Question about Pioneer DEH-P730 CD Player
Pioneer deh p730
Hello, does anyone know how to fix the display on this unit from changing to black, then to blue, then black and blue? The background/foreground keep switching colors back and forth and its annoying the hell out of me, does anyone know the setting to fix this????
    Scholar:
  • 148 Answers
Has it always been like this? I know that the display inverts automatically to save the life of the OEL...otherwise the brightness of the same pixels being on all the time will cause the OEL to 'burn-in' If that isn't the problem, the OEL is going bad. They can run about $100 and usually aren't worth repairing.
Posted on Aug 17, 2006
  • Jexx Jexx
    Jexx Jexx Oct 31, 2006
    I need to follow up on this.
    No, it is not a problem. With the unit turned off but still receving power through the ignition and battery constant power wires, press the #5 button key and it will disable the screensaver from inverting. I believe it is done to preserve the life of the OEL.
Hello, I have an odd problem with my Pioneer DEH-P9800BT Screen
Clean all contacts chemically and check all wiring for good, tight connections.
Aug 25, 2017 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
How to set clock on deh-p730 pioneer car stereo
For most older Pioneer single CD players, you can set the clock using the following steps:
  1. Press and hold the SOURCE button until the unit shuts off.
  2. Press and hold SOURCE again until the clock appears.
    *With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button.
  3. Press the left or right arrow to select the segment of time you wish to adjust.
  4. Press the up or down arrows to increase or decrease the numbers in the blinking segment.
  5. Once the clock is set correctly, press the SOURCE button to exit.
Apr 20, 2011 | Pioneer DEH-P730 CD Player
I purchased a Pioneer Deh-1400 cd am fm player 2nd hand with no manual. Can anyone tell me the proper wiring connections? Only the power line is labeled.
remote turn on is blue with a white stripe and antena is blue 12+ is yellow acc is red ground is black left front is white with gray stripe right front is gray with black stripe green with black stripe is rear left and purple with black stripe is right rear
May 18, 2010 | Pioneer DEH-1400 CD Player
I have the Pioneer DEH-P5100UB. How do i stop the display from changing colors from blue to black?
I have the same radio, it doesn't have preset buttons...to get it off u turn the key to on/acc and turn the radio off. then press the "band/esc" button.
Nov 11, 2009 | Pioneer DEH-P5100UB Car CD/ MP3 Player
The pioneer deh-1100 does not have a color code for the wiring. Does anyone know the color code?
Here is the breakdown of what wire does what:
+Red..............12v ignition
+Yellow...........12v battery
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Sep 05, 2009 | Pioneer DEH-1100 CD Player
I dont have a wiring diagram for the 16 pin plug on a deh-p2500 pioneer car stereo. Can Anyone help? It is a used unit.
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 25, 2009 | Pioneer DEH-P2500 CD Player
Cant find the reset button
should be behind the face its a small black hole use a ballpoint pen and gentley press
Mar 27, 2009 | Pioneer DEH-P730 CD Player
I need a wiring harness for my deh-p730
Most Pioneer units follow the below detailed color codes for the wiring.
Yellow - +12V Constant Power
Red - +12V Switched (accessory) Power
Blue - Power Antenna
Blue/White - Amp Turn-on
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 16, 2008 | Pioneer Car Audio & Video
Pioneer Premier DEH-P730
Pioneer follows standard color coding for stereo/headunit wiring. Pioneer car stereos needs two wires plus the ground wire to be activated. The yellow is connected to the always on B+12 such as the positive terminal of the battery, the red goes to a switched B+12 such as the ACC of the IGN switch while the black of course goes to the chassis/body ground.
Should the above been done correctly and problem persist, then perhaps the fuse may have blown, there is a loose connector at the rear of the head unit or a probable internal electronic defect has developed.
May 11, 2008 | Pioneer DEH-P730 CD Player
Display
try checking on the settings maybe you accidenally change the lighting schemes in your unit.
Oct 18, 2007 | Pioneer DEH-P6900UB CD Player
Pioneer DEH-P730 CD Player Logo
247 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
