Question about Gateway Computers & Internet
Trouble shoot gateway NV77H19u
Computer shut down-pressing on button does not turn it on-only receive flashing (3) lite then stops. Hit switch again (3) flashes then off. Will not turn on?????-------Paul
c_robertson
  • 123 Answers
SOURCE: i have a gateway ma7 laptop and press power and get nothing
When the computer is off, unplug the power cord from the laptop and then plug it back in. See if the charge light (lightning bolt symbol next to the led) comes on or turns green/blue. If it doesn't your power supply may not be working, even if the light on the supply is on. Second is the battery may be damaged. Remove the battery and see if you can power on at all.
If it boots with only the cord, the battery is bad/shorted forcing shutdown.
Posted on Apr 29, 2009
Damilare
  • 358 Answers
SOURCE: LG x110 laptop power supply problem:
To be very sure of what the problem is, try to test the your laptop with a another friend's battery, or through a technician first. If it powers, then try and test the laptop again with another AC Adapter, from someone who uses the same type, or a technician.
Trying out these two things will give you a clearer and better idea of what might have gone wrong.
Hope it helps you out.
Posted on Jul 13, 2009
  • 5 Answers
SOURCE: m-series gateway (m1629) press start button, nothing
Taken apart, looking for abnormal solder etc checked powers switches decided that this unit was acting like it may have shut down due to excessive heat issue. pulled battery on board, tested ok, re-installed everything and found that this unit now is active. Conclusion: I suspect the bios shut this unit down, hard reset correct this issue.
Posted on Aug 25, 2009
Testimonial: "this fixed the unit thanks."
SOURCE: hp pavillion dv7 won't power on
Same issue - solved by disconencting everything (main battery, CMOS battery, RAM, hard disk and wireless card). Held in power button for 20 seconds (HP say this removes any electostatic charge on the main board). Reconnected everything and machine booted to Windows. Ran HP's onboard diagnostics and everything checked out OK.
Posted on Feb 08, 2010
parrotheadpc
  • 2600 Answers
SOURCE: acer aspire 7520g will not boot
Your reflowing of the mobo did the troubleshooting for you. Your mobo is bad and most likely needs to be professionally reflowed. The problem with the ACER in particular is not knowing exactly what chip is the bad one. I know for instance the chip on an HP board is usually the Nvidia chip which does many things for that system. The blanket trick works more as a diagnostic tool than actually fixing the board for good. You are probably in a position to either reflow your board or replace the thing. Good luck
Posted on Jun 14, 2010
How do I trouble shoot my HT-e320? The problem is, when ever you turn it on, a word "prot" is appearing and it will shut off
Your receiver in PROTECT mode has been shut down most likely to DC Offset(a damaged amplifier) That damage will have to be repaired before the unit can be reset. The repair is major, and certainly not a DIY project. If you would like more assistance, or would like to inquire about repairing your receiver, please visit my website at audioserviceclinic.co. You may contact me there, Thank you.
Dec 20, 2014 | Audio Players & Recorders
Mitsubishi hc3000 wont start
this is a problem in your power board.
thi unit is getting OFF due to heating problem
Jun 29, 2008 | Mitsubishi Office Equipment & Supplies
Does the gateway NV77H19u have an camera already installed on the computer
yes there is, it is HD and is top center above the screen.
Feb 25, 2013 | Gateway NV77H19U Laptops
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
I had my gateway fx laptop running this morning and shut it down at around 7 am. When I turned it on it loads to the log in screen but I can't type or use the touchpad at all. Help
Press and hold-down the ON/OFF button, until it shuts off. Restart it, and see if it was an "intermittent" or "once-only" problem.
If you still have the problem, take the computer to a qualified technician, for professional trouble-shooting.
Apr 05, 2010 | Gateway 2520915 Keyboard
Slow flashing blue power lite. Monitor shows no
First when you power up the computer press F8 key then enter in enable vga mode.
If you are able to enter then go to start menu->control panel->display property ->settings.
Change screen resolution to 1024*768 then apply and ok.
But if you are not able to see safe mode and other menu.
Then open cpu cabinet .
Refix RAM memory.
Pull cmos cell from motherboard for 10 minutes.
Reattach all connection harddrive.
Open processor fan and processor remove dust from all parts.
Make sure motherboard is not ground with cabinet.
Remove PCI cards if any.
After all above still same then change RAM then try.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Gateway DX4640-UBC01A PC Desktop
M-series gateway (m1629) press start button, nothing
Aug 24, 2009 | Gateway Computers & Internet
Mits-WS-65712 Powers on for 3 seconds and shuts off
If you press the Input Button and Menu Button at the same time, you should see a LED flash a once or twice then pause then flash a couple more times. This is the Error Code. If you do this, it would help me determine where the problem is.
Jul 23, 2009 | Televison & Video
Infrared mouse Mod:MG0570T just stopped working 1 day. I've lost the paper work that came with it so I need help trouble shooting to solve the problem.
my mouse get lost on regularly. First press button on receiver (device plugged inot USB port) the blue led should flash slowly looking for devices. next press connect button on the bottom of mouse. it should connect and start working. If not, unplug receiver, re-plug and try again.
Mar 30, 2009 | Acer Computers & Internet
Computers & Internet Logo
89 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
