Spin , end . 400 lights flashing on bosch wis24140gb, won't reset.any idea to fix without taking out completely
  • 1462 Answers
SOURCE: Bosch WLF 2260
suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
Posted on Jun 14, 2007
SOURCE: washing wont spin or turn but takes water in and pump out without spinning
Electronic door lock faulty.Replace
Posted on Nov 05, 2007
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
  • 57 Answers
SOURCE: Bosch WFO2865GB that stops before the Spin cycle
probably not draining fast enough, check for blockages at filter, sump, outlet and plumbing
Posted on Mar 30, 2010
  • 118 Answers
SOURCE: I have a Bosch Maxx
this is because the water can't evacuate . check the pump trap filter and make sure there are no blockages. you will probably find water still i the machine when this happens. There might be a blockage up in the hose pipe before the pump. Good luck
Posted on Jan 22, 2011
Bosch logixx 7 (5 years old) Serial No WIS24140GB/07 door will not open at end of programme. start/pause, 400, rinse, spin & end lights all flashing and a bleeping sound. To open door have to switch to off...
After trying to find manual and doing it the right way with no success my son solved the door problem with a metal fork. Where your hand meets the handle (inside the door drum) shove the fork in to force the clip open. Not the outer edge of the door, theres no locking system there - behind the actual handle.
Aug 29, 2013 | Washing Machines
WFL 2260 Fills hot, fills cold, no wash action, move control to drain, empties, move control to spin, no spin but goes thro. cycle ends program door unlatches, any suggestions?
Motor brushes, worse case scenario motor complete. Run the following motor test.
1. Put main dial to off
2. Press and hold start button whilst turning dial one click to left (easycare 30).
3. When display show 8.88 or two of the progress light come on, release the start button
4. Turn dial anticlockwise to 60 cotton (take the long way, NOT thru OFF or you'll have to start over)
5. Press start
6. Motor should rotate in both directions, pump runs, motor kicks up to full spin.
7. No motor action and two lights flashing on progress lights (separated by a light that's not on) indicates a motor fault.
As suggested brushes or complete motor.
Hope this helps
Mar 27, 2013 | Bosch WFL 2063 Front Load Washer
Bosch classix water won't drain
check for blockages in the outlet pipes, filter and pump.
Dec 30, 2012 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch she4ap06uc/05 quick wash light flashes. I have tried to reset it and it will not reset. The sump pump work and drains all the water out of the machine. It turns off and on fine but when...
Bosch she4ap06uc/05 This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 13, 2011 | Dishwashers
F43
Hi.
If you have Bosch, Baumatic, or any other machine built by Bosch, then F43 is a motor issue:
Error F43 : Motor fault: do an emergency drain through the drain access in the front bottom side (see manual). Open door and check ig the drum rotates free when spin by hand. Disconnect power before performing maintenance.
Regards.
Ginko
Sep 14, 2011 | Washing Machines
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Jun 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
All of a sudden my sb-400 won't fire. i have changed the batteries numerous times and the red ready light is on but when i take a pic the auto flash pops up and the speedlight won't fire.
HI, I have a SB-400 with cracked housing, and hope to find a broken one to replace my part. Any offer is very much appreciated if you are interested of selling yours! Sincerely, Samantha (utwicky at gmail dot com)
May 14, 2011 | Nikon SB-400 Flash
Mar 29, 2010 | Bosch Washing Machines
Bosch WFF 1800
There is no draining & this is why your spin does not work. There is only one belt. First siphon out the water from the machine via your front door. Clean out your outlet filter, check the tube from the tub to the filter. Luckily there shouldn't be a block in your outlet pump
Dec 07, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
