Question about Intermatic T104 24h 208-277v Mechanical Time Switch
T104 intermatic was replaced but will not turn on
Previous t104 timer was not working. Replaced with a new t104 and ran wires the same way but still will not power on.
  • 4 more comments
  • Terri Michaud Feb 14, 2012
    This timer is for an inground pool
    OK update. The timer works now when I turn it on manually. I have attached the on/off trip levers but the problem now is that the timer clock is not rotating.
  • Gene Haynes Feb 08, 2013
    If the timer is new, then your wiring is wrong. If timer worked before, and wired is correct, then Replace WG1573 clock motor:http://waterheatertimer.org/How-to-repla...
    In addition to response above: Look on back of timer mechabnism to make sure clcok motor is WG1573 240volt. Then look at following wiring diagram (wire colors may be different)http://waterheatertimer.org/images/T-104... Then comment back.
  • Terri Michaud Feb 13, 2013
    I checked the wiring as suggested..now the issue is that the devive trips the circuit breaker when it is turned on manually or by the timer. It turns off with no issue and will run once you reset the circuit breaker
  • Gene Haynes Feb 13, 2013
    If device trips circuit breaker, then 1) wiring is wrong or 2) amp draw from load exceeds circuit breaker size. SO: 3) What amp or watt load do you have? 4) What amp circuit breaker do you have?
  • Intermatic Master
  • 5,245 Answers
Your wiring is incorrect -or- wire is not under the screw plate correctly -or- the 240Volt breaker is tripped on one leg.
Make sure that copper wire is under screw plate, and that no insulation is under plate keeping wire from making contact.
Open following link to double-check wiring:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Posted on Jun 16, 2012
SOURCE: I replaced my pool clock ( Intermatic)twice. still
I have the same problem with the t104 clock. wired exactly to the diagram. this is the second one, the first one i thought it was a defective timer so i replaced it with another t104 and also wired it exactly to the diagram and still nothing. am i not doing something right???? line 1 to 1, line 2 to 3.....
Posted on Jun 11, 2010
arealplumber
  • 33 Answers
SOURCE: replacing an old timer with a new gm40.
Here is the instructions for your unit:
Intermatic GM40
Go to page #4 for wiring instructions on 120v dual loads.
Hope this helps and please rate this!
Posted on Dec 09, 2008
  • 12 Answers
SOURCE: A t104 intermatic turns on and off sporadically
Replace the trip levers, I dont think your timer turns off and on without trip levers? Unless your outdoor fixtures have photo cells on them or wired to them! Are they coming on at night and shutting off at Daylight, if so they are connected to a photocell or have internal photocells which means you don't need the timer unless you want to control different on off times.
Posted on Jan 26, 2009
SOURCE: How to wire a intermatic timer T104 240 v to a
T104 is 240volt timer.
Timer has terminals A 1 2 3 4
T-104 clock motor must receive 240Volts to operate.
Clock motor wires are white-colored and can be seen connected to terminals 1 and 3.
http://waterheatertimer.org/images/Back-of-WH40-2b.jpg
There are two work-arounds for using T104 for 120V.
1) Diagram 1 showing how to change wiring:
http://waterheatertimer.org/images/T-104-control-120V-Load-500.jpg
Move 240V clock motor wires to terminal 1 and A.
Connect 240V Hot leads to terminals 1 and A. This will power the 240V clock motor
Hot wire going to 120V load connects to terminal 2. This wire will be turned on each time timer turns on, and 120Volts will power the 120V load.
To complete 120V circuit, neutral wire that comes from neutral busbar in breaker box connects to 120V load.
To control additional 120Volt circuit, run jumper wire from terminal 1 to terminal 3.
Connect Hot to second load to terminal 4.
2) Second method is to change T104 timer into T103 timer:
http://waterheatertimer.org/images/T-104-control-120V-Load-2-5.jpg
Replace T104 240V clock with identical 120V clock motor from Grainger
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
Neutral wires connect to terminal A.
Hot wire from Breaker connects to terminal 1
Hot going to Load connects to terminal 2
Posted on Dec 27, 2010
SOURCE: the t104 comes new in
277V instructions say:
Move small white motor wires to terminals A and 1
Connect 277 Neutral wire to terminal A
Connect 277 Hot to terminal 1
See illustration:
http://waterheatertimer.org/images/T-104-control-120V-Load-277-400.jpg
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 04, 2011
Good morning, problem began when timer stopped working at the pin "off" point. Figured a new timer was in order so replaced with a WG1573-5 (same as previous) Timer is T104. Now the problem, when the timer...
