Question about Cameras
TV suddenly lost power in set - all else ok
Hi, I wonder if you could give me some advice regarding (or would be able to suggest who could repair) my SwissTec M22/37C-GB-TCD-UK? I have had the TV definitely from Jan 2009 (possibly from Jan 2008 - either way I am sure that it has run out of any warranty. It was purchased at Sainsbury's in one of their post Christmas sales and has given good daily service up to last evening when I switched it off to settle to sleep. Today when I went to turn it on I noticed that there is no red standby light and no means of switching it on from the remote or main set. I have changed the fuse and checked the electric supply which are all perfectly alright. In fact I have changed it over with my lounge set and that is running perfectly from the same socket. I have no knowledge of how these machines work but wonder if from what I can tell you if it is repairable and if it is worth what it would cost or if I would be better to dispose of it and buy new? I would be grateful for your response. thanks Elizabeth
  • Huh? I didn't post a digital camera question folks - how did that happen??? It really is a TV!
SOURCE: no power
Bring your Tv to Micro Electronics
1515 Britannia Rd E, Unit 12
Mississauga Ontario, L4W 4K1, CANADA. ask them to chek it out, they are the best, they will let u know is it possible to fix or not, how much its gonna cost you, if its fixable and can get the parts you will get the tv in ur hand next day. call them 905-565-6595
Posted on Nov 11, 2007
SOURCE: power switch does not function
Yes I have the same problem. Camera will not switch on.
Posted on Aug 02, 2008
SOURCE: can I fix this?
TRY WWW.BUY202.COM THERE CHEAP ON SCREENS
Posted on Sep 06, 2008
SOURCE: digilogic dstb1000
the function light dose not represent a remote command, it simply flashes when it detects a infra red signal of any wavelenth. if the box is not turning on it sounds like a defective nor or nand flash rom. i believe that the box has a j-tag so maybe you re flash it?
proberly not
so inconclusion a defective flash means no os no os means the box wont work
hope this helps
Posted on Oct 31, 2008
  • 73 Answers
SOURCE: Digital Camera Problem
this may sound violent and stupid but have you tryed pushing the lense back in. if the company refuse to fix under warrenty and your not going to pay the. its not going to change anything if it doent work
Posted on Mar 24, 2009
Hi i own a 26 inch Didgatrax tv model cfd2685....
suggest you take it to a repair shop for a repair estimate. normally done free if you decide to have them fix it .
Sep 07, 2017 | Televison & Video
756 pro no signal for a while then comes on
To help you resolve this issue, the best advice I can give is to: join yahoo group specific to your radio Make/Model, the team there will help you with expert advice and info, plus you can download goodies for your radio, all is free.
I hope I have assisted you.
Best regards,
Peter
Aug 13, 2012 | Icom IC-756PRO Transceiver 002896
Purchasing from family
please give detail of problem in tv set that you asked roughly cost. regarding transportation on pick up, its ok and better if you pack tv in original packing.
Sep 04, 2008 | Sony KP-53HS10 TV
Toshiba 27D46
Hi
Your set will have cracked solder joints in and about the vertical output stages. This is not a major repair, and will require re-soldering of that stage, and maybe a few capacitors replaced as a cursory repair as preventative maintenance. should cost between $50-80 depending on who you get to look at it. If you are quoted a price higher than this, I suggest ringing around repair guys in your area and be careful to explain exactly what you have described the fault as here.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jul 10, 2008 | Toshiba 27D46 27" TV
Toshiba 27D46 27" TV Problem
Hi
It will not be the picture tube. Your set will have cracked solder joints in and about the vertical output stages. This is not a major repair, and will require re-soldering of that stage, and maybe a few capacitors replaced as a cursory repair as preventative maintenance. should cost between $50-80 depending on who you get to look at it. If you are quoted a price higher than this, I suggest ringing around repair guys in your area and be careful to explain exactly what you have described the fault as here.
regards
robotek
May 29, 2008 | Toshiba 27D46 27" TV
Sanyo DSC27930 No picture, no sound but seems to have power.
Hi there!
Something did Pop and yes it will cost 150 - $300 to repair. The question is what would a new unit of the same size and quality cost. If the repair is about a third of the cost of a new unit , it would still be considered economical in RSA. If repaired it may run again for another 4 years so the Math speaks for itself. The decision entirely yours in the end. It could really be anything that popped so to give advice would be difficult. However, try the fuse first. It is certainly the cheapest option at the moment. Regards and good luck, JUS004
Apr 01, 2008 | Sanyo DS27930 27" TV
Tv philips 28"
Hello, you (tech) can try this remedy - 1500 = fuse (250V/4A) - 3523 = resistor (47R) - 3527 = resistor (0.22R) - 3532 = resistor (2.2K) - 6500 = diode GBU4JL7002 - 6523 = diode 1N4148 - 7520 = circuit TEA1507P/N1 - 7522 = transistor BC847B - 7521 = transistor STP10NK80ZFP - 6526 = diode BZX384-C22 - 7515 = optocoupler TCET1104-G - 3526 = resistor (0.15R). - 3526 = resistor (0.22R). If you need more info please advice. Arpi
Jun 17, 2007 | Philips 28PW6506 28" TV
Dead Philips 32PW9545 TV
the problem is in the power supply or related circuit.call a tech to look at your set.it should not be expensive to fix maybe between $40.00 to $100.00 good luck
Apr 23, 2007 | Philips 28PW6506 28" TV
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
