Question about Symbol MC9060-G
Backlight needs to be increased - Symbol MC9060-G
    Problem Solver:
  • 5 Answers
Look for the "bulb icon" on your keypads
Posted on Feb 17, 2012
Samsung un55d6300 buzzing
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 24, 2015 | Samsung 55 UN55D6300 LCD TV
Best quality picture
This is likely a simple settings issue.
A lot of people don't realize that backlight settings can affect the picture.
Go to the menu (press menu on your remote)
The menu will show picture options. Just toy with different settings until you find what you want. It may be on a preset setting that doesn't work. If you are in a bright room, you will need to increase brightness and contrast and perhaps backlight.
Usually an unclear picture is due to the contrast, backlight, and brightness settings being too low. You can also increase sharpness.
I suggest a contrast setting of 70, a brightness setting of 60-80, and a backlight setting of above 80.
Good luck.,
Mar 08, 2014 | Hisense 50 Class LED HDTV - 1080p, 1920x...
Lost its brightness and clarity
Hello
Check whether the backlights get full brightness as you increase the bright ness level. Set the set to least contrast level, and check whether the backlight is sorking well. If it is OK, then try to increase the contrast level [to at least 70% of the total]. If backlight level cannot be adjusted according to the contrast level the backlight inverter baord and backlight CCFL lamps need to be checked.
images of the backlight inverter board and CCFL lamps are attached here.
Feb 21, 2012 | Toshiba 42HP66 42 in. LCD Television
How do you increase the volume of the backlit light?
Hello
The backlight can be adjusted as follows:
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To
select a backlight setting, press the 3 Snooze/Dimmer Bar until the desired brightness is reached.
Please note that the backlight will not work while the clock is operating on battery power.
OK
Apr 07, 2011 | Timex T311T Clock Radio
You can hold a flashlite to see the screen, i was told it might be the light bar or inverter can you plz tell me what the problem is before i spend to much money
Ok if you can see the image when you show a flashlight to it means that the backlight is not working, it could be a simple problem as the backlight power cable loose inside or in worst case the backlight completely damaged. Best to take it to a service center and they will be able to tell you what happened. Hopefully it's just a loose cable.As LCDs do not produce light themselves they need illumination (ambient light or a special light source) to produce a visible image. Backlights illuminate the LCD from the side or back of the display panel.Backlights are used in small displays to increase readability in low light conditions.You can search for info on Backlight to learn more about it.
Jan 25, 2011 | Computers & Internet
My dell inspiron 1525 notebook brightness is goes down,it looks very dark, whatshould i do?????
Press the Fn key and the up arrow key simultaneiously, this should increase the brightness. (down arrow key reduces the brightness)
If this does not increase or decrease the brightness, then the problem should be with the backlight or the backlight circuits. Please contact Dell for a replacement of the LCD panel (if your computer is in warranty) if not contact a local tech who can replace the LCD panel or the Backlight for your laptop
Dec 25, 2010 | Dell Inspiron 1525 Notebook
I have nc 6220 laptop hp after windows xp professional restoration i have dim screen problem
Couple of possibilities here...
Hardware may be set for low brightness, look at keyboard for icon of a sun. Press the function key and this button to increase the brightness.
Driver may be needed - get from manufacturer website
Backlight / flourescent light is near end of life - may need to be replaced.
Inverter Board for back light is having issues - may need to be replaced.
You can replace the inverter board without replacing the backlight, but if changing the backlight itself, the inverter board needs to be replaced as well.
Jun 11, 2010 | HP Compaq nc6220 Notebook
Screen is to dark. cannot see letters very well.
Suggest you press the Fn key And the key to increase brightness, first. (Should be a key that has a sun icon on it)
Barring this does not increase the visibility of your LCD screen, the I suggest the Backlight is bad, or the Inverter.
The Backlight is a type of CCFL tube (Cold Cathode Fluorescent Lamp) mounted to the LCD screen. The LCD screen needs the light given off of the Backlight.
Replacing the Backlight is a daunting task, and if done wrong, will cause possible damage to the LCD screen.
The LCD screen itself has a thin metal frame holding the components of the LCD screen together. This frame must usually be opened on the side that has the backlight, to access the backlight. The components that make up an LCD screen are fragile, and can easily be damaged.
The Inverter supplies power to the LCD screen, as well as the Backlight.
Inverters do go bad, but commonly it's the Backlight to go first.
This shows a typical Backlight replacement. It IS not an advertisement to attempt this yourself, but a reference tool for information.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Nov 16, 2009 | Itronix GoBook III Notebook
How do you make d screen glow?!?! is it possible (d same clock theyre decribing) d one with d stylus on the bak
You cannot make the Screen Glow however you can increase the Backlight brightness of the Screen
follow the Steps:-
Click Menu Key
Goto Options Icon
underthat select Screen/keyboard
then select Backlight Brightness option and increase the Brightness to 100.click on save...
Nov 09, 2009 | RIM BlackBerry Pearl 8100
The screen is too dark to read anything though the power comes on. i tried to increase the brightness but did not work NEED HELP!!!
Sounds like your backlight or inverter is on its way out. You can pick one up on ebay.  Google how to check backlight/inverter issues with your model.
May 02, 2009 | Computers & Internet
Symbol MC9060-G Logo
56 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
