 25, 2008 | Computers & Internet
AutoCad LT 2006 incompatible with Windows Vista
some of the older versions of autocad does'nt tend to work in vista.try installing autocad 2008 or 2009.it is recently released and well compatible with vista.REMEMBER, if u r using it for architectural purposes,try downloading autocad architecture 2008.it is especially made for architects.try downloading it on torrentz.com
Jun 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Conflict with Autocad 2004 (using Windows Vista)
May 23, 2008 | Autodesk AutoCAD 2004 for PC
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
