Question about Extreme Networks Summit 24e2 Networking Switch
Vlan trunk on summit 24e2
I have cico 2811 router with dot1q subinterface (router on stick ). How should I configure 24e2 switch as the uplink port. Where I can configure port as a trunk port or as an access port?
    Problem Solver:
  • 19 Answers
Extreme uses tagged and I untagged instead of trunk/access, so it would look like this for a trunk:
conf vlan test add port gi1 tagged
(and of course you could put other VLAN's on this same port too since it's a trunk)
conf vlan user1 add port gi1 tagged
and this for handoff:
conf vlan lam test add port fa1 untagged
Posted on Jan 30, 2014
How Do I Restore the Default VLAN Configuration of an Interface?
We can take S5700-28P-PWR-LI-AC as example.
The default VLAN configuration of an interface involves the default VLAN of the interface and the VLAN that the interface joins. By default, the default VLAN configuration of an interface is as follows:
Access: The default VLAN is VLAN 1, and an access interface joins VLAN 1 in untagged mode.
Trunk: The default VLAN is VLAN 1, and a trunk interface joins VLAN 1 to VLAN 4094 in tagged mode. That is, a trunk interface allows all VLANs.
Hybrid: The default VLAN is VLAN 1, and a hybrid interface joins VLAN 1 in untagged mode.
Dot1q-tunnel: The default VLAN is VLAN 1, and an dot1q-tunnel interface joins VLAN .1
Negotiation-auto or Negotiation-desirable: If the interface is negotiated as an access interface, the default VLAN configuration of the interface is the same as that of the access interface. If the interface is negotiated as a trunk interface, the default VLAN is VLAN 1 and the interface joins VLANs 1 to 4094 in tagged mode. That is, the interface allows all VLANs.
Run the display this include-default ' include link-type command in the interface view to check the link type of the interface, and then perform one of the following configurations to restore the default configuration of the interface.
Restore the default VLAN configuration of an access or dot1q-tunnel interface.
<HUAWEI> system-view
[HUAWEI] interface gigabitethernet 0/0/1
[HUAWEI-GigabitEthernet0/0/1] undo port default vlan
Restore the default VLAN configuration of a trunk interface.
[HUAWEI-GigabitEthernet0/0/1] undo port trunk pvid vlan
[HUAWEI-GigabitEthernet0/0/1] undo port trunk allow-pass vlan all
[HUAWEI-GigabitEthernet0/0/1] port trunk allow-pass vlan 1
Restore the default VLAN configuration of a hybrid interface.
[HUAWEI-GigabitEthernet0/0/1] undo port hybrid pvid vlan
[HUAWEI-GigabitEthernet0/0/1] undo port hybrid vlan all
[HUAWEI-GigabitEthernet0/0/1] port hybrid untagged vlan 1
Restore the default VLAN configuration of the Negotiation-auto or Negotiation-desirable interface.
[HUAWEI-GigabitEthernet0/0/1] port trunk allow-pass vlan all
Jun 28, 2016 | Compex PS2216 16Port 10100Mbps Smart...
Does the Switch Support QinQ?
· The S2700EI supports only basic QinQ configured using the port link-type dot1q-tunnel command, and does not support selective QinQ configured using the port vlan-stacking vlan command.
· The S2700SI does not support basic QinQ or selective QinQ.
· Other models support both basic QinQ and selective QinQ.
Jun 01, 2016 | Huawei Computers & Internet
How to config vlan on switch 3cdsg8 and a router draytek 2920
You can configure trunks TRUNKS > Configuratio
n.
You can configure port to be part of that truck via TRUNKS > Members
Jun 16, 2014 | Draytek Computers & Internet
Hello, I have a Linksys SRW2016 and 2048 switches with one cisco 1800 series router. I have successfully created two vlans on one switch and when i try to connect a trunk port to cisco router it...
Make sure that the frame encapsulation is set on the router to 802.1q on each of the sub-interfaces. You could also try fixing the speed and duplex on both the router and the switch in case there is a problem negotiating the speed and duplex.
Hope that helps!
