Question about Suzuki Home Digital Piano Dark Rosewood (r21)
Trouble shoot suzuski hp9 88keys
Lights all on no sound
    Genius:
  • 1,212 Answers
Do you get sound through the headphones? If so, the jack interupt contact may be dirty or corroded. Some contact cleaner should help clean it up, then it is merely a matter of plugging and unplugging several times to make the contact for the speakers.
Other possibilities, the source is not set right, the volume is off, or muted, the "voice" ahs not been selected.- inother words a knob set wrong, or button pushed or not pushed. I am betting you checked those first thing, but should someone else reading this in the future read it, it might be something they have overlooked..
Posted on Feb 15, 2012
Why no audio output?
shouldve checked it b4 you bought it
Jul 02, 2015 | Music
Hi, I have a Mackie vlz3 mixer. Last night I turned everything on and it was all distorted. I did some trouble shooting. It is definitely the board. Can you help. Ted
sounds like it could be dust or moisture ...Try cleaning the board and knobs and faders. this may help it may make it worse. Also while at it...check all connections...especially from board to amps. or to outboard gear. Could be a bad chord
Feb 22, 2015 | Mackie 1604 Vlz3 16 Channel Mixer
My Casio CDP-220R is loosing the fine tune when playing chords they sound out of Sync. How can this be fixed.
Normaly this can be a battery problem or the capacitors are getting worn out
Nov 25, 2014 | Casio Music
The f and b keys after middle C does not make any sound when played. Where can I start trouble shooting?
Without knowing the make and model of the instrument we can't be of much help, although it sounds like a key contact issue. i suggest calling the manufacturer customer service department for help trouble shooting.
Sep 01, 2017 | Music
How to trouble shoot Hofner Icon Series Bass
Hi!
If replacing the jack did't clear it up, and the cable and amp checkout OK, my best guess would be either a solder connection on the pots and switches, or a dirty pot or switch. I'd reflow all solder points and use DeOxit 5 on the pots and switches. Use it sparingly trying to flow it inside the components. Then operate the pots/switches a number of times quickly. Do your best to keep it off the finish. Do not spray it into the pickups.
Good Luck!
May 06, 2014 | Hofner Icon Series Violin Beatle Bass...
How do I remove the electronics (pre-amp) from my Takamine G350 for trouble-shooting?
The process if covered right here:
http://www.takamineguitars.eu/uk/support/preamp-removal-and-installation/
IMHO- the guitar manufacturers are the top of the line when it comes to customer service and online support data.
Apr 01, 2012 | Music
I have a Wurlitzer Funmaker organ that has no sound. Is there a reset or fuse I should be looking for to get this organ working again? I removed the back Panel and need some suggestions the light on the...
Contact Morelock's Organ Service, Rienzi, MS, United States Phone 601-462-7611. Provide them with the complete model number and expect to pay for a service manual if they have one. Start at the end of the power cord and work towards the amplifier section. You will want to establish that the power supply is working correctly. The light is only an indication that the power cord is getting power to the power switch. If the power supply is providing the correct voltages to the other circuit sections of the organ then you will have to trouble shoot each one separately. Check to make sure the speaker is functional. If it has a headphone jack test it also as it may cut the sound to the speaker out if headphones are plugged in. If it is faulty, sound may not get to the headphones or the speaker. You will also need tools. At least a volt/ohm meter.Remember not to work on the circuits with the power on unless you absolutely know how to do this safely. There are lethal voltages in the power supply.
Dec 18, 2010 | Music
Amp doesn't do anything.
If you hear a pop when you turn it on and the squeak when turning off most of your amp is probably working.Depending on whether it is a tube or solid state amp there are several things to consider some being as simple as a deadLED or bulb in the pilot light and a defective input jack to as complicated as a dead power supply to the preamp circuitry. If you are not familiar with safety procedures and electronic trouble shooting and have no test equipment and the schematic you might be better off having it serviced. Here is a link to a troubleshooting guide:http://www.geofex.com/ampdbug/ampdebug.htm A lot of the info can be applied to solid state amps. Hope this helps.
Jan 19, 2010 | Music
I need schmatics for my Chauvet ColorBank 8 stage lighting system
seems as thou the Color Bank 8 stage lighting system is a fixture....what controller are you usein?
Jun 20, 2009 | Music
CASIO CTK-800 turns on but no keys work, and then the power key will not turn it off. I have tried all of the trouble shooting solutions, i have tried different dc adapters, and nothing works. None of the...
That doesn't sound good. It sounds as if the processor is locking up and that might only be fixed by replacing the main board. Sometimes this happens if a unit gets fried by static electricity.
But before giving up, I would open up the unit and check for loose cables and connectors internally. If there are chips (IC's) that are socketed on circuit boards, push them down firmly. Things may start working again.
Apr 16, 2009 | Music
Suzuki Home Digital Piano Dark Rosewood (r21) Logo
88 people viewed this question
Top Suzuki Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Suzuki Music Expert? Answer questions, earn points and help others
