Question about Toshiba Televison & Video
I have a HDD/DVD VIDEO RECORDER RD-XS24SG. lately I have a problem with channel setting, at AUTO it does not find all channels. My cable provider suggested that I set the channels manually. I checked
- from the Channel Setting I tried the AUTO - I asked the cable provider to reset my account and tried the Channel Setting again. - apparently the signal of some channels is weak and they suggested that I set the channels manually, they gave me a list of the frequencies. Sometimes the recorded material just shows horizontal lines black and white but the voice is fine.
  • 10 Answers
SOURCE: dvd recorder panasonic dmr-es20
run cable box through dvd recorder
Posted on Aug 25, 2007
whitetiger93
  • 141 Answers
SOURCE: pioneer dvd recorder dvr 310
Resetting the Recorder to Factory Settings
1. Make sure that the recorder is on
2. Press and hold the STOP button and STANDBY/ON button.
The recorder turns off with all settings reset.
Try this and let me know if it works.
Posted on Mar 27, 2008
SOURCE: HCT DVD recorder: HDVR-960s
Regarding the Black and white lines
You need to click menu scroll over to the right and select reset to factory settings.
I know you can not read the screen so try and follow the steps below.
After fixing mine by carefully reading the screens I went back and retraced the steps and counted.
Follow these directions. Do not go too fast or you may miss or lock up.
Turn the machine on.
Then with the remote
1). Click the button Settings
2). With the right arrow (blue directionals) click 5 times slowly. Slowly.
3). Click Enter button
4). With the down arrow (blue directionals) click it 2 times.
5). Click Enter button
This hopefully Resets your machine back to Factory settings.
It worked for me.
Posted on Oct 04, 2008
  • 3 Answers
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Unit must get the TV guide from an analog station. If cable company goes digital you loose the data. If the station that hosted TV guide goes digital you loose the data. This unit does not have a digital ATSC tuner only analog NTSC tuner. If you are still getting analog data there are a few capacitors on the power supply under the hard drive that bulge up and cause problems. They should be replaced with higher voltage rating types.
Posted on Feb 08, 2009
Benimur
  • 6966 Answers
SOURCE: I recently installed a Comcast digital adapter to
Hi and welcome to FixYa
Initially, postback the model number of the Comcast digital adapter and the TV.
Offhand, if the Comcast digital adapter is connected to the Sony through a coaxial patchcord, then the Sony would really have to be set to Ch 4 (or 3). Channel selection is done on the Comcast digital adapter. It is not possible to record one channel while viewing another.
Good luck and thank you for asking FixYa
Posted on May 22, 2010
How to play a dvd on toshiba hdd xs32
You must use the input setting and select dvd. Thanks.
Aug 22, 2014 | Toshiba RD-XS32 DVD Recorder
I am having trouble in connecting the new dvd recorder . I think ,I am missing some thing on the initial set up to receive the channels our present configuration is ... 1.R F cable input to set top box,...
I found your model information on a site which provided something I was going to ask you if I could not find it.DVD recorders need either a digital input from a cable box or a self-contained digital scanner(yours does not have this).So,you need to hook up as follows,External cable into cable box input,cable box output into DVD recorder input,DVD recorder output to TV coaxial cable input(usually labeled ant.)the screw on connector anyhow,you should know what I mean it seems.In this configuration,you should not need to turn on the DVD recorder to watch TV without recording because they usually have a bypass mode when there is no power on the DVD.If you have picture in picture(PIP),you should be able to use the main source to record and switch over to the PIP channel if you do not want to watch what you are recording.Do about a 10-30 second test of that just to make sure though so you don't end up all messed up.Oops.My bad...you do not have PIP.As long as the cable box is tuned to the channel you want to record,you should be able to use the TV's tuner to watch something else with no problem.When doing this on VHS recorders,sometimes the screen would get fuzzy and you would have to press the TV/VCR vutton on the VCR remote.I do not know if a DVD recorder will do it or not as I have yet to buy one,but when you do your test recording,you can mess around with whatever you want to see what happens so you will be fully prepared when you do it.If you need more help or have a problem/question,just comment here and I will get an autolink to your post and will reply ASAP.Good luck! Greg
Sep 26, 2010 | Coby DVDR1280 DVD Recorder/HDD Recorder
Don't know how to set channels w/new cable box.
Use channel 3 or 4 or hook up the RCA jacks. If you use 3 or 4 leave it on that channel and use the cable box to change channel. Use RCA jacks (best) turn the channel on the recorder to line in ether LINE1 or LINE2 with one you plug it up to and leave it on that channel.
Jul 23, 2009 | Toshiba RD-XS32 DVD Recorder
The TV guide on screen no longer lists the tv schedule
Look online for the AVS Forum about TV Guide ON Screen (TVGOS).  there are lots of posts there about specific locations and providers,
May 18, 2009 | Toshiba RD-XS55 (250 GB) DVD Recorder /...
How do I record a TV Program.
Video & Left,Right audio go out of Comcast cable box to L1 input on DVD recorder,Video & Left,Right audio go out of DVD recorder to a line input of your TV.  Record L1 input on DVD recorder.
Jan 10, 2009 | Panasonic DMR-E80H DVD Recorder
No sound through channels on hdd dvd
If you are taking output from the Red, Green Blue connectors (Component) from your video source and plugging them into your hd dvd recorder, you need a sound channel as well. The S-video carries both audio & video but not in high-definition. Sounds like you've got the 3 channels for your video (RGB-component) connection now you need an audio signal into your HD DVD recorder. That will be 1 fibre connection or 2 cables. Let me know if you get it working & good luck!
Nov 13, 2008 | Wharfedale DVD-M3 DVD Player
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hdd recorder / recording & watching cable channels
yeah actually that is kinda simple. Like the old vcr recorders you can just put a splitter between the cable (input) and your dvd hdd and your tv.
that is an easy 3 dollar solution
Apr 23, 2008 | Philips DVDR3575H/37
Hooking a vcr player to toshiba rd-xs35su
hi, connect it via a scart lead and switch to av channel.
Jan 13, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Ilo dvd player wont search high channels
At a guess the device will only find channels it can detect. So what is your connection antenna or cable If antenna then all TV is line of sight and directional If cable - only the channel's the cable co supply will come down the wire.
Sep 17, 2007 | iLO DVDRH04 DVD Recorder
Televison & Video Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
