Question about Coffee Makers & Espresso Machines
Jura Impressa S95 "PRESS KEY/POWDER QUANTITY" message doesn't disappears
Hello! I bought an used coffee machine "Impressa S95", but now i have a problem. Even when i start the machine, or after a coffee, or just after while, a message appears and it don't disappear, even i try to set everything, reset, power off and on again. Sometimes after a time i let it stopped, it let me make coffee. The message it's "PRESS KEY / POWDER QUANTITY", i know what this usually means, but this should appear when i press that button, not random and blocking the machine. I looked into the manual but i couldn't find any type of error like this, any ideea. If it's possible to give any possible solution, i would be very happy. Thank you!
SOURCE: "water pipe empty" icon will not disappear from display screen 3, cannot brew coffee, first use - second machine to have this problem
I have a Siemens surpresso S40 with the same problem.
Try to fill the tank with hot water. I dont't know why but it solved the problem for me.
Posted on Oct 28, 2007
  • 46 Answers
SOURCE: jura impressa S70
its a grinder group fault , the seal on the internal group head (the part that compresses the ground before brewing) has stuck or gone dry from lack of use. if u gain access to the internal of the machine( may need a special tool, oval head srews) grease with food grade lube, the red/orange seal on the long 45 degree cylinder inside. u can manually turn the gear by hand once inside. If still a problem check the motor that drives the same unit.
Posted on Feb 09, 2008
SOURCE: jura impressa s9
A hose has popped off inside the unit.   It is probably due to calcification (waiting too long between cleanings), or using too much powder (more than 2 tbsp) on the manual powder function.
Posted on Mar 01, 2008
  • 60 Answers
SOURCE: fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Posted on Jun 02, 2009
SOURCE: Jura impressa x90 keeps beeping
may need descaling, if this is the case you always need to descale first
Posted on Jun 23, 2009
My Jura Impressa C5 does not descale, automatically or manually. If I try the latter by pushing the descale button, all three upper button start flashing, instead of just the middle, with the coffee...
Dont worry about what that bloke said.
I have just had the same problem - the machine thinks it has a filter in it so take it out and follow the manual to deactivate the filter. You will now be able to rin the descale.
Aug 24, 2013 | Jura Impressa C5 Automatic Coffee Center...
Jura impressa j5 coffe not coming out spout
Jura imprezza z5
The machine is working but the coffe is not comming out
and the coffe powder just been thrown into the junk box,
in the begining the machine made a brakedown in the electricity.
Feb 12, 2013 | Jura Impressa J5 Refurbished Coffee...
Jura Impressa X90 doesn't give water or coffee. Keeps saying: fill system
Hello, make sure the magnet in the water tank moves freely, sometimes it gets stuck with deposits, its a small black rectangle near the base. if its not free, you need to put some descaling solution it the tank to clear it.
Jul 03, 2012 | Jura Capresso Impressa X90 Espresso...
Tray missing
On the right side inside you can see a small slot. Try using a screwdiver or something to click this small microswitch, if the message disappears, then you need to check your tray and see if something is broken. You can also try to move a little on the tray when it`s in the machine. However if clicking on the microswitch doesn`t help, you need to have this switch replaced in a servicecenter
May 27, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Impressa S95 recently, the amount of coffee being served is much reduced and water seems to be diverted through the steam outlet
Find a great article on what needs to be done here:
http://www.wholelattelove.com/articles/jura_capresso_cleaning_guide.cfm
Dec 28, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura x90 flashes message fill powder and we don't use powder
It seems to be the microswitch on powder lid that`s not locking. Check if there`s something missing from the lid, and then maybe try to put something in to close the switch.
Jun 22, 2009 | Jura Capresso Impressa X90 Espresso...
Clean machine/machine ready light won't go away
Have experienced the same problem for the last nine months. Was finally able to solve it today by following this guide: http://www.wholelattelove.com/articles/jura_capresso_cleaning_guide.cfm
Having cleaned the shower screen I ran the regular cleaning cycle and now the display indiucates "Ready" as it should do.
Sep 07, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura impressa s9
you need to clean / lubricate the "plungers". The normal clean cycle will strip off the lubricant over time. See my post here:
http://www.fixya.com/support/t348905-malfunction_8
Feb 18, 2008 | Jura Capresso Impressa S90 Espresso...
Add more powder
Not sure - our machine always says that even if the powder is full
Aug 08, 2007 | Jura Capresso Impressa E8 Espresso/Coffee...
Coffee Makers & Espresso Machines Logo
74 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
