Question about Watches
Manually close power recliner
My power recliner is stuck in lay down position....can i close it manually
Cannot advance date manually when crown is in 1st position on eco citizen ladies watch
Return for warranty repair. They have a 5 year warranty. Your instruction book has details and address to send it in. Send a copy of your receipt also.
Oct 08, 2012 | Watches
Back panel came off and wont go back on
Align the caseback exactly as it was before you opened it. Make sure thet the groove for stem is in correct position. Lay the napkin on the flat table surface, put the watch on it (dial down) and using both hands and your body weight push the caseback down back in place. Remember: the side of the caseback wich first came out must be last pushed in.
Do not use very soft napkin (towel) as this can brake the glass under the pressure.
If all above described DO NOT work, then there is not enough power in your hands or not enough weight in your body and you will need watchmakers help (he/she will be using special watch press to close the watch).
P.S. Do not get upset if you can not close it; I'm very expierenced watchmaker and very often came across the watches wich I was not able to close without the watch press (even my arms are quite strong and the weight is 95kg).
Do not forget to rate, please.
Aug 13, 2009 | Nixon Chalet Bracelet Watch
Timex watch cover
Mar 07, 2009 | Timex 40131 Wristwatch
Timex watch cover replacment
Removing the crown/stem of CASIO EF-321
Other case for a simple Casio quartz watch :
Jan 15, 2009 | Casio Edifice EF106D2AV Wrist Watch
Remove the winding stem/crown.
There is a tiny point (end of small metal piece called setting lever) on the left side of the stem (on watch movement, very close where the stem is entering the movement).
You have to push that point down with a metal pin or tweezers. Crown (winder) must be pushed in to normal position otherwise you will not be able to put the stem back properly.
So, do as follows:
1) Push the crown in,
2) Lay the watch down on flat surface and push on setting lever point,
3) While holding setting lever pushed in- extract the setting lever by gently pulling crown out of watch.
Jan 09, 2009 | Fossil AM3425 Wrist Watch
Unable to manually change date on my Rolex Oyster
Usually to change the date you need to have the crown pulled out to a position that is between the "closed" position and the position where it will move the minute/second hands.
Jan 03, 2009 | Watches
Invicta Speedway 9223 not keeping time
It sounds to me as it is a quartz chronograph and it is right that the centre seconds hand moves only if the pushbutton is pressed. If you look close enough, you will notice that the small subdial finger is ticking and counting seconds. It is recommended to replace battery, as sometimes watches been laying in stores for a few years before selling and the battery is flat or underpowered.
Want to know more about your watch? Go to www.invictawatches.com and find out.
Regards
Arthur
Dec 16, 2008 | Invicta Speedway 9223 Wrist Watch
Watches Logo
143 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
