Chicagao electric fireplace heater doesn't work
I have a Chicago electric fireplace that is not blowing out any heat...The bottoms light up but, nothing happens..I have tried only 750watts and, still it doesn't kick on.
The light bulb and, flames work fine.
Is there a website or phone number where I can buy a replacement blower unit?
Thanks
  • hatterasjeep Dec 08, 2008
    I have the same problem. I need a source for a replacement heater assembly.
  • Anonymous Mar 22, 2014
    I have a electric wall mounted fireplace model number ef431/plu242032 ive changed bulbs but lights still won't work
MY HEATER NOT WORKING,BLOWER AND LIGHT COME ON NO HEAT
Posted on Sep 20, 2009
Fire doesn't flicker on my fireplace heater anymore.
Posted on Dec 25, 2009
HI THE 3 INDICATER LIGHTS WERE ALL ON SHOWING THAT THE HEAT SHOULD HAVE BEEN ON FULL CAPASITY!!BUT THERE WAS NO HEAT BLOWING OUT OF THE GRILL!!
Not an unusual problem with any electric fireplace heater. I suspect the overheat circuit has shut the heating element down. Or the element has burned up (that's not unusual either).
In any event, turn the fireplace OFF and unplug it. Wait 30 minutes before plugging it back in. During that time, the overheat circuit may reset itself. If that fails to solve the problem call The Technical Service Dept of Dimplex USA at 888-346-7539, Monday - Friday, 8:00 a.m. - 4:30 p.m. EST. If it ends up needing parts, you can order them at that time.
Have the Model # and Serial # of the fireplace, handy. As you will need to provide that information to them, as well as the date of purchase.
Mar 02, 2011 | Dimplex DF3003 Electric MidSize Heater
The fireplace blower does not work therefore there is no or very little heat from my dimplex elect fireplace---thanks
This is a constant problem for ALL electric fireplaces with heaters. Either the Owners Manual fails to the manufacturer not telling you that the heating elements need routine cleaning, because they are sucking in household air to heat it and send it back out, So whatever is float in your household air (dust, lint & pet hair) near the floor goes into it, clogs it up and causes the heating element to overheat and fail. Or customers who have purchased these units don't read the Owners Manual.
These units, no matter who the manufacturer is were not designed to heat for long periods of time. In fact the heater element doesn't produce much more heat that a blow drier on high heat.
The heater and the blower and are in the lower compartment of the firebox. If you can access it, you can clean it with a shop vac and a brush attachment on the end of the hose. Be sure to unplug the fireplace from the wall outlet before attempting this. If cleaning it doesn't help, the blower motor will have to be replaced. You can order one from Dimplex USA.
Feb 06, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Heater works fine when its turned on but stops blowing heat after 3 mins.
mine just did the exact thing. I took it apart and blew it out with an air chuck and it works like new again. a couple of weeks ago i used a vaccum and it work a couple of days and then did it again. The squirrel cage and heat elements were filled with dust. It was not easy taking apart but now i know to only take the bottom off. thanks
Nov 18, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Electric fireplace just blows out cold air it is a Century model # is HEF26
It would seem to me that the Thermal fuse has "Blown" this is an internal protection device that operate from heat... they often fail spontaneously, when this happens oftem all else works but no heat.
You will have to take it to a reputable repair shop/man and get a firm "Quote" for repair.
Jan 20, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Twin Star electric fireplace fan (maybe heater) doesn't work!
I have a twin star electric fireplace insert model #28efo24grs that is missing a remote any suggestions >>>>917-747-4893
Dec 13, 2009 | Kitchen Appliances - Others
My electric fireplace model # HEF33WDG, the heat works, but the flames dont move. Can someone help me.
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
Oct 21, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Oct 15, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Rewiring Fireplace Electrical Insert
I looked up regular electral diagram for the different elements.
Dec 15, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Electric fireplace 39EB364GRS
do a search on the web for model of fire place.
Oct 10, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Problem with HomePride model TE555 fireplace heater
I hav ethe same heater but my coil does not get hot. I am trying to find a replacement part for it but no luck. I called the number (905-847-2643) of the company but no call back.
Jul 27, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
1,397 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