Did you buy new timer or new clock motor?
WG1573 is replacement 240v clock motor for T100 series timer.
T100 series is fully repairable and can be maintained to last decades. I've seen operable timer from 1950s.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
You can convert T104 240Volt timer into 120V timer by changing clock motor to WG1570 to replace WG1573.
In any case, timer is wired wrong somehow since it seems to cut off one leg of the 240V circuit.
Copy following links for illustrations and troubleshoot and more information than you can use in decades:
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
More related information
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/Photos-of-WH40-timer.html#remove-dial
Don't grind up your motor.
Connect direct to hot wires and run 240V.
Add a comment
Gene
h
Aug 22, 2013 | Hardware & Accessories
How to wire a 240 volt salt water chlorinator to an intermatic 1725c timer
T104 and ET1725 are wired differently since ET series timers have dry switching terminals. Dry terminals receive no power when timer is energized. So ET series timers require jumper wire.
Here is crossover wiring:
http://waterheatertimer.org/images/Crossover-wiring-T104-to-ET1725.jpg
More resources:
http://waterheatertimer.org/How-to-wire-Intermatic-ET-series-timer.html
http://waterheatertimer.org/pdf/Intermatic-et1725c.pdf
Add a comment for more information
May 13, 2013 | Intermatic Hardware & Accessories
Hi! Please help me. I am having trouble connecting the wires from my dead 220v T104 pool pump timer to a new 220v T104 timer. The old timer had posts marked G 1 2 3 4. The new one has posts marked L 1 X...
Open following link for T104 wiring diagram:
Your new timer is L 1 X 2, so that is not Intermatic T104.
You might have GE/Tork 15061 that fits into Intermatic box.
http://waterheatertimer.org/GE-timers-and-manuals.html#GE-replacement
First thing to check is if new timer is 240Volts to match old T104.
If new timer is 240V, then here is crossover:
"Old 1" goes to new L >> and notice that L and 1 are connected by brass bridge. If bridge is missing, add a jumper wire between L and 1 on new timer
"Old 2" goes to new 2
"Old 3" goes to new X
"Old 4" goes to new X
T104 Intermatic timer is SPDT single pull double throw, so it turns off both wires going to Load.
New L1X2 timer is SPST single pull single throw, so it turns off one wire going to Load, and that's why old 3 and old 4 both connect to terminal X.
If this is too complex, then add a comment or buy new trippers and a new WG1573 clock motor and repair T104 for $20.
Apr 22, 2011 | Intermatic T104 24h 208-277v Mechanical...
Installing a outdoor timer t104m this is for the pool cleaner,need wireing instruction.next to pool pump timer.
Open following link for wiring diagrams and manual.
240Volt T104 can be wired many different ways.
What is the significance of 'next to the pool pump timer?'
Are you getting power off the 240V pool pump timer to operate the new T104? This is perfectly fine. The pool pump wires would bring power from the breaker box.
Is the new T104 going to control 120Volt lights? The timer can do that, it just has to be wired correctly.
In any case, the T104 has 240Volt (or 277V) clock motor, and clock will not operate with 120V
If you add specific details, I can help with exact wiring diagram for your project.
Apr 18, 2011 | Intermatic Hardware & Accessories
I had a T-104 timer installed on my water heater about 5 or 6 years ago. It is now starting to make a pulsing-type sound, but it does seem to be working okay otherwise. Is it something that could be...
The noise is from clock motor turning the gears.
When timer is new, parts have a bit of white grease on them.
Turn off power and spray WD 40 or apply some white grease.
The other possibility is that WG1573 240Volt clock motor is going bad.
Replace clock motor by tipping mechanism out using thumb spring located top inside box.
Buy clock motor and extra trippers from Granger:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Notice on image below, there is a bit of white grease on lever.
This photo is from new T104.
Feb 22, 2011 | Intermatic T104-20 Indoor Hot Water Timer
The spring that turns off the power in my Intermatic WH21 timer is broken. Where can I buy a new spring?
Parts are not available for WH21 240V water heater timer.
Timer has 1 year limited warranty.
http://www.intermatic.com/customer%20service/frequently%20asked%20questions.aspx
WH21 is rated for 25Amps and works on water heaters up to 4500Watts.
Look at label on side of tank to see wattage.
WH21 is SPST and turns off one hot wire to water heater.
I ran a business for many years.
Cost of stocking, organizing, and shipping parts is near same cost as new timer.
