Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint csx24grxa aa no power to water pump - Hotpoint HSS25GFP Side by Side Refrigerator
I have a Hotpoint BF71 dishwasher. I put it on but it hasn't worked, it filled with water which won't drain not will it even start now. I took out the filter but I couldn't find any blockages Help!
Reset the power at the breaker, but you may need a new pump and motor assembly. The same pump washes and drains on most Hotpoint models- a solenoid is used to open a drain flap and let the water out, but a bad pump will equal no wash or drain... Hotpoint Dishwasher Pump and Motor Assembly WD26X10013 Hotpoint Dishwasher Drain Solenoid Kit WD21X10268
Jul 11, 2016 | Hotpoint Dishwashers
Good Morning, my name is Ian. My Hotpoint Washing machine has been strong and reliable since I moved into a rented property 1 year ago. I placed a load in on a long wash, and within an hour all the lights...
It sounds like it could be the timer, but I'm not sure. I would go to a Hotpoint site and you might be able to talk to a tech or tech-support there.
Mar 05, 2015 | Hotpoint Washing Machines
Hotpoint wma37 washes clothes ok but wont drain or spin
the hotpoint has a saftey factor built into it if the water does not drain it will not spin , the fault is the pump is blocked or broke or the sump hose is block this leads into the pump
to fix take the drain hose the grey one and put it in to a bucket and it will empty the water
if not the sump hose is blocked
if it emptys lie the machine on its side if poss with power off , if it will not lie on its side disconect the water hoses
look under the machine u should see the pump and the sump hose u can remoe this hose put lots of old towels down to catch the water check in side the sump hose for blockages
the pump this on the new models has hex bit screws on it to open check to see if it move freely it should spring back slightly
try this any problems let me know the model number
Jun 28, 2009 | Washing Machines
Hotpoint machine is not throwing the dirty water out
blocked drain piping or blocked impeller on drain pump or failed coil?complete pump,that would be the area that should be looked at to solve problem
May 05, 2009 | Hotpoint Washing Machines
Wont go through cycles or drain the 3inches of water.Is getting power
turn on the dishwasher then go to your circuit breaker and, switch off the power to your dishwasher next: reach in to your dishwasher and remove the cover on your pump then remove any broken glass etc. that has fallen into the pump then put the cover back on and, close the dishwasher turn it on and, turn on the breaker you turned off earlier your machine should work again let me know how it goes...
May 02, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Hotpoint Aquarius WD440: IT seem when it supposed to pump the dirty water out,the waters are not coming,but if i take the pump and put down on the floor ,the water are coming out and it run the whole spin...
If you are getting voltagae to the pump and the water is not pumping out then you have a bad pump, just replace it and you have the problem solved, If you do not have voltage then we would have to find out why.
May 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Waste water problem
you have a blokage in the water drainage
Jan 01, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint HSS25GFP Side by Side Refrigerator Logo
35 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De GO PATS
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
