Need cu.ft. for kenmore model#25369804893 and water on bottom under crispers how do i fix
SOURCE: refrigerator collects water at bottom,
at the top of the fridge section at the center back there is a drain assy/ tube for defrost water to exit the unit and go to the bottom of the outside, this is most likely clogged up. disassemble and clear drain line, hook back up and call me in the morning.
SOURCE: 2006 Whirlpool 20.9 cu ft,
If you access the panel in the rear of the unit, check the evaporator tray, is it dry? It shouldn't be! If so, check the drain hose above it. It is likely plugged.
SOURCE: water in inside bottom
I would try vasoline petrolium jelly on the door gasket. If the gasket is not sealing correctly, air will get in and condensate. Also check the gasket for any cuts or tears too. This old trick, My boss would charge $30.00 for when I worked on appliances.