Following page shows selection of replacement timers:
http://waterheatertimer.org/Boxtype.html
For example, I have tested WH40 and T104 and other timers that show on page.
Trippers and motors are available for Intermatic box timers WH40 and T104, so you can maintain these specific models for many years.
WH40 and T104 timers are SPDT and turn off both hot wires to water heater.
Both timers will work on any wattage residential water heater
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
Feb 18, 2011 | Electric Intermatic Wh 21 Water Heater...
Hi expert: I am installing intermatic P1353me digital pool or spa mechanism and having trouble to figure out how to do this heater Firemen Switch connection. My existing pool timer is T104 and there were...
1) Fireman's switch automatically turns off heater few minutes before turning off pump.
Not all pool timers have fireman's switch.
If old timer did not have it, then don't worry about it.
P1353 has wires marked for fireman's switch, so simply don't use them if you don't want to.
http://waterheatertimer.org/pdf/Intermatic-P1353-manual.pdf
page 21 of manual shows wiring for fireman's switch.
2) T104 and P1353 comparison
Difference 1: T104 turns OFF both hot wires, while P1353 turns Off 1 hot wire.
http://waterheatertimer.org/Compare-120-and-240.html
Difference 2: T104 controls 1 240V load with 1 time schedule, while P1353 controls 3 different 240V loads, each with different time schedule.
Check that wire(s) coming from breaker can handle all 3 loads.
http://waterheatertimer.org/Color-codewire.html
3) 240Volt T104 is wired as follows:
http://waterheatertimer.org/images/T-104-240-Volt-400.jpg
Hot1 from breaker connects to T104 terminal 1
Hot2 from breaker connects to T104 terminal 3
There is constant power on terminals 1 and 3, each terminal has 120V when combined makes the 240V circuit.
Load1 wire connects to T104 terminal 2
Load2 wire connects to T104 terminal 4
Terminals 2 and 4 have power whenever timer turns ON
4) Definition:
In electric wiring, Line means power from breaker, and Load means wire going to light,fan, motor, pump.
5) Converting T104 to P1353
http://waterheatertimer.org/images/P1353-timer-350.jpg
http://waterheatertimer.org/images/P1353-terminals-566.jpg
Hot1 from breaker connects to P1353 terminal 1
Hot2 from breaker connects to P1353 terminal 2
This will power timer electronics and timer clock and switches.
Jumper wire is placed from Hot1 at terminal 1 to each Line terminals 3 5 and 7.
This will put power at the switch, and when switch turns ON, then power will flow from Line wires to Load wires and then on to the Load.
Load 1 connects to terminal 4, Load 2 connects to terminal 6, Load 3 connects to terminal 8
To complete each 240V circuit, Hot2 is connected directly to each Load.
6) You say 'salt' system connects to terminals 1 and 3 on T104, then those wires are carrying constant 240V to that device. So Salt system connects to terminals 1 and 2 on P1353
7) Get a second opinion:
I frequently contact Intermatic for various problems.
P1353 is fairly new product, and manual is long, and I might not fully understand your problem or wiring.
Intermatic answers their email.
http://www.intermatic.com/customer%20service.aspx
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 28, 2011 | Intermatic Digital 3-Circuit Timer...
How to wire a intermatic timer T104 240 v to a 120v?
Dec 26, 2010 | Intermatic T104 24h 208-277v Mechanical...
My Intermatic timer is not working. I replaced the WG1573-10D motor but still it does not work. The manual override works so the power supply is ok. Any suggestions welcome.
Your question doesn't provide enough information.
You have 240Volt T104 Intermatic timer?
A) WG1573 is for 240 volt timer. If you have T101 or T103 timer, it takes 125V clock motor.
B) This is new installation? and clock motor only worked when override was ON, so you bought new clock motor. But actual problem is that wires from Load and Breaker are reversed.
C) Your timer worked fine in past years, but dial stopped rotating so you bought new clock motor?
You replaced clock motor.
Manual override works.
--And then your information ends.
Does clock motor work? Does the dial turn? Are your on-off trippers on the dial?
Are tripper worn down?
Buy new trippers.
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
If clock motor does not work, and circuit is 240Volts, then I suspect you connected clock motor to wrong terminals>? Clock motor connects to terminals 1 and 3.
Add a comment and fill in details so we can properly troubleshoot.
Dec 04, 2010 | RTO Intermatic Inc Wg1573-10d Replacement...
Intermatic T104 24h 208-277v Mechanical Time Switch Logo
217 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Craig Butler
Craig Butler
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
