Simpson aquapulse 713 heavy duty 7kg .it first started when the washing machine flooded the wash house, duno where the water was coming frm tho and the screen displayed PU - check the pumps. so we did and they weren't blocked or anything. tried to wash the load again and it went okay but when it came to the 'spin cycle' it would stop and display PU once again. we've pulled out the middle agitator to check if there was anything stopping th spin cycle to go about as usual but nothing. now we're all out of ideas, please help !!
I have a Simpson 7,5 eziset top loader. It fills and does the wash cycle but won't empty and spin put the hose on the floor the water empties. Then when I switch it to spin it does
Posted on Dec 09, 2013
I've got a simpson aquapulse 713 and just noticed that there is oil on the floor, seems to me it happens after it has spin. Any ideas?
Posted on Jun 02, 2011
My simpson aquapulse 513 5kg heavy duty machine, spins washing into balls and then stops, what must I do to repair this
You will probably find the agitator is spinning but steel bowl isn't. Either brake release is not working or clutch problem. Not an easy fix. Best to get someone out to repair it.
Nov 12, 2016 | Simpson Washing Machines
The water is not draining out of the washing machine what could be wrong
not much info out there on this one
water pump solenoid or water pump
faulty control board timer
to empty machine run drain hose out the door
or towels and buckets
Sep 17, 2016 | Simpson Washing Machines
I hve a simpson aquapulse every time I do washing pu comes up can sme 1 plz tell me wat it means thx
PU code is the drain pump/\, This code can mean a bad pump, but most often there is some kind of restriction or blockage in the drain lines from the pump to the drain. Check for clogs/restrictions and clean them out and try again.
Dec 31, 2014 | Simpson Washing Machines
Remove the clothes and check for free movement of the drum, if there is friction then check the motor and belt assembly, check the free movement of the bearings. Also make sure that the inlet water level is good and the water level set is correct for the clothes quantity. If not the clothes will be dry on top and might cause such an issue
Oct 03, 2013 | Washing Machines
Brake band for Simpson Genesis 505 heavy duty washing machine
www.searspartsdirect.com or www.applianceparts.com. If the brake is internal with the gearbox, chances are the only way to replace the brake is with a new/rebuilt gearcase.
May 10, 2012 | Simpson Washing Machines
I have a SIMPSON ENCORE 555 heavy duty washing machine. It will do a normal wash cycle, but when it comes to the spin cycle, it doesn't distribute the washing around the drum and hence won't spin. any...
Hi just read your posting.Now does the washing tangle around the agitator?In your posting you mentioned the washing not distributing around the drum.Could you confirm that your machine is a top loader for me,because the word "drum and distribute" are terms for a front loader.If your machine is a top loader which I think it is then the problem could be your brake arm or spin coil is not operating.Please reply and let me know if the clothes are tangling around the agitator.Looking forward to your reply.
Sep 07, 2010 | Washing Machines
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Washer does not rinse & spindry after getting submerged in water.
everything needs to be checked from the timer control button to the motor, im guessing it agitated through the wash cycle but wont spin now right? your flood could have damaged any number of items... run through ( with the machine unpluged ) and test the components for continuity and/or resistance.
Oct 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
657 people viewed this question
Top Washing Machines Experts
