Question about Radio Communications
Zodiac m144 cb radio
Mic plug on set
  • 13 Answers
SOURCE: midland cb radio
NO. I SORRY. YOU COULD GET IT FROM THE MANUFACTUREE. THANK YOU
Posted on Sep 16, 2008
  • 24 Answers
SOURCE: mic wiring diagram 4-pin
try http://www.cbtricks.com/
they have mic wireing diagrams
Posted on Jul 14, 2009
SOURCE: Wiring Johnson Microphone to cobra 29 CB Radio
Use trial and error systemathically. If still refuses to work, mike and radio aren't compatibles.
Posted on Nov 23, 2009
  • 219 Answers
SOURCE: 29 LTD CB Radio: whats the color to number wiring for cobra mic...
This is for a cobra CA50 mic
1-sheild
2-white
3-red
4-black
Posted on May 09, 2010
  • 1274 Answers
SOURCE: cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
Posted on May 29, 2010
My cb motorola can't receive from other cb radio
make sure that it is a cb radio and not a business band radio
Apr 22, 2014 | Cobra 29 LTD CB Radio
Galaxy DX-2517 CB Radio mic plug replacement
Its the same wiring as a cobra 29 so if you have one just match up what s there with what you go and you will be chatting in no time
Feb 05, 2012 | Galaxy Radios DX-2517 CB Radio
I can not send out
Is the DYNAMIKE turned all the way to the right? Check the mic wires, pin 2 on the mic plug is the audio wire, If you are using a stock mic the audio wire is yellow. If you are using an astatic mic, the audio wire is white. Is the PA/CB switch in the CB position? Does the radio have weather capability? if so make sure the weather/cb switch is in the cb position and the weather channel selector is set to off.
Feb 03, 2012 | Cobra 29 LTD CB Radio
29 ltd classic wont transmit
Great radio when it works.
If you have your settings on CB - not PA - -be sure that your Cobra has that setting selected.
If CB -is selected and still nothing - be sure you have a working mic. These wires are fragile and can break internally. One easy way to check is to borrow a cobra mic or even drop by a CB repair shop and ask them to do a mic check with the mic - it is free.
If you have a bad mic replace it and all should be well.
If your mic is good and it still doesn't transmit you will need to replace the finals in the unit. It is common that these burn out of you got too close to someone with too powerful a radio. The CB shop will need to look at it further and repairs should not be over about 40.00.
Good luck with your Cobra.
Mar 31, 2010 | Cobra 29 LTD CB Radio
My 18 WX ST Cobra CB radio will allow me to receive sound from the 3 weather stations it has on it, but I cannot pick up sound from other CB radios. help please?
get an swr meter and check your antenna first. if good problem may be in the circuit board.. they are famous for loose IF, TX mixer boards. or call us
Nov 03, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Have a33hml sometimes does not transmitt or rec
take apart the mic where it plugs into the radio.
there are probably loose wires.
make sure to mark each wire where it is hooked up to the mic pins before you start messing with it. Example: red #1..black..#2 ETC ETC.
the mic plug has numbers on it and the colored wires go to certain numbers on the mic plug.
Oct 23, 2009 | Galaxy Radios DX-33HML 40-Channels Base CB...
Not able to finish transmiting.
1 check and clean mic switch
2 check and repair wires in mic plug
3 if preamp mic replace battery
Jul 03, 2009 | Radio Shack TRC-503 CB Radio
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
Jan 13, 2008 | Magnum DeltaForce CB Radio
Radio Communications Logo
42 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
