Question about Dell PowerEdge 840 (becwmk1_2) Server
Why red light blinking on dell poweredge 840 - Dell PowerEdge 840 (becwmk1_2) Server
  • 596 Answers
Check your power supply or the power supply source (outlet or UPS unit) as well as the power cord. Your system power source is not at the correct amp, voltage and may need replacing.
Good Luck.
C2Solutions
Posted on Feb 15, 2012
SOURCE: Dell PowerEdge 840
Look in Bios setup for OS Install mode setting. If it is enabled, it restricts the RAM to 256MB. Change the setting to off and it will sense the total RAM
Posted on Dec 09, 2007
SOURCE: Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
Posted on Jun 11, 2009
JaxPlanet
  • 921 Answers
SOURCE: My Dell PowerEdge 840 will not allow me to install
I am not sure where you got your information but I just checked Dell's website and they have Windows 2000 drivers for your server which include the video driver.
http://support.dell.com/support/downloads/driverslist.aspx?os=WNT5&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PWE_P4_840&hidos=WNET&hidlang=en&TabIndex=)
If you are still having a problem then you should call Dell support. Every Dell server has lifetime free phone support.
If this helps please vote for my solution.
Posted on Sep 30, 2009
Vanniar
  • 23 Answers
SOURCE: power edge loght is red and blinking
You should be able to see the reasons in the front panel, remove the front cover and you will see a small display with some information passing slowly. Sometimes is just the redundant power-supply that is disconnected.
Posted on Nov 25, 2009
  • 12 Answers
SOURCE: We have a Dell Poweredge
Go into the RAID setup during bootup (not always in the BIOS), but will post somewhere on startup (should say SCSI/SAS Controller card press CTRL + M to enter setup) or similar.
When in the raid setup check to see the status of the drive(s).
Was the machine running and it's just happened etc or are these machines you have obtained and are plain not working?
Posted on Sep 09, 2010
I cannot get the Dell PowerEdge 840 to recongize and of my HDD in the Raid array.. Trying to install the OS but tells my on HDD is detected
Then you need to get into the BIOS of the PERC RAID controller and inspect the state of the physical/logical volumes. Reboot the machine and watch for the prompt after the PERC5/6 RAID controller loads it's BIOS.
Considering this a null issue given the age, though...
Jan 21, 2014 | Dell PowerEdge 840 (becwmk1_2) Server
Orange blinking light on 840 PowerEdge
Take all 84 of your servers to a service outlet.
Nov 16, 2012 | Dell Pallet Of 48 Poweredge 840 Intel Xeon...
Dell Poweredge 840 shutdown automatically
Hello
This error mostly comes with the failure of processor fan, overheating of processor shuts down the system due to processor's protection. You need to check the fans and replacement is recommended.
Hope this helps
Jan 31, 2011 | Dell PowerEdge 840 (becwmk1_2) Server
I have a blue vertical flashing light showing just above the Dell emblem. In the past there has been a solid light. I have checked on OpenManager which indicates all is well but I do not like unexplained...
Great thanks,
That's just a system indicator flash. Solid blue means on and normal, blinking means someone either turned on the system indicator in the management software or bumped the indicator switch on the back of the server. This was designed to make easier transitions from back to front when working with multiple servers in a rack. To turn the indicator off, just go to the back of the server and find the Ethernet and usb ports that are together. If the usb is the bottom and Ethernet port is the top then just to the right you should see a small blue blinking light and a button, pushing the button wil turn the blinking off.
Again, no worries this is just a "locator beacon" not an error message, if the light ever blinks yellow then you have an issue.
Hope this helps FixYa,
Chris
Jan 10, 2011 | Dell PowerEdge 1800 Server
Power edge loght is red and blinking
Nov 25, 2009 | Dell PowerEdge 1800 Server
High pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
May 26, 2009 | Dell PowerEdge 1800 Server
Beeping Upon Bootup
dependent on how many beeps you hear is dependent on what might be the problem. A fuller explanation from pushing the power button to nothing happening would be more than helpful. Beeps in a Poweredge can mean motherboard, memory or as you said power supply problems.
May 06, 2008 | Dell POWEREDGE 2400 Server
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
Dell PowerEdge 840
reinstall your server it will resolve your porb.
Dec 03, 2007 | Dell PowerEdge 2600 Server
Dell PowerEdge 840 (becwmk1_2) Server Logo
707 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
