Question about HP Office Equipment & Supplies
49.4C18 Service Error
Color Laser Jet 3800
Joed911
  • 4338 Answers
SOURCE: My HP color laser jet
This is what HP says about error 49:
Control Panel Message:
49.XX.XX
PRINTER ERROR
To continue
turn off then on
Description:
A critical firmware error has occurred that
caused the processor on the formatter to
abort operation. This type of error can be
caused by invalid print commands, corrupt
data, or invalid operations. In some cases,
electrical noise in the cable can corrupt
data during transmission to the printer.
Other causes include poor-quality parallel
cables, poor-connections, or home-grown
programs. On rare occasions, the formatter
is at fault, which is usually indicated by a 79 Service Error.
Recommended Action:
1. Turn the printer off then on.
2. Press Stop to clear the print job from
the printer memory.
3. Turn the printer off then on.
4. Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file. If the message
displays only with a certain software
program or print job, contact the
software vendor for assistance.
5. If the message persists with different
software programs and print jobs,
disconnect all of the cables to the
printer that connect it to the network or
computer.
6. Turn the printer off.
7. Remove all memory DIMMs or thirdparty
DIMMs from the printer. (Do not
remove the firmware DIMM.)
8. Remove all EIO devices from the
printer.
9. Turn the printer on.
10. If the error no longer exists, install
each DIMM and EIO device one at a
time, making sure to turn the printer
off and on again as you install each
device.
11. Replace a DIMM or EIO device if you
determine that it causes the error.
12. Remember to reconnect all of the
cables that connect the printer to the
network or computer.
13. If the error persists, upgrade the
firmware compact flash card.
14. Replace the formatter and calibrate
the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 11, 2008
leroyal
  • 2120 Answers
SOURCE: Color Laser Jet 3800 leaving roller marks on paper
Pull out the fuser at the rear of the machine.
Posted on Feb 07, 2009
SOURCE: HP LASER JET ERROR 49
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3377075&prodTypeId=18972&prodSeriesId=3377075&objectID=c01571503
Posted on Jun 23, 2009
  • 39 Answers
SOURCE: my HP color Laser Jet 3000/3600/3800 is sqeaking
You need to clean the carriage ride path for the cartridge.
Posted on Aug 12, 2009
SOURCE: Our HP Color Laser Jet Printer keeps saying 50.2
I had a similar problem. make sure the fuser is the same voltage as the printer. 110v printer needs a 110v fuser. easy way to tell. White barcode sticker it is a 110v. Red or Pink then it is a 220v.
Posted on Aug 27, 2009
Hp color laser jet 5550dn shows error code 10.10.02 supply memory error
This error codes indicates that one of the toner cartridges you have installed does not contain a valid chip on it. If you recently changed a cartridge that is the likely culprit.
Feb 28, 2015 | HP Color LaserJet 5550dn Q3715A Workgroup...
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
Hp lazer jet 2600N won't print red color what will fix it. Has a new cartridge
You may need to replace FORMATTER BOARD & DC CONTROLER BOARD ASSY which are located behind the printer. Both BOARDs are side by side together. Just open the back cover, you will see it.
Jun 10, 2010 | HP Color LaserJet 2600n Printer
HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Oct 12, 2009 | HP Color LaserJet CP4005dn Network Printer
My HP color Laser Jet 3000/3600/3800 is sqeaking
Aug 12, 2009 | Office Equipment & Supplies
Feb 07, 2009 | HP Color LaserJet 3500 Printer
271 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
