Question about Streamlight Survivor LED Flashlight, by 90503
The alkaline battery of my survivor LED has been leaked, when i replace the battery it didn't turn off anymore even when i hit the switch. please help me solve this problem. thanks!
Panasonic Lumix DMC-LS75---I have put in new batteries , yet it says " Please replace batteries" as soon as I turn it on and then switches off by itself. I have cleaned the battery terminals; it stil
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Check the contacts of the battery and in the battery compartment of the camera. They all should be clean and shiny. You can clean contacts with a dry cloth or cotton swabs. Never use anything sharp in or close by a camera.
Nov 23, 2014 | Panasonic Cameras
Red light flashes but camera will not stay on
When the red LED goes on. the batteries are empty. When the LED is flashing, it is even worse.
Your camera will work with AA batteries.
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
Mar 01, 2014 | Konica Minolta DiMAGE Z3 Digital Camera
It turns on, but nothing else
take out the batteries; remove cartridge. press hold power button for 30 seconds. place batts back in and try to turn toy on
Oct 05, 2012 | Vtech V.Reader Interactive Reading System
Hi, I have two IC-R10's in very nice condition. Previous owner passed away several years ago and left the rechargeble batteries inside the units(The contacts had very little corrosion left from the...
  • Hi, I can help.
  • It is very possible that the corrosion could be a little worse than initially thought. Look for unnoticed corrosion and clean the contacts real real well with a pencil eraser.
  • Under the third battery is a switch marked (Charge) OFF/ON. When using the power supplies to power the scanner the switch should be off (pushed to the left). When using batteries the switch should be turned to on (pushed to the right)
  • The internal charger is meant to charge Ni-Cad batteries not Alkaline batteries. If you have Alkaline batteries in the unit then you should never have that switch to on with the power cord plugged in or a charge will be attempted on the Alkaline batteries and they will explode/leak.
  • The problem will be that switch, unnoticed corrosion or the batteries you are using are not good.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 29, 2011 | Icom IC-R10 Handheld Scanner
I got the kodak easy share 143 model camera coming brand new off of ebay yesterday,,,but it keeps saying my batteries are half drained, then dead after a couple of photos. Then if they're dead it...
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 26, 2011 | Kodak Cameras
Hi, I bought a Vizio L32 HDTV10A that didn't power-up. There were charred components on the power board (an 8-pin IC with heatsink and 2 resistors). I replaced the power board, and the power LED then...
change the mother board. the ic took a hit after the power board went off. it will test good without stress, but under power stress it break down. measure the output with osciloscope to check the waves you should get a saw tooth wave if the the ic is good under stress.
Mar 07, 2017 | Televison & Video
Battery in flaslight was leaking and ruined the light. It was a cheap LED flashlight so just threw it away, but when I went to my package of new Nexxtech Alkaline Infinicells, I see that there are about 12...
That's what can happen with super cheap no-name (no quality control) batteries. Frequently batteries of this type are not even alkaline at all but old fashioned zinc carbon batteries.
NexxTech claim to offer "Affordable Quality products", so perhaps their buyers are unaware that their suppliers are letting standards slip. I'm sure that if you contact them they'll try to help.
http://www.nexxtech.com/nexxtech_usa.html
Jun 16, 2009 | Cameras
Streamlight Survivor LED Flashlight,  by  90503 Logo
29 people viewed this question
Top Streamlight Camping, Backpacking & Hiking Experts
Stan Ford
Tom Chichester
Are you a Streamlight Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
