Question about Canon PowerShot S300 / IXUS 300 Digital Camera
E18 I used my Camera on the beach this weekend. Now the lens will not move and it reads E18 on the screen. I am thinking sand might have started this problem. Thank you for your time Straw
  • Canon Master
  • 4,738 Answers
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it short of sending it in for costly repair. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Posted on Nov 16, 2007
  • 641 Answers
The "E18" error code indicates an error that involves the lens unit or lens cover and it's make sense that the reason for it is sand. Try to clean lens area using air pressure. In case it will not help, you should send the camera to the appropriate factory service center for correction of the error. Following the repair cost you should decide, whether it worth it
Posted on Aug 01, 2007
Message e18
There is some sand or other light material blocking the lens
Jan 19, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
The screen won't come on for viewing and the lens won't retrack, it also started popping up with E18
That is shutter error code. I am sorry to tell you have to buy a new camera, it would be to expensive to replace.
Nov 15, 2009 | Canon PowerShot A95 Digital Camera
Lens error was at beach no sand but yet when turned on it says lens error
Anyone who has ever been near the beach knows that as soon as you are within 100ft of the sand you will feel sand in between your toes even with your sneakers and socks on. That's because sand is in the air and contaminates everything. Therefore, if you value your camera, mp3 player, radio, cellular phone PDA, or laptop computer, DO NOT TAKE IT anywhere near the beach. Solution: use an air compressor. Blow air & dust through the hose first. Use clean air to blow out extended lens area. Open and close lens and blow out several times. Firmly jolt the camera into the palm of your hand to dislodge the dirt particle. Use more air. You may notice sratches on the side of the lens cylinder that were created by the particles of sand. 99% pure isopropyl alcohol (91% if you're in a pinch is available at any drug store) can also be used on a Q tip and swabbed around the lens barrel cylinder. Make sure you use a few CLEAN Q tips on the lens. Now go buy a disposible camera and $10 mp3 player for the beach and leave the $200+ camera and IPOD at home or at the hotel room. Now you'll surely have a wonderful time at the beach.
Jul 28, 2009 | GE A730 Digital Camera
I dropped my mx1063 in the sand at the beach. I
This is not a user solvable problem. One thing that should not be done is to turn on the camera when it has been dropped in dirt, sand or water. This will, in your case, grind the dirt around and parts try to move and contaminate additional parts of the camera. It's only worse if water is involved as this will likely cause shorts in electrical areas.
Take the camera to a repair shop and get their opinion on whether it is fixable and if so what they estimate the cost to be. Sometimes it's cheaper to buy a new or used camera.
Jul 22, 2009 | Kodak EasyShare V603 Digital Camera
E18 error on canon digital camera s200 powershot dropped it and now the lens is stuck halfway out/in The lens will not open, it was not dropped. I get e18 error.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
Hope this helps, let me know if you have a proble.
You can Try the following also;
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Try the above and let me if its any help.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 07, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
I think I have sand in my casio casing. The pictures are sometimes blury and the zoom doesnt always go in and out. We took it to the beach, and well...... Is a Casio Elilim ex-s600. Do you know how I...
You will not be able to clean out the sand yourself. The sand probably got in to the mechanics of the lens and other moving parts.
The inside of the lens is made like a watch, and is very precision for calibration. Once you open up your camera and especialy the lens, I have doubts it will ever work again!
Servicing the camera may not be cost effective. You can enquire to Casio to see what they would charge for this type of service. I would think it would be more feasible to replace the camera.
If you want to take a camera to a beach, make sure it is in a sealed containment. The water vapour, any salt spray, sand, and or sand dust will certainly cause damage to even the most expensive cameras!
Jerry G.
Jul 01, 2008 | Cameras
Does it need regular cleaning?
Sand generally has no effect on the electronic side of the camera, however it will definitely can cause problems with the mechanical aspect of the camera such as the zoom lens. this can be removed with a can of compressed air.
Suntan lotion likewise should not be any problem except for smudges on the housing/casing and especially bad for the lens. Additionally, the lotion would help the sand adhere to crevices and nooks of the camera. Wiping should get you just fine.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 17, 2008 | Canon PowerShot SD600 Digital Camera
Cannon power shot a70
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Nov 24, 2007 | Canon PowerShot A70 Digital Camera
E18 & I don't know what to do with this camera.
This is the hardware problem your camera’s lens gear also damaged if you have some experience to open your camera jacket clean lens gear.
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
E18
This error is cause by a few things. First you need better power, how old is the unit? The battery pack may need replaced, the lens mechanism draws alot of power and sometimes if the flash is charging and the lenses are moving it struggles for power and shuts down. Another thing that can cause this error is jammed gears in the lens. This can be cause from an impact (dropped unit) or debris in the lens mechanism (sand, dirt, dust) the gears are so small and as is dust anything can blow in there and get jammed in the unit to jam it. I have got units to function again by tapping on the front of the lens while repeatedly tapping on the front of the lens. The idea is to work the jam out and free the lens. The E18 means a stuck lens but the reason its stuck i canot tell with out looking at it. Tap on the front of the lens (the part that moves in and out like a telescope) or try and tap on the side while powering it on. If you know some one with a unit like yours try their battery before you get a new one. They are very power hungry and if your unit is a few years old it may be time for a new battery.
Apr 03, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot S300 / IXUS 300 Digital Camera Logo
102 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
