Question about Sony Handycam DCR-HC42E Mini DV Digital Camcorder
The cassette holder isn't closing......and the tape is not loading
I m having double problems.the cassette holder of my camcorder isnt closing....i mean not gettin in the place.ven i load the cassette .....it doesnt get inside the handy cam as it used to b4. my camcorder jus keeps on flashing-''re-attach the power source''.i jus don get wat the hell it means.plzzzzz help me at ur earliest.
  • johnginty Jan 11, 2009
    Sony handycam  PC55E
    Tape will not load, cannot shut case.
Not geting in holder tht mean u must open ur casset holder and put in polethin bag for a hour and it will accept tape
Posted on Oct 01, 2007
How do I fix the tape holder system on my camcorder? The door won't lock, and the cassette won't get inside the compartment.
hi,
is it close without a cassette ? if so the reel sensor in the cassette compartment may be faulty. if the head drum not rotates the cassette drive will not work correctly, if so please loosen the head drum with a plastic rod or some tools like that. do not put your finger in hence sometimes will jam your finger. remember don"t touch the scanning chip of the head.
Oct 26, 2015 | Panasonic Palmcorder PV-GS12 Mini DV...
Cancorder not wrking-e007 error message
moisture in the cassette holder. Take out the cassette, leave the holder door open for a couple of hours in a dry, warm location, and it should work again.
Sep 12, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Record problem
There are two things 1.there is a push switch under the cassette holder may be brocken 2.cassette holder is bad.put a cassette and press on cassette holder then try this way you can make sure which part is bad.
Jan 30, 2008 | JVC COMPACT VHS-C CAMCORDER
Hi
See if this works--If you are on battery there may not be enough power .Charge the battery or use the the mains power through the transformer and see if it works.
Hope this helps
Jay
Nov 17, 2007 | Sony DCR-PC55E Mini DV Digital Camcorder
Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Aug 20, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Tape holder of camcorder isnt closing
Jul 19, 2007 | Sony Handycam DCR-HC42E Mini DV Digital...
Can not load any cassette even empty cassette holder can not be closed.
I had the same problem and solved it by removing the battery to allow the camera to reset. Worked fine after that.
Sep 24, 2006 | Sony Handycam CCD-TRV11 8mm Analog...
Will Not Load Cassette
I have the zr850 which I have used less than a dozen times, and it does the same thing as you describe. Was told by canon tech people to try a maxell brand tape and a head cleaner tape. Have not tried their sugestion yet. camera is 3 months old.
Aug 07, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Sony Handycam DCR-HC42E Mini DV Digital Camcorder Logo
411 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
