Question about Cooling System for Chevrolet Avalanche
No heat, engine running hot
Changed leaking water pump. engine is now running around 230, before it was running aroung 210. heater blowes hot air sometimes, but most of the time it is cold air escically in low speed travel.
  • 3 Answers
Get a coolent flush had the same thing with 2000 dodge intreed
Posted on Feb 14, 2012
The heater is blowing cold air
Coolant system is a closed system. If you are loosing water there is definately a leak somewhere. Check all hoses after filling the system and letting it run until it's warm. Be careful when checking most systems have the water at 185-210 degrees once the vehicle is warmed up. Also check the Heater Control Valve. It allows hot water to travel to the heater core when you set the ac controls to "heat". Could be bad and leaking there. But bad hoses are the most likely culprit. Only takes a pinhole.
Jan 12, 2013 | Rover 75 Cars & Trucks
What could cause my truck to have no heat?
the heater radiator could be blocked or the valve controlling the heater could be faulty ,,,, carefully check the heater hoses ,, they are the small ones running from the engine bay through the bulkhead into the car,,,they both should be hot ,,, if one is cold the water is not circulating either due to a blockage or the heater valve not working ,,, if the car has climate control you need to be sure that it is serviced properly as this system mixes the hot and cold air,, also at 210 you should have some heat , the best way to check if its the thermostat is to run the carstationary until it gets hot even if the thermostat is faulty the system will build up heat due to no cold air passing through the grill and coolng the engine radiator
Feb 11, 2012 | 2001 Chevrolet Silverado 1500
I have a 2002 ford ranger that runs normal while engine is running but gets hot when i shut off engine
SOUND LIKE ENGINE OVERHEATING.USE A INFRA THERMOMETER ENGINE TEMPERATURE SHOULD NOT EXCEED 104 CELSIUS WHICH IS 220 DEGREES IF ENGINE EMPERATURE GOING OVER 230. THERMOSTAT STICKING PARTIALLY CLOSED,WATER PUMP FAILING CHECK WEEP HOLE IF LEAKING REPLACE WATER PUMP.FLUSH RADIATOR ,HEATER CORE, AND ENGINE BLOCK. MAKE SURE YOU HAVE 50 / 50 ANTI FREEZE AND WATER.MAKE SURE ENGINE EXHAUST NOT STOPPED UP BECAUSE EXHAUST SYSTEM ALSO TAKE HEAT AWAY FROM ENGINE.
Aug 11, 2011 | Ford Ranger Cars & Trucks
GMC Sonoma SLE 4.3L 1991- Coolant Temp Gauge Not reading
there are 2 coolant sensors one for gauge and one for ecm
Jul 23, 2009 | 1991 GMC Sonoma
Heater problem 1999 trailblazer
low coolant, or air trapped in system, or bad water pump
Mar 29, 2009 | Chevrolet TrailBlazer Cars & Trucks
Thermostat?
It actually sounds to me like you're low on coolant. My Jeep leaks coolant and whenever it gets low the temp gauge will go real high and then drop, and the heater doesn't work well. This is because the cooling system of your car is supposed to be a closed system, full of coolant and no air. When coolant leaks out, the space it used to occupy is now occupied by air, which does not transfer heat well. When 'air' is passing through your cooling system, no heat can be transferred from your engine to the heater and radiator, resulting in a hot engine and no heat at the heater. Then when a pocket of water passes through the system, the temperature gauge quickly falls as the water absorbs the heat from the engine. The hot water that cools the engine is where the heater gets it's heat from as well, so when water passes through the heater core, the heater works, but when it's filled with air, it doesn't.
Hot water runs through the heater core regardless of whether or not your thermostat is open or closed. That's why your heater works in the winter even before the engine is at normal operating temperature. The fact that the heater stops working is a good sign that the thermostat is probably not the culprit.
As for the water pump. If the water pump was bad, your temp gauge would go into the red and stay there. Water pumps generally don't work intermittently. Either it's good and ot works, or it's bad and it doesn't.
However, if you are in fact low on water, as I suspect, it means you probably have a leak somewhere. The leak could be in the water pump housing gasket, so depending on where you take it for repairs, they may try to sell you a new water pump anyhow. So just beware of that.
Feb 12, 2009 | 2004 Chevrolet Blazer
Problem with No Heat on 2005 Chevy Avalanche - Cooling System?
it is most likey a sticking thermostat it either gets stuck closed or open in your case closed so collant isnt getting to the heater core and all you get is cold air blowing into the truck.
its a simple fix you can either do it your self or take it to a mechanic. now remember there are differnt thermostes so think about the climat you live in and get one according to that
Jan 07, 2009 | 2005 Chevrolet Avalanche
I have water leaking from the engine, but don't know where from. The radiator has been changed the water tested for emmissions, pressure tested and still water is leaking. The heating blows hot when...
if you see the water leaking form the front side of the engine usually from the water pump since the pump is not running you also wont get heat, bit when you pressurise the sys you are forcing the hot water into the core and you have heat, it is the water pump.
Dec 04, 2008 | Honda Accord Cars & Trucks
Cooling System for Chevrolet Avalanche Logo
96 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
