Question about Air Tools & Compressors
I have central pneumatic 21 gal. air compressor. The unloader valve is broke. The power switch is a fenwai model: fw-10. Where can I buy a new unloader valve?
    Genius:
  • 1,212 Answers
If you should mean the switch that is pressure controlled that turn the compressor on and off- that is a fairly universal replacement piece, As is the power switch itself
If you needed that specific part, your best bet is Harbor Freight tools who owns the Central Pneumatic domain.
Posted on Feb 15, 2012
  • 1 more comment
  • justforfun29 Feb 18, 2012
    Harbor Freight only has the 1/4" line that comes off the manifold that screws into the tank. They don't carry the fitting that connects the line to the on/off control.
  • John McPherson Feb 18, 2012
    Northern tool carries an item that should be similar:
    http://www.northerntool.com/shop/tools/p...
    It has a 1/4 inch fitting, it can be attached to other sized lines with reducing bushings/couplings. If yours has that part integral with the pressure tube coming from the compressor head to the tank, or the port for the tank outlet; reworking those lines with new plumbing will need to be done and a "T" installed to accomodate everything.
  • Peter Swiderski Sep 14, 2012
    The Pressure Control Switch on my Central Pneumatics compressor developed a leak in the diaghram. After purusing the internet for a replacement pressure control switch I found the exact replacement needed on ebay at one/fourth the the price at other venders. ALWAYS include ebay in your searches.
manhandy
  • 146 Answers
SOURCE: can't find air filter for central pneumatic air compressor
i do not know which one you taking about! the Air intake or in line moisture type on the discharge.
but both are universal just go to air compressor shop or go on line.
Posted on Jul 05, 2009
  • 3600 Answers
SOURCE: what type of oil for central pneumatic air
It should use 30 weight mineral oil, or 30 weight motor oil.
Posted on Aug 06, 2009
  • 41 Answers
SOURCE: central pneumatic 2 hp 4 gal air compressor has
can you please tell me where are the leak found as there are different place with dif temp seal
Posted on Sep 27, 2009
lindsay836
  • 677 Answers
SOURCE: I need parts for a central pneumatic compressor
http://www.harborfreight.com/manuals/93000-93999/93785.pdf
That should be it, please let me know.
Posted on Feb 06, 2010
  • 1388 Answers
SOURCE: I have a Central Pneumatic,
If air leaks when motor is off, fault most likely in-tank check valve. Follow discharge air line from pump to tank. Brass/steel valve at tank is the check valve. Remove hose to valve and check for leak. Replace as needed. If air is leaking while motor is running fault could be reed valves in head. Faulty reed valves in head, or torn head gaskets will cause very hot discharge air and tank will most likely never fill to shut off (or take a very long time to fill)
Posted on Sep 07, 2010
21 gal vertical Model 94667 will not fill tank.
Could be piston rings too. Have you looked here? http://www.centralpneumaticaircompressors.com/buying-central-pneumatic-air-compressor-parts/
Oct 14, 2013 | Air Tools & Compressors
Central pnematic compressors, will not build up air
Use soapy water to check for air leaks. Can also check piston ring and valves. Make sure engine is driving the compressor.
May 19, 2013 | central pneumatic 212cc, 9 gal., 135 PSI...
Searching for fenwai pressure control fw 10
If your compressor is a piston compressor, try cleaning the check valve which comes from the pressure switch to the tank (it has a little spring and a rubber/plastic valve inside)
Otherwise check to see if it is sucking air in properly, (whilst it is running, remove the air filter, and very quickly put your hand over the air intake to see if it is sucking whilst it is at 20 psi, if not, then it may be that the valves in the head maybe either broken or not seating properly
If it is not a piston compressor, then it maybe the MPV needing some attention
Hope that helps
Aug 22, 2012 | Air Tools & Compressors
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Why coolant coming through air filter element?
Hi dear,
There problem is loan/unload pneumatic valve not work properly. Please change this pneumatic valve.
Jun 20, 2010 | Ingersoll Rand Stationary Air Cooled...
25 gal horizontal craftsman air compressor is leaking at the pressure control valve. Can I replace the valve or repair it?
Unloader valve probably needs to be adjusted. Should be two jam nuts holding the unloader to the pressure switch. Loosen the jam nuts and adjust the unloader slightly away from the lever. Tighten the jam nuts and try it again.
May 21, 2010 | Air Tools & Compressors
Central Pneumatic 2 hp 8 gal compressor won't build pressure just sounds like leaking all the time where do i start to look for problem
if it is leaking air the check valve is bad.find the airline leaving the air pump follow this line to tank.this line attaches to the check valve which is screwed into tank.make sure no pressure is in tank when removing.
May 18, 2010 | Air Tools & Compressors
Air Tools & Compressors Logo
802 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
