Question about Tyco Electronics / Raychem T312M-Printer
Data light flashes when print job is sent but doesnt print anything. Print queue on server is clear
Our Data light keeps flashing and the printer won't print. How do we get the data light to stop flashing so we can use our copier again with our computers?
Sounds like a bad print job stuck in a print spooler.
Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
Jan 15, 2013 | Sharp Mx-M450nb Digital Copier
Hello guys, i´ll be very
Issue Print jobs are stuck in the print queue (spooler) on a computer running Microsoft Windows connected to the print server. Nothing prints, and the print job in the printer's queue shows a status of Printing . These print jobs cannot be deleted even on the server, and it will not disappear or print until the Print Spooler service is restarted. Solution For Microsoft Windows Server 2003 and Microsoft Windows XP Professional x64 Edition, a fix is available in Microsoft Knowledge Base Article, The Print Spooler service may stop sending print jobs to a printer that uses the standard port monitor on a Windows Server 2003-based computer . Click here to view Microsoft Knowledge Base Article 934885 (http://support.microsoft.com/kb/934885) . To prevent this issue from occurring, disable the bidirectional printing support for each HP printer driver installed. To do this, perform the following steps:
  1. Click Start , point to Settings , click Printers , right-click the icon representing the printer to be modified, and then click Properties .
  2. Click Ports , click to clear the Enable Bidirectional Support check box, and then click OK .
NOTE: Sharing a printer over a network is a feature of Microsoft Windows and not HP printer specific.
Nov 01, 2010 | Office Equipment & Supplies
I HAVE A LEXMARK 5690 AND THERE IS A PRINT JOB STRUCK IN THE PRINT QUEUE AND I CAN'T GET IT TO CANCEL. THE OTHER JOBS AFTER THAT WILL CANCEL BUT TO FRONT ONE IS STUCK. AND I CAN'T PRINT ANYTHING AND I...
1. Go to Start, Control Panel and Administrative Tools. Double click on Services. 2. Scroll down to the Print Spooler service and right click on it and select Stop. In order to do this, you need to be logged in as Administrator. At this point, no one will be able to print anything on any of the printers that are being hosted on this server.
3. Next you need to go to the following directory: C:\WINDOWS\System32\spool\PRINTERS. Delete all the files in this folder. This will clear all print queues (it’s a good idea to first make sure there are no other print jobs being processed on any of the other printers on the server because doing this step will delete those jobs also)
4. Now you can go back to the Services console and right-click and choose Start for the Print Spooler service!
You can also go to a command prompt and type net stop spooler or net start spooler to start and stop the service.
Sep 01, 2010 | Lexmark Office Equipment & Supplies
I finally cleared a paper jam, and now my printer is trying to reprint all the documents I sent to print while there was a jam. I do not want these to print since it will waste a ton of paper and ink. How...
There should be a little print queue icon down by the clock.  Double-click on this to open the print queue program.  From there you can remove jobs from the queue.  NOTE:  It can take a minute or two for jobs to remove themselves.  It's not instant.
Please rate me if you found this helpful.  Thanks.
Mar 07, 2010 | Dell P1500 Laser Printer
We have a spooling problem. The sharp mx-2300n just says "ripping" and 20% complete but won't move from there and print anything. Can cancel print job from Mac but won't stop anything at the printer end....
Go into the Job review mode and highlight the pending print job (note: it may be stuck in processing). You should then get the option to delete the job.
Make sure that the pending print job is also cleared from the network print queue. They can sit in the queue and be persistent on processing, even after you've cleared the copier. Clear the queue prior to deleting the job on the copier.
If this doesn't, disconnect the copier from your network and try the above steps again, then reboot the copier and reconnect it to your network.
If you're trying to print out Adobe-based web pages from the internet, this may be what's causing your copier to jam up. There's known coding anomalies with Adobe-embedded documents on web pages. Trying to directly print from the web page can stall or lock up the print process.
Sep 07, 2009 | Sharp MX-2300N Color Copier
I have a d-link DP 301u can't print to printer
found it just not to be a good product could not get it to work properly.
Took a netgear ps121 and had it connected and working in less than 5 minutes and could use the manager sofrare that came with the printer.
Jan 02, 2009 | D-Link DP 301U (DP-301U) Print Server
Samsung clp 510
usually happens when the NIC card goes bad, may need to replace.
first try resetting the printer, look in your manual
Aug 25, 2008 | Samsung CLP-510 Laser Printer
HP LaserJet 1018 & DP-G310
Does your network have a dedicated computer server and the printer is attached to this server or is the printer attached to a dedicated print server device?
OR
Does a computer on your network shares its printer with other computers on your network?
There is insufficient information on how you configured your printer setup for me to give you a proper answer to your problem.
Jun 10, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Lost Connection after 1 print-job
Please check the print queue in the computer. Clear it. Then restart the printer and the print server. See what happens...
Oct 24, 2007 | U.S. Robotics USR7500A Print Server
How do you clear the stored memory?
The problem is not with the printer, but with your PC print queue still having the outstanding print job. Anytime you power off a printer, it automatically clears it's internal memory. Depending upon which operating system you are using, you need to go to the Printers Folder, open up the queue, and delete the print job there. Once the queue is clear, that should take care of it.
May 01, 2007 | HP LaserJet 4 plus Printer
Tyco Electronics / Raychem T312M-Printer Logo
24 people viewed this question
Top Tyco Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Tyco Office Equipment and Supply Expert? Answer questions, earn points and help others
