Question about Lexmark Office Equipment & Supplies
I have a four in one Lexmark x5630 printer and have replaced cartridges with brand new black and colour 36 & 37xl. The printer won't even print a test page - just says that cartridge error co
I have a four in one Lexmark x5630 printer and have replaced cartridges with brand new black and colour 36 & 37xl. The printer won't even print a test page - just says that cartridge error contact manual?????
  • Official Brand Answer
  • 3,344 Answers
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Try to contact the store where you bought the new cartridge(s) and have them replace it. You may also contact Lexmark Technical Support Center for assistance (especially if you're using genuine cartridges).
Posted on Feb 15, 2012
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: We have a X5650 Lexmark printer. The ink
    It could be that the cartridges are not inserted properly in the carrier or just needs cleaning. Try to remove both cartridges from the printer and manually clean the nozzles. You may refer to this article on How to Clean the Print Cartridge Nozzles and Contacts Manually. Then reinsert one cartridge first and close the cover. If no error appears, reinsert the other cartridge. Replace whichever cartridge is causing the error. You can also try the Clean Cartridge function on the printer by pressing the Setup button -> Maintenance -> Clean Cartridges. It will then print the clean nozzles test page. If error continues, replace the faulty cartridge.
    Posted on Jan 31, 2011
    rcw1962
    • 2571 Answers
    SOURCE: ho do i install my lexmark x5630 printer ?
    Yes it is, i dont know where you looked, but it took me 10 seconds to navigate to the drivers.
    http://support.lexmark.com/index?locale=en&segment=DOWNLOAD&startover=y&userlocale=EN_UK&question=x+5630&productCode=LEXMARK_X5630&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X5630&searchid=1280157230301#2
    Posted on Jul 26, 2010
    nematics
    • 431 Answers
    SOURCE: my printer keeps saying missing cartridge
    is u r catrige original one or fake
    Posted on Mar 29, 2009
    • 159 Answers
    SOURCE: refill lexmark 37xl ink
    I own a Cartridge World ink refilling store and we do not refill the Lexmark 36 and 37. The reason is that your printer turns off the electronics on the cartridge when the ink gets low, so you can't reuse the cartridge. Your printer will only function with an electronically functioning cartridge. We NEVER recommend Lexmark printers. They are poorly made, don't accept refills a lot of the time, and across manufacturer their ink costs the most and is designed to clog the cartridge if you don't use it fast enough. We recommend HP printers that take integrated print head cartridges and Canon printers that take tank style cartridges.
    Posted on Mar 08, 2010
    printmastert
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: at the base of cartridge carrier,on the right-hand
      Hello. Hope you got working already. But if you're still having the problem, unplug the power supply (the small black box behind the printer where the power cord is attached) with the other end still plugged in to a known working power outlet. Look around the black box, it should have a green LED on around the silver contacts. If not, properly secure the power cord by unplugging and plugging it back in. Otherwise, you got a defective power supply. Try not to use extensions or power strips, plug printer straight to the wall power outlet or plug it to a different known working power outlet. If the power supply is working fine, plug it back in the printer in a correct position. Properly insert it and make sure it pushed all the way in the printer. If you're still getting all blinking lights once plugged in, your printer might be damaged by the the lightning strike. If that's the case, you can call Lexmark and ask for assistance with that. Well, these are the troubleshooting steps you can do to determine where the problem is. Good luck!
      Posted on Mar 30, 2010
      Lexmark S405 : printer will not print until the black ink cartridge is replaced
      Smash printer with axe or sledgehammer. Grin maniacally. After researching on internet,go out & buy new printer that allows you to print till empty & refill again! Obviously not a Lexmark...
      Jul 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
      My black ink all of a sudden won't print and I get an error message that says remove tape from cartridge...there is no tape...it is a Lexmark 6150
      If the problem continues even after re-seating the black cartridge and cleaning its nozzles, then it could be a faulty cartridge issue. Replace it with a new genuine Lexmark cartridge.
      Aug 23, 2011 | Lexmark X6150 All-In-One InkJet Printer
      I have inserted a new black ink cartridge (34) and get an error message 'left cartridge missing, insert black or colour photo cartridge' have peeled label off and reinserted several times but still...
      Make sure you are inserting a genuine Lexmark cartridge. Try to insert a different known working cartridge, maybe your old black cartridge, to determine if your new cartridge is faulty. If inserting your old black cartridge gives you a message saying "very low ink" or something to that effect, then most probably there's something wrong with the new black cartridge. Have it replaced with a new one from the store where you bought it from. You may also contact Lexmark Technical Support Center for assistance.
      Aug 12, 2011 | Lexmark X8350 All-In-One InkJet Printer
      We have a X5650 Lexmark printer. The ink cartridges were both replaced with certified cartridges (parts 36 and 37xl) . When installed the printer does not recognize that the cartridges have ink and...
      Jan 20, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
      Lexmark X5630 indicates refill black and color cartiridge
      Is your ink still comming out of the cartridge? if soo than the person who has refilled it hasn';t done it carefulkly and might have damaged it.
      I should suggest you to buy a new one......
      Apr 28, 2010 | Lexmark X3650 Printer
      Refill lexmark 37xl ink
      Mar 01, 2010 | Lexmark X4650 InkJet Printer
      Refilling cartridges
      For that printer: there are 4 color and 4 black cartridges BESIDES the #31 photo cartridge. Lexmark has made it so you MUST either, throw away or send to them, the 36 and 37, the 36XL and 37XL. The printer will never again recognize them after they are removed from the printer...
      However, the 36XLA and 37XLA AND the 36A and 37A as well as the 31 Photo may be removed from the printer, refilled, and reinstalled.
      I have seen some forums that say you can but a piece of BLACK tape, across the bottom row of contacts on the non-refillable cartridges....I believe there are 4 to 7 contacts across the bottom row only.....and the printer will still give you a message that it needs ink.....but it WILL print. I have not tested this theory yet though. I have just gotten the first message saying my black ink is very low.
      Hope this helps and I think Lexmark Corporation Sucks for tricking people like this. (This printer comes with the NON refillable cartridges as default, but I did NOT see in the documentation that it couldn't be refilled. Nasty people........:(
      Good Luck~~! mstipps@yahoo.com
      Jun 01, 2009 | Lexmark X3650 Printer
      Reset Lexmark 36 Black cartridge?
      I managed to get it working, just damage the connection point (where the chip is). I used a knife to break part of the connection and now I can fill the cartridges myself for a fraction of the price :)
      Mar 05, 2009 | Lexmark X4650 InkJet Printer
      604 people viewed this question
      Top Lexmark Office Equipment & Supplies Experts
      Roopesh S
      Roopesh S
      Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
