Question about Sony KV-36FS100 36" TV
Halo of different colors on screen...need new TV?
I have a sony trinitron and just tonight the color when all haywire. It is like a ring around the center of the screen and the center is black and white. I had the TV for over 15 years (bought it new) and never had a problem. Until now...
4 Suggested Answers
SOURCE: Rings of Color
You will need a degausser. Check out Wikipedia for the definition. Look on ebay or your local TV repair shop. Cost should be $20-$100.
Posted on Dec 13, 2007
  • 116 Answers
SOURCE: 32" Sony Trinitron made 10/1994
Probably bad solder connections in the video processor area.
Posted on Mar 01, 2008
  • 4 Answers
SOURCE: picture is all different flashing colors
Maybe you put magnet near to your TV or something that can produce magnetism.... if not the deguassing system is not functioning anymore. .. bring your unit to near service in your place.
Posted on May 07, 2008
  • 4234 Answers
SOURCE: Sony Trinitron 29inch Color TV
The 2 blinks are an indication of over-current. This is usually because of a shorted component. The most common is the horizontal output transistor. This will be a 3-legged part attached to a heat sink close to the flyback transformer (part with red wire coming out the top). This transistor will be marked C4856 or something similar. Update this with the exact marking and I'll provide you with the full part number and approximate cost.
Dan
Posted on Jul 14, 2008
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
Sony Trinitron's colors have turned green yellow
Only yellow color denotes the absence of Blue color. Check it. Check its video output card for any loose solder terminals at the blue color output section circuits.
Jan 12, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
MY SONTY WEGA TRINITRON HAS A PURPLE HUE AT THE TOP OF THE SCREEN. ALSO THE CHANNEL DISPLAY WHICH IS NORMALLY GREEN ON COLOR IS NOW A RED COLOR
This kind of problem occurs if tv screen got hit by some thing that damage internally and its irreparable, second possible cause is magnetic field nearby screen, please check any speaker or some thing that has magnet inside around tv, remove it from tv to fix purple hue at top of screen.
Unplug tv from AC wall socket for 20-25 minutes, replug back in and turn it On, this will demagnetize screen to cure the problem.
Apr 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
The color appears to be going out. There is a
probably is a convergence problem with your tv so you need to take it for rapair,
Nov 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Color in corner going bad
U drop this tv before,like CRT yoke in cathode ray tube have big jumbo.Any magnatic around also,Tries moves the the difference directions might help,like northwest,southeast,so on.
Oct 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Horizontal color line across the screen
Most likely a bad Vertical IC or bad connections on the vertical IC. don't continue trying it on. If you have a bad connection it could do more damage. You also could damage the CRT ( picture tube ). If you remove the cover and look at the bottom side of the PC bord with a good magnifiing glass you may see what looks like rings around the leads comming from the Vertical IC. The Vertical IC is mounted on a heat sink usually towards the front of the set looking from back. If you do see the rings around the leads try reheating with a solder iron. If this dosen't fix you most likely need a new IC.
Apr 15, 2009 | Televison & Video
Color problem with Sony Grand WEGA 42WE655
Well, there probably isn't any relation between the two problems occuring exept for the timing. Magnetism won't affect a rear projection LCD.
I would say that your description is a bit odd, though. Usually on this model, there is a blue blob that shows up, eventually turning into a blue haze, and a star pattern of stuck pixels. It almost sounds like you have a bad set of component cables. On the SXRD's, they usually turn green.
Does it do it on all inputs (including the channels)? If it does, then it is the optical block. If it does not, then I would suspect that it is cable-related. If it is the optical block, then there is no way that any input can be different from the others (except for digital/analog differences, but those are usually obvious with patterns vertically on the screen).
If it does not look the same on all inputs or channels, change out whatever cables you are using. A loss of the red or blue cable in a component can give the symptoms you describe.
I hope this helps you...
Jan 08, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Dan
Jul 14, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Picture is all different flashing colors
Apr 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-36FS100 36" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
