Question about Smeg DO81CSS Electric Double Oven
Main oven is cooking unevenly, one side of oven hotter than other (tested with thermometer)
Have already had fan element replaced a few months ago, is there any side elements that could fail?
4 Suggested Answers
  • 1462 Answers
SOURCE: Hotpoint oven heating element
check stat not open circuit and check selector switch not damaged
Posted on Oct 18, 2008
barkencoa
  • 3463 Answers
SOURCE: How do I fit the main heating element in a De Detrich oven
If it is fan assisted then remove the inner rear panel of the oven there you will see the element, disconnect and replace.
If there is no removable panel, then you will have to remove the oven from the housing, and do it from the rear of the oven.
Plz rate my solution.
Thanks.
Posted on Jan 02, 2009
  • 69 Answers
SOURCE: It would appear that the main oven element is not working
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Posted on Aug 10, 2009
Oven want heat up
Replacement elements may have failed
Jan 27, 2018 | Ovens
My oven does not heat up when in fan oven mode, the inner element does not get hot, the outer element does, Both elements get hot when using the main oven full width grill. ...
From your descritpion and if you already replace elements there are two options.
One is that there is an open curcuit either by a loose contact from selector switch to the elements this can be check with a mutlimeter.
The second option the selector switch itself is mulfuction and this normal after long time use since it consist with power contacts they fail to conect after long and you will need to replace it. If your familiar with electric then you can check it with power on and multimeter to see if it conects the elements or not. This operation need extra extra safety and experience.
We have here one side just to see what part you need the cooker selector multifaction switch
Aug 25, 2011 | AEG D5701-4 Electric Double Oven
I have a 'Simpson 2001 Thermaflow Oven' and a few months ago, i was heating it up, and i heard a pop, from then on my oven has not heated up, i cannot seem to find what is wrong with it!! Please...
I would say that the oven element has blown. It is common especially if you have a fan forced model. Make sure the fan works before you go buying a new element as the replacement will fail early. Simpson ovens have to be removed from the wall cavity to replace the fan and the element. Make sure you tuen the power off before doing anything...
Give the parts supplier your model number so that you get the fight element ( and fan) if necessary.
Jul 31, 2011 | Ovens
Bosch built in double oven: had new element fitted to main fan oven, but now oven keeps on getting hotter does not stop heating up when right temp reached.
This type of problem normally can be ascribed to a defective thermostat. Unfortunately there is no test for a thermostat, it has to be replaced to see if the problem has been sorted out.
One thing you can do is remove the thermostat bulb from the oven and place place it in a position where it will not heat up. Place an oven thermometer in the oven. Switch on and see of the temperature climbs above what you wee seeing before. This is a very much hands on test as you have no control over the temperature that the elements can get to. As soon as you see the temperature reach a point above that seen before, shut down immediately.
Mar 27, 2011 | Bosch Ovens
I have a diplomat fan oven. I repalced the fan element about six months ago. everything worked fine, however in the past couple of weeks the motor has been running slowly and erratically. now something has...
Sounds like the fan motor has failed altogether, and as a result the oven element has probably blown again due to overheating of the element.A ew fan and element is more than likely going to be needed to correct the problem.
Dec 16, 2010 | Ovens
Bake element does not work during convection cooking
Hello and welcome to Fixya.
I hadn't seen your post prior to today, so perhaps you've had a remedy presented to you already.
If you have not, reply to this post and I can recommend a few test to perform that will determine the issue with your oven.
Off the top it sounds like a possible faulty convection heating element or the K3 relay on the board is defective.
I'll watch for your reply.
Thank's,
macmarkus :)
Jun 07, 2010 | Thermador SC302T Electric Double Oven
Hotter on one side of the oven in my kenmore oven 79095302102
Yes the element is not working properly and basically one side is burnt out...this is causing the problems you are having.
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 22, 2010 | Ovens
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
Electric oven tripped my electricity a day ago and now the fan oven just blows out cold air
It is most likely that the oven heating element has failed. You will need to have it replaced
Normally the heating element is located around the circumference of the fan assembly and when it is working it glows red. You would see it if it was on.
Jan 11, 2010 | Ovens
Smeg DO81CSS Electric Double Oven Logo
1,282 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
