Cameras Logo
Posted on Oct 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pictures are in the camera but not on the sd/mmc card
Anonymous
Level 3:
  • Master 903 Answers
  • Posted on Oct 25, 2008
Anonymous
Master
Level 3:
Answers
903
Questions
6
Helped
322574
Points
2524
The pictures have been saved to the cameras memory instead. Check that the card is not locked. if it is then you can't save to it. Unlock the card and then try
2answers
Why has my camera stopped working on picture transfer
I use an SD card reader. Found one at Staples for about $20. It connects through USB.
What size memory card for a 5mp
The Z740 works with MMC and SD cards. MMC cards are all but extinct, but SD cards up to 2GB in size are still plentiful. You should be able to buy them at just about any department, electronics, or office-supply store. Just make sure you get SD cards, not SDHC or SDXC cards.
The camera will work with all size SD cards. Obviously, the bigger the card the more pictures it can hold. Also, the bigger the card the more pictures you risk if you lose or break the card.
One school of thought says get the biggest card you can and then be very careful with it. Another school of thought says get two or more smaller cards and spread the risk.
What memory card do I buy for my Kodak easyshare C530 camera.l The one I purchased was a SD card and it would not allow me to format.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7551/7269&pq-locale=en_US&expression=sd
The above link goes to a site that describes how SD or SDHC cards can be used in newer C cameras such as yours.
Also, the following should be noted regarding sd cards:
Question : Why doesn't my camera recognize the SECURE DIGITAL (SD) or MultiMedia (MMC) memory card that is in the camera? Answer : Your camera may not recognize the memory card inside for one of the following reasons:
  • The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
  • The card may be corrupted. Reformat the memory card.
    CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
  • The card may not be a certified SD or MMC card. Purchase a certified SD or MMC memory card.
See your camera's user manuals for more information. Go to KODAK Product Manuals, and select the manuals you need.
Doesn't recognize memory card. I had an Eye Fi wireless memory card installed and now it's totally blank and the camera doesn't recognize it. Tried a regular SD memory card, and the camera doesn't...
Your camera is only supporting SD/MMC Cards (up to 2 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
I keep getting the error msg memory card cannont be read
Your camera is only supporting: SD/MMC up to 1 Gigabyte
The card that you currently have might be high speed. All should be sorted if you change the SD card to the supported MMC SD card up to 1G. There is a lever on the SD card this one might need to be changed.
I just bought a new memory card and tried to format it and I get an error message filesys 001 I think. Bev Caproitti [email protected]
Your camera is only supporting SD/MMC Cards (up to 1GB)
2helpful
2answers
I have a new memory card. I cant get pictures
Your camera is only supporting SD/MMC Cards (up to 1 GB)
2helpful
I'm missing the camera card. How do I get a
This 5MP (Megapixel) camera has 16MB built-in memory and has an SD card slot.
Your camera uses either MMC of SD memory cards.
Radio Shack, BestBuy, Fry's, Office Depot, Office Max, has them.
Start with a 1GB SD card (Don't use MMC).
A 1GB card will hold almost 500 pictures at maximum resolution (5MP).
(Fry's is lowest cost, then Best Buy)
I have a canon A530 digital camera and its mode switch on the right top corner has broken and is lost and we cannot download photos to our computer, etc
To download the pictures, remove the SD/MMC card from the camera (in the battery compartment) by pushing on it, then releasing it, and putting it in an SD/MMC card reader connected to your computer.
Camera doesnt recognize a Secure Digitalor MultiMediamemory card?
The cause and solution may include one of the following: The card may not be certified SD or MMC. Purchase a certified SD or MMC memory card. The card may be corrupt. Reformat the memory card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
