Question about Dell PowerEdge 4600 Server
I have a dell4600 with ide drives only, error message drive not found and in bios it can only go to auto
Trying to revive son's old computer. I don't even see sata connectors inside but the computer is not recognizing the ide drive
  • 596 Answers
I would check your cables and connection to the server board. If these two are correct and you still get this error(s) you may need to use a desktop os such as XP, VISTA, WIN 7 to access the data.
Good Luck
C2Solutions
Posted on Feb 15, 2012
L410
Step 1:
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. make sure there are no disks in cd floppy usb drives Test all power and data leads that attach to your hard drive IDE,SATA the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat ribbon 40 pin IDE it will be the fist to fail Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error. also make sure you have set it boot from you hard drive in BIOS Restart your computer and enter BIOS mode. On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on. Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it. Once you've selected your desired options, continue to boot.
Feb 27, 2013 | Acer Veriton Computers & Internet
Bootmgr is missing
Step 1:
Feb 15, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
BOOTMGR IS MISSING
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on. Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it. Once you've selected your desired options, continue to boot. or The solutions might be very simply... remove your hard-disk and attached to other PC or laptop as an external hard-disk. When it is detected, go to my computer, right-click, untick that (stupid) option, immediately you see the message uncompressing and its done. Put your hard-disk back in to your machine its ready.. w7 insert your OS CD
go to DOS window and type in your OS driver (usualy C:/
type in bootrec /FixMbr
then type in bootrec /fixboot
then type in bootrec /rebuildbcd
then type in exit
restart your computer
it will work 100% only if you prompt at the same order Hope this helps.
Dec 15, 2012 | Western Digital HDD WD5000AAKX 500GB SATA...
Cd no boot record
Hope this helps.
Nov 19, 2012 | Computers & Internet
Missing boot manage
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs
data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Aug 25, 2012 | ASUS Computers & Internet
Boot manager is missing on qdi advance 10E mother board. \i'm trying to access the boot menu to put ubuntu on. the computer has no windows on it
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Jun 20, 2012 | QDI Group QDI Advance 10E Motherboard
Dell bootmgr missing xp
hope this helps
Jun 17, 2012 | Dell Computers & Internet
Boot file is compressed
hope this helps
May 24, 2012 | eMachines T3508 PC Desktop
The computer would not boot with a 2nd IDE drive installed
Try setting the jumper on the IDE hard drive to SL (ie slave).
Mar 17, 2012 | HP (SHP) HP DC7100 CMT SRP US HP...
Error 0203 failure IDE #2
Arthur,
That problem can be a couple of things.
The CD/DVD Drive may be failing ,or the actual IDE Controller built into the motherboard is bad.
You will need to determine which it is.
To do that - find an identical computer and see if you can remove the CD/DVD Drive from your laptop and swap it with that computer's drive. Then try to boot up your laptop with the "Known Good" drive in the system. If the same error occurs - then you will know that the IDE Controller on the motherboard has failed.
You can try to upgrade your system BIOS and this might trick the IDE Controller back into working, but it is a slim chance. Try it anyway.
(For details about swapping the CD/DVD Drive on your laptop, visit the toshiba website to get the instructions. Also, on the same website you can download the BIOS executable to attempt to run. The website is: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=556042&rpn=PSM30U&modelFilter=M30-S350&selCategory=2756709&selFamily=1073768663)
Hope that helps!
Nov 26, 2011 | Toshiba Satellite M30 Notebook
Dell PowerEdge 4600 Server Logo
mukhtar21 shaikh
mukhtar21 shaikh
