Monitor shows nothing with startup. Continues to show nothing.
  • 6 more comments
  • M. Valk Feb 14, 2012
    Compaq Pressario sr5521nl
    same onboard videocard and 'extra' video card. Nothing to be seen.
    fans running, power supply ok, it seems
    Also removes battery and did startup. But still nothing to be seen on the screen.
    At the back of the PSU the led shines brightly. Because aal the fans are working I think the psu should be ok.
    Fans are working, I think it is something else than the psu.
    took out all memory. Makes no change, still blank monitor.
  • M. Valk Feb 15, 2012
    SOLVED!!! The problem was not the Black Screen of Death from Vista, but the cpu. It was burned down completely. So now I am going to look for another MOB.
It will probably be your inverter or psu thats what it sounds like to me good luck
Posted on Feb 14, 2012
    What is an invertor?
My computer is on and has a blank page and it will not let me get to startup
What do you mean blank page? And what is startup? Is startup the desktop with your icons? Tell exactly what happens and what you see when you power on the computer.
Maybe you are saying your system booted up all the way except your screen is blank. If so try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 20, 2012 | Dell Latitude C510 Notebook
Monitor is blank and the power light keeps flashing green.
When you switch on both Poota and Monitor, is there visual startup flashes or startup information showing on screen.
Make sure the monitor connect to rear of poota is located and firmly in place and properly screwed in?
Nov 12, 2009 | Dell E196FP 19" LCD Monitor
Black and white screen
I had the same monitor and same problem. Nothing you can about it if your computer works fine... than its not your computer's falt. I got a new monitor. That's the best you can do too mate! :)
Aug 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway 22" flatscreen monitor won't display after startup
Monitor has blown capacitors internally on the power board I can fix these let me know what you would like to do.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
BENQ FP737S Monitor shows "No Signal Detected" on startup
first problem could be the hdmi cable you are using is loose or broken.second, the display mode you selected was wrong, try to go to desktop and right click and choose nvdia control panel and choose the nview display mode to use,select the only use one display(single)and apply.
Jan 27, 2009 | BenQ FP71E 17" LCD Monitor
Powers up but black screen shows
1st - Try pressing <Fn> + <BrithnessUP> keys a few times, (on HP <Fn> key is between <Ctrl> key and <Windows> key, <BrightnessUP> key is <F8> key and <BrightnessDown> key is <F7> key. If nothing happens try the 2nd one.
2nd - Plugin external monitor, (type and size doesn't matter). Turn on your laptop. If you can see desktop on the external monitor, your drivers are o.k., The problem is your laptop display, NOT the graphic chip.
Oct 21, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
