Compact disc changer SL-MC59
There is a cable and it came loose and I need to know how it should be routed. a picture would be great.
techman
  • 3130 Answers
SOURCE: Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
  • 141 Answers
SOURCE: Disc stuck in cd player
Easy, turn off the power, remove the lid by unsrewing all the screws on the side, back and top of the lid. When removed you should see the CD jammed somewhere at the rear of the disk carrier. be very carefull and slowly remove it. The disk may be already scratched but if you're carefull you can stop further damage. Also don't force any part of the tray they are only plastic. If you can't get the disk out things start to get awkward. Write backmor take the unit with the lid off to a repair shop it shouldn't take them long to get it out.
Posted on Apr 07, 2010
canwoodjc
  • 3301 Answers
SOURCE: Looking for FREE download SL-MC59.
I found the manual for the 60 , if thats any help http://service.us.panasonic.com/OPERMANPDF/SLMC60.PDF I'll keep looking for the 59
Posted on Jul 06, 2011
dunnbiker
  • 8546 Answers
SOURCE: i need to download a users manual for technics
Web search "Technics SL-MC3 manual" and this pops up...
http://www2.panasonic.com/consumer-electronics/support/Audio/Technics-Audio-DJ/Technics-CD-Players/How-To-Guides/model.SL-MC3.H
Please try the search engines first.
Posted on Aug 08, 2011
gopakumarg43
  • 74185 Answers
SOURCE: Technics cd changer sl-mc59 says C F 19 it does
HelloDisc reading is done by the laser pickup assembly. If it has some trouble with it, the lead-in and lead-out signals and other music signals cannot be read from the CD disc we insert into. There are mainly three reasons for this fault. The first one is with dirty laser pickup assembley focussing lens. If the lens has accumulated with dirt or dust, the intensity or laser beam that hits the disc will be weak, and so the reflected beame too. This will lead improper reading of the lead-in signals, and the set will show no-disc after a while. Put a laser head cleaning disc [this disc can be bought from most of the electronic sparepart shops at your town], play it for at least three times, and see whether it helps you.If not, try replacing the flat ribbon plastic cable that connects the laser head assembly to the main board of the player. Actually this is a very skilled work, as you have to dismanle the mechanism out from the set. If these two processes does not help you, repalce the laser pickup assembely with same type and number. OK.
Posted on Dec 21, 2011
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
Missing remote for Technicis Model SL-MC59 Cd changer
You will need to go online to Technics and contact customer support and the technical department to see if they can help.
Apr 05, 2012 | Technics SL-MC4 61-Disc CD Changer
Cds won.t drop down in technics compact disc changer sl-mc59
The gears and leavers go through heavy ware over the years, and is not an easy fix because you are dealing with plastic parts that eventually give out and may need to be replaced, a job for a technician.
Mar 04, 2012 | Audio Players & Recorders
Technics 5 cd changer Model SL PC11 will pick up
This is a problem with the laser assembly which requires service. The laser assembly needs to be replaced as a whole. It is not easy to replace them, but someone with patience, and a knack for mechanical things can do it.
Nov 27, 2009 | Audio Players & Recorders
My techniqs sl eh790 compact disc changer is not opening
My disc changer only let's me put 1 disc in even when I press for another slot to open just don't know how to do it
Dec 02, 2008 | Audio Players & Recorders
Need Manual for Technics SL-PD827
Go to http;//audio.manualsonline.com
Jun 24, 2008 | Technics SL-PD8 5-Disc CD Changer
 Grubhead
Grubhead
