Question about Nintendo Video Game Consoles & Games
Error code 51099
Connecting ds to wireless
SOURCE: trying to hook up nintendo ds wireless connection,
recieved a error code 051099-1. please advise
Posted on Nov 16, 2009
frankwarrior
  • 54 Answers
SOURCE: I can not connect to wifi. I have a BT hub. error
You need a wireless router from your computer.
Go to search on taskbar and search CMD. Then type IPCONFIG/ALL
you dont need a BT Hub
Posted on Mar 06, 2010
Tom Marvolo
  • 708 Answers
SOURCE: My son has his DS
Click Here to know more about this
Posted on Aug 16, 2010
  • 1234 Answers
SOURCE: my nintando DS gets error code #51099 everytime I
Error Code: 51099 This error code can occur for two different reasons:
  • You are trying to agree to the User Agreement of the Nintendo DSi or Nintendo DSi XL, but are receiving error code 51099. This can occur if the Nintendo DSi or Nintendo DSi XL tries to connect to Nintendo's servers to download the User Agreement, but there is no existing Internet connection setup on the system. To connect your Nintendo DSi or Nintendo DSi XL to the Internet, please click here.
  • You are trying to play a Nintendo DS game online with a Nintendo DSi or Nintendo DSi XL, but your home Internet is set to WPA security. Please read the following:
There appears to be a compatibility issue with the security settings on your router:
Are you using WPA security?
    No, I am using WEP security
If you are using a Nintendo DSi or Nintendo DSi XL, you will be able to connect online and use many online features with WPA security. However, you will not be able to play original Nintendo DS games that are Wi-Fi compatible, as they are only programmed to work with WEP security. In order to play these games online, you will need to do the following (If you are not receiving this error when attempting to connect games online, click here):
  • Change your wireless security to WEP or temporarily disable wireless security if you wish to connect to the Nintendo Wi-Fi Connection.
  • If you are unable to log into your router or do not know how, you can check our router look-up page (link) to see if it is listed. If your model number is not listed, check any similar models from the same manufacturer for default information. If you are still unable to log into your router, please refer to the router manufacturer or the company that provided it.
  • Make sure your router is not on our list of incompatible routers. If it is, we recommended using a router that is compatible or co nnecting from a hotspot location.
  • The wireless security settings are typically found under sections labeled 'Wireless', 'Basic Wireless' or 'Wireless Security'.
  • Change the security mode to WEP, and chose your encryption type. The 64-bit encryption type typically uses a 10 character key while the 128-bit encryption type uses a 26 character key. Hexadecimal keys consist of letters A-F and 0-9, whereas ASCII keys have no limitations and are case sensitive. Be sure to use the key that is listed in 'key slot 1' and make sure you are not using a 'passphrase'. For specific information about changing your security type please see your router's manual or contact the manufacturer.
  • Important Note: it is recommended that any changes made to the router are performed from a computer that is wired via Ethernet cable to the router. In addition, any changes made to wireless security must also be adjusted on other wireless devices in the home that use the router (e.g. laptops, other game systems, etc). For instructions on how to change these devices, refer to the user manuals for these devices or contact the manufacturer.
  • Establish a connection in connection files 1-3 on the Nintendo DSi or Nintendo DSi XL. Make sure you are putting the WEP key into the Nintendo DSi exactly as it appears on your router page.
If the error persists while using WEP (or if you are receiving this error with other Wi-Fi features), follow these steps:
  • Keep trying, as there may be a temporary network issue. If the problem persists, or has been consistent over a period of time, move on to the next step.
  • Configure the Nintendo DSi or Nintendo DSi XL manually
      Please note: if your router is set to broadcast the network but the Nintendo DSi or Nintendo DSi XL is not finding the access point then a manual setup will not resolve the error. There may be another problem, such as interference, or a basic setting in your router that is causing compatibility issues. Be sure that your router is set to 'Enable SSID broadcast' or 'Enable Wireless broadcast'. If you prefer to keep your network name hidden, verify the correct spelling and case of your router's SSID.
Posted on Aug 26, 2010
  • 26 Answers
SOURCE: Every time I try to connect to the internet it my
You can only connect to internet if someone is sharing their Wifi. If it is password protected, you won't have any luck. You're best off heading to Starbucks or McDonalds for free Wifi to connect to the internet.
Posted on Jun 18, 2011
Error codes 51099
This code means that your wireless signal is not compatible with your DS. If you are using WPA/WPA2 for securing your wireless internet then you will not be able to use your DS on this signal. I would suggest changing your wireless signals passphrase to WEP so that you will be able to use your DS without any problems
Aug 19, 2011 | Nintendo DS Console
I can't connect to the internet. My DS is giving me Error Code: 51300. What can I do?
According to Nintendo's tech support website, error code 51300 means that the access point you are trying to connect to is not compatible with the Nintendo Wi-Fi connection. Try to find another access point and see if it will work then.
Jun 29, 2011 | Nintendo DS Lite Console
Here is the link from Nintendo explaining the 51099 error code. In the future, please provided more specific information so that we can help you more effectively. I fortunately recognized this as a Nintendo error code. Most people would not have. Simply typing "51099" with no other information generally slows down your response time from experts. You were just fortunate this time that I happened to be online when the question appeared. Thanks in advance!
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51099&system=DS&locale=lang
May 08, 2011 | Nintendo DS Lite Console
Wi fi error code 51099
Error code 51099 implies that your DS cannot connect to the wireless signal. You should check the settings on your DS and the settings on your router.
Here's a detailed and interactive guide for how to do both.
Hope this helps fix your problem!
Mar 24, 2011 | Nintendo DS Lite Console
We have an error code 51099 on the DS. Could you please tell us how to correct this. Thanks
This code is generally attributed to the DS not finding a connection to the internet using Wifi. The DS does not support WPA security. Change the security on your wireless router to WEP or No security.If you donot need the internet on your DS then change the internet wifi off. Another thing is to change the router to b/g or mixed mode. If you are using wireless N only then the DS cannot find and use the wireless network.
Jan 17, 2011 | Computers & Internet
Error code: 51099
error 51099 means internet connection problem
Nov 24, 2010 | Nintendo Video Game Consoles & Games
My nintando DS gets error code #51099 everytime I try to connect to the internet on pokemon soul silver. Do you have any ideas?
Apr 20, 2010 | Nintendo DS Lite Console
I can not connect to wifi. I have a BT hub. error code 51099
Mar 02, 2010 | Nintendo DS Lite Console
Error code 510099
Please double check error code
Error Code: 510099 Specific Error Code Not Found - General Troubleshooting
  • Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
  • Check your router's broadcast settings to find out if it is set to "G", "B", or "Mixed." Mixed typically works best, but try all three to see if it improves the network connection to the Wii console.
  • Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off. Wireless keyboards and mice may also cause interference.
Oct 22, 2009 | Nintendo DS Console
Video Game Consoles & Games Logo
32 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