Oct 04, 2010 | Linksys SRW2016 (745883562435) 16x1000...
Hi,this is pavan i want to b configure the HP procurve 2626 J4900B managed switch pls help me through anybody by giving the programme to configure it
What do you need it configured to support? Multiple subnets? VoIP support?
Here's an example to support 2 subnets, VLAN 1 Data and VLAN 2 Voice. This switch is the VLAN router for the site and it is also the default gateway for all the devices on the network.
show running-config
Running configuration:
; J4899A Configuration Editor; Created on release #H.10.50
hostname "HP 2650 dot 11 layer 3"
snmp-server contact "Your contact info here"
snmp-server location "Server Rack - Upper Switch"
time timezone -5
time daylight-time-rule Continental-US-and-Canada
interface 49
name "Uplink to HP2650 port 49 - 192.168.105.12"
flow-control
exit
interface 50
name "Uplink to HP2650 port 49 - 192.168.105.13"
flow-control
exit
ip routing
timesync sntp
snmp-server community "public" Unrestricted
vlan 1
name "Data"
untagged 1-46
ip address 192.168.105.11 255.255.255.0
ip helper-address 10.50.3.2
tagged 49-50
no untagged 47-48
exit
vlan 2
name "Voice"
untagged 47-48
ip address 10.50.3.11 255.255.255.0
tagged 1-46,49-50
exit
ip route 0.0.0.0 0.0.0.0 192.168.105.1
spanning-tree Always turn on Spanning Tree
spanning-tree priority 0 This switch is the master Spanning Tree operator.
password manager
password operator
Sep 20, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
How to create subinterfaces on a 3845 series cisco router? I am trying to setup a trunk port for VLAN configuration. Thanks
Its like router on stick configuration??enter the interface which you have to configure and in that interface as mentioned below
Hostname(config)#interface FastEthernet0/1
Hostname(config-if)#no ip address
Hostname(config-if)#no shutdown
Hostname(config)#interface FastEthernet0/1.1
Hostname(config-if)#encapsulation dot1Q 1 native
Hostname(config-if)#ip address x.x.y.y < subnet mask >
interface FastEthernet0/1.2
Hostname(config-if)#encapsulation dot1Q 2
Apr 09, 2010 | Cisco 3845 Integrated Services Router...
How to create vlan in nortol 3510 L3 switch
You would need to trunk the VLANS to the router and create sub
interfaces and then, create access lists applied to
the interfaces to control inter vlan communication. I hope this helps,
Router interfaces something like this, may not work on all versions of
IOS:
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.1
description VLAN1_Servers
ip address 192.168.1.1 255.255.255.0
interface FastEthernet0/0.2
description VLAN2_QA
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0.3
description VLAN3_DEV
encapsulation dot1Q 3
ip address 192.168.3.1 255.255.255.0
interface FastEthernet0/0.4
description VLAN4_FIN
encapsulation dot1Q 4
ip address 192.168.4.1 255.255.255.0
Aug 01, 2009 | Nortel Enet Routing Switch 3510-24T Incl...
IP Addressing by dhcp for vlans
tell each vlan about DHCP server using
ip helper <DHCP servers ip adddress>.
in config mode.
Mar 03, 2009 | Cisco Catalyst 2950 24x10/100 Mbps...
Routing
show ip int brief This will show you the available interfaces and type.If you want to create on Fa0/0 for example the config will be as follows:
On configuration mode type
Interface fa0/0.[vlan Id]
encapsulation isl | dot1q [Vlan id]
Assuming you are using dot1q and terminating vlan 200 The config is as follows
int fa0/0.200
encapsulation dot1q 200
ip address --------
on Gig Port
Int gi0/0.200
ip address
The encapsulation used should match the switch trunk.Default encapsulation is isl on cisco switch.If you are connecting another vendor use dot1q encapsulation.
Dec 27, 2007 | Cisco 2501 Router
Extreme Networks Summit 24e2 Networking Switch Logo
168 people viewed this question
Top Extreme Networks Computers & Internet Experts
David Payne
David Payne
Are you an Extreme Networks Computer and Internet Expert? Answer questions, earn points and help others
