Question about Nixon Banks Watch for Men
I need a pin for the clasp. It is the spring loaded pin that connects the link to the squeeze mechanism.
  • 344 Answers
How To Get a new Pin, Sprinbar, or Locking Looper?
We can send small parts out individually, depending on the watch model. some watches will need to be sent in for repair. If you're in North America, you may call us our customer service line at 1-888-455-9200 from 8 to 5 PST, Monday to Thursday, 9 to 5 PST Fridays, for more details. If you're somewhere else in the world, please go to the nixonnow.com homepage, select your country, then support / service.
Posted on Feb 16, 2012
My watch band is too large. How do I make a metal expansion bracelet smaller
There are two ways.
First is to remove links.
Second it to move the pin in the clasp to another hole. Mine has 8 holes for this and you can see them in the side of the clasp. Use a pin to push the pin inwards as they are spring loaded. Do this work on a table with a cloth on it. If you drop the pin on carpet, they can be hard to find.
Nov 06, 2016 | watch band Watches
How do you take the links off to make it smaller?
Tiny screws in some of the links near the clasp usually. When you unscrew it with a jewellers screwdriver and the whole pin comes out and the link drops away.
If not, the adjustment is on the clasp itself by moving the final link further into the clasp cover. Press the tip if the spindle with the point of a knife or a pin. They are spring loaded in the centre.
Oct 18, 2015 | Watches
How to change the size of the strap?
I don't know for the swatch specifically but all watches are roughly the same beast. If you look at the side you will notice small pins on the band. With a very small jewelers screw driver and some light tapping you can pop the pins out. The end connections near the watch and then on the clasp side are usually spring loaded which can be removed with a tiny flat blade as well. Just tap out the pins and keep track of them, you will need to tap them back in once you have removed the extra link to make this smaller.
Sep 04, 2012 | Swatch Ycs410gx Windfall Watch for Men
How do I remove links from a Seiko watch band?
Follow these steps and it will help u resize your watch.
1-Take a good look at the watch bracelet. Seiko watch bands are equipped with one of two different types of pins holding the links in place. One type is a simple, nail-shaped pushpin that's inserted into the joint between two links. The second is a flat, L-shaped piece of metal that slides into the center of a link and locks it into place. Both pins are removed using the same process. If the nail-shaped pushpin is present, you'll see the tiny screw heads in the joints. If the L-shaped pin is present, the links will be open-sided and you'll be able to see a strip of metal inserted in each links.
2-
Look for the arrows on the inside of the watch bracelet links. The arrows indicate the direction the pins and links need to be slid off of the band. Any attempt to go against the arrows could break or warp the links.
3-Remove the spring bar from the clasp with the small pin-removal tool. Set the watch up on it's side so that the top of the spring bar is facing up and the bottom is flush against the table. Put moderate pressure on the top of the spring bar and tilt the watch just a bit sideways so that the spring bar can slide out. Ease out the bar slowly and carefully; the spring bar is spring-loaded and will shoot away from the watch if you're not careful (make sure that the bottom of the watch is pointed away from you at all times). Put the spring bar in a small dish so it doesn't get lost.
4-Line up a small pin-removal tool with the top of the pin and push in the direction of the arrow until it slides out completely. Slide off the link. Place the pin and the link in the small dish. You'll want to save them in case the watch needs to be re-sized again at a later date. Continue removing links, alternating sides of the band to keep it even, until the watch reaches the desired size.
5-Reconnect the watch. On the side opposite where the spring bar was removed, line up the link connected to the clasp and the second link on the band. Slide the pin in the opposite direction of the arrow, using a flat-headed pin inserter to push it into the joint. Use the pin-removal tool to give it a final push, listening for the click.
6-
Reinsert the spring bar slowly, using the pin inserter. Make sure the spring bar is lined up and tightly in place to avoid injury.
Try this and it you cant manage it then you need to get it to a watch repair shop specializing in that brand.
Jan 09, 2011 | Watches
Its too big to fit my hand good but also i cannot shorten it enouph so it can fit me without being extremely tight. Is there an alternate way to shorten it. I noticed 4 holes where the clasp is and was...
Some clasps have holes in them to allow you to adjust the straps in smaller steps than removing links.
It sounds as though yours in one of these.
The pins are spring loaded just like the ones used to fasten the strap to the lugs of the watch, so you can apply a probe to one end of the pin with one hand, while applying a gentle force in the direction you wish the strap to go with the other hand.
Then do the same with the other side and repeat as needed.
Jan 05, 2011 | Breitling Bentley 6.75 A4436212.G573.970A...
I am looking for the spring loaded pin to connect the band to the clasp for model #F98-04-KC3511.
This is usually a 14-16 mm clasp spring bar. Your local watch repair shop should be able to supply it to you without a problem.
Sep 22, 2009 | Kenneth Cole Watches
How to remove links from band
This band is put together with cotter pins. To remove the cotter pins look at the edge of the band. The end of the pin that comes out is split and looks like a screw. The end that is solid is the end you want to push from. Use a small punch to push the pin out. The split end is the bigger end of the cotter pin so it needs to come out and go back in the same way it came out. Make sure you remove an even number of links on each side so the watch sits on the wrist the right way. You also have a micro adjustment on the clasp. To adjust the clasp simply use a punch to press the spring bar in the clasp in until it moves. This is a spring bar so be careful it doesnt jump out if the clasp comes apart.
Sep 22, 2009 | Festina 16177-4 watch Watch for Men
I need to adjust a Casio AMW320rd-1A9 STAINLESS WATCH BAND. ADVISE PLEASE
Sep 19, 2009 | Watches
How to adjust the band on a GW800D Tough Solar
By finding a spring loaded rod in the clasp (that is in the set of three holes in the clasp) moving it to the last position. However it was still loose, so by finding the spring loaded rods that hold the links of the band together, pushing them down in the direction of the arrows and removing enough links to fit.
Aug 29, 2009 | Casio GW800D 1V G Shock Atomic Solar Watch
Adjusting the strap
Most clasps have a series of small holes drilled in them, and the end of the strap is held in by a small, spring-loaded bar whose ends are seated in one set of holes. Take the end of a small paperclip, or a large needle, and use it to depress the spring-loaded pin. You can then carefully slide it to another set of holes to make the band smaller. Don't let the ends of the pin slide all the way out of the clasp, or it might shoot off into space.
Jan 22, 2008 | Versace 27473-008-00 Wrist Watch
Nixon Banks Watch for Men Logo
96 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
