Question about HP Laserjet P3015X Printer
Shadow on printout on hp laserjet p3015 - HP Laserjet P3015X Printer
pct_services
  • 5 Answers
SOURCE: HP Laserjet 3050 blank print
Have you tried a new toner cartridge? Usually blank pages are due to a missing bias voltage to, or in the cartridge.
Posted on Jun 21, 2009
FixinFax
  • 3085 Answers
SOURCE: MY HP Laserjet 1020 printer makes shadows on what
This a very recent model. Try replacing the toner cartridge.
Posted on Jul 22, 2009
  • 3 Answers
SOURCE: hp laserjet p3015 pausing after 5 or so pages
I have seen this problem before. Basically what is happening is the fuser is losing it's heat. When the printer pauses it is waiting for the fuser to get back up to temperature. The first course of action would be to reinstall the print drivers. This will rule out the communication aspect. Then to replace the Fusing assembly (fuser) and if that doesn't work to replace the Power supply.
If it is the power supply it wouldn't be worth the time or money to repair the printer based on the original cost of the machine.
Posted on Aug 16, 2010
SOURCE: hp laserjet p3015 prints really dark. how can i
EconoMode This product has an EconoMode option for printing drafts of documents. Using EconoMode can use less toner and decrease the cost per page. However, using EconoMode can also reduce print quality. HP does not recommend full-time use of EconoMode. If EconoMode is used full-time, the toner supply might outlast the mechanical parts in the print cartridge. If print quality begins to degrade under these circumstances, you will need to install a new print cartridge, even if there is toner supply remaining in the cartridge. Enable or disable EconoMode in any of these ways:
  • At the product control panel, select the CONFIGURE DEVICE menu, and then select the PRINT QUALITY submenu. EconoMode is turned off by default.
  • In the embedded Web server, open the Settings tab and select the Configure Device option. Navigate to the Print Quality submenu.
  • In the HP Printer Utility for Macintosh, click Configuration Settings , and then click Economode & Toner Density .
  • In the Windows PCL printer driver, open the Paper/Quality tab, and select the EconoMode option.
Posted on Mar 08, 2011
SOURCE: configure ip adress to hp
This model does actually have embedded network functionallity.
To configure the IP Address, follow the menu map as below:
1) - (4) I/O
2) - (4-2) Embedded JetDirect Menu
3) - (4-2-2) TCP/IP
4) - (4-2-2-1) Enable (Make sure this is 'On')
5) - (4-2-2-3) IPV4 Settings
6) - (4-2-2-3-1) Config Method (Auto = DHCP, Set to Manual in order to specify an IP address.)
7) - (4-2-2-3-2) Manual Settings (This is where you can set the IP Address, Subnet Mask, and Default Gateway.)
Posted on Jun 07, 2011
How do I reset hp laserjet p3015 to factory settings
  1. Press the Menu button .
  2. Open each of the following menus. Press the down arrow to highlight it and then press the OK button to select it. CONFIGURE DEVICE. RESETS. RESTORE FACTORY SETTINGS.
Dec 04, 2016 | HP P3015 Laser Printer
LaserJet P3015. Why is it printing dark background?
Hi Boateng Samuel,
I would be happy to help you with your P3015. Although the enterprise printer models are out of my support scope, I was able to find you the appropriate document specific to print quality. Please use the following document to troubleshoot the issue:
HP LaserJet P3015 Printer Series Solving Print Quality Problems
Best of luck, I hope this helps.
I work on behalf of HP.
Jul 17, 2015 | HP Office Equipment & Supplies
Hello! I have a HP P3015 LaserJet Printer show
you need to go to the printer on computer, then to the port settings and use the usb dot 4 port - will be that
Oct 22, 2013 | HP P3015 Laser Printer
There is an error code on my HP LaserJet P3015 which reads 49.4C02 ERROR
HP LJ P3015 with 49.4c02 error - tried lots of things in the end went into printer driver right clicked and then clicked troubleshoot - windows came up with a fix dont know if it is permanent - troubleshooter said a print job was deleted from the print queue. Presume the printer tries to print the problem job in the queue each time it is switched on.
Oct 10, 2013 | HP Laserjet P3015X Printer
Hp laser jet p3015 not powering on
41.2 error hp laser p3015 printer
Mar 25, 2013 | HP Laserjet P3015X Printer
Replacing Laserjet4 with P3015 no printout
Make sure that the IP address is the same as the LJ4
When you display the printer from the control panel can you actually see it?
Look at the properties and check the IP address
Oct 26, 2011 | HP P3015 Laser Printer
Shadow On Printout
Here are the possibilities:
-drum blade is not cleaning well, take out toner look at the shiny cylinder ( drum) is there toner on it? change cartridge.
- transfer roller ( black roller on bottom of machine that comes in contact with drum) take lint free cloth and wipe may need to be changed,
Oct 11, 2007 | HP Color LaserJet 9500HDN Printer
HP Laserjet P3015X Printer Logo
247 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
