Question about JVC AM FM CD DET FACE CAR STEREO
Speakers dont work
Stoped working took it out of my truck becuase speakers wernt working tested in my car still nothing
THE PROBLEM is that being in atruck the vibration are greater and things move in time and as this has hapend its quite possible its shorted on the speakers and blow the audio chip so if that is the case just buy an amp and conect that and fix the problem a lot cheaper
Posted on Oct 25, 2008
Rear speakers on my 02 chevy Malibu not working don't know why iv tryed everything when I bought the car it worked and then out of nowhere it stoped working
If the radio fader is adjusted fully to the rear and there is no sound the speakers and wiring should be tested.
Best way of testing is to remove the radio to access the wiring to the speakers. Identify the pairs of wires to the rear speakers and apply a 9 volt battery to each pair. If the speakers and wiring are good they will make some noise and the fault will be either the connection to the radio or the radio is defective.
If no noise is heard when applying the voltage, the rear speakers should be accessed, disconnected and tested in the same way. If you have noise it is the wiring at fault. If no noise the speakers are faulty.
The result of testing can be verified at every stage by using a known good speaker and a couple of micro jumper cables.
Feb 25, 2017 | 2002 Chevrolet Malibu
The back pasenger electric window of my 2006 dodge ram 3500 deisel wont go up.both the switch on the door and the switch on the driver control door dont work. checked the fuse box but found nothing labeled...
hi, there is a relay for the windows. in the fusebox (s) there should be a relay for each window. these relays do fail (open circuit on switch side). the feed POWER side may be shorted. these circuits are hard to find the fault, but check all the door relays. the motor can stick and put heavy current to blow the fuse, if you leave the engine OFF and put the ignition ON press the other window and listen for this relay noise. a click can be heard to pinpoint the location of other relays. once you find these switch relays to determin if these are working and use this to put the rear window back up. gerry
Sep 13, 2010 | 2006 Dodge Ram 3500 Truck
Car front two speakers arent working. rear two are.
have the front speakers ever worked?
if not have they been connected properly?
if yes then
look under ballance and check theat rear and front ballance is in the middle
if it is then for temporarily replace the front speaker with any old speaker
if that works then you need new front speakers
if no then the radio is broken
but what you could do is rewire the back speakers so they also play though the front ones too
this can be done from behind the radio
find the rear right positive and negative wires
strip the insulation but dont cut the copper wire
cut the front right speaker and attach that to the rear speaker wire
do this for both positive and negative
rear right
positive
..v
..v
I...I
I...I
I...I
.I.I..........< strip cable but do not cut metal
.I.I..______________
.I.I=_______________ <<<front right positive
.I.I
I...I
I...I
I...I
I...I
Jan 06, 2010 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
1996 sububan speakers not working
make sure the wire to the speaker are still connectied and see if the connection is broke you might have it hook up but if its broke its not making contact
May 18, 2009 | 1996 Chevrolet Suburban
My subs heve stoped morking and i dont know why!
try check that you have connected the positive to the positive from sub 2 amp.if that dosent work try gt new rca leads
Dec 13, 2008 | Car Audio & Video
JVC AM FM CD DET FACE CAR STEREO Logo
42 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
