Question about Mitsubishi CK-35308 35" TV
Mitsubishi CK3527R shuts off on its own
I have a Mitsubishi CK3527R Counsel TV purchased in 1998. I am having a problem with the TV Shutting off, on its own, intermittently. When this happens, sometimes the little Green Program Timer light goes on, located at the bottom of the set, for a few seconds, then it shuts down . I have unplugged it for a day or two, re plugged it back in and it would work OK for a few days, But the it would shut down at any time, periodically, again. Any suggestions??
ctf1800
  • 4402 Answers
SOURCE: TV Shuts down
convergence amp IC's i would start with.
Posted on Dec 03, 2007
josh1856
  • 105 Answers
SOURCE: Mitsubishi VS-55707 Shuts Down
I would not recommend working on a TV unless you have a great deal of knowledge about them.
it is probably your power relays do you have a part # i could help you look around
Posted on Jan 26, 2008
  • 1030 Answers
SOURCE: TV suddenly shuts off and lamp light comes on, but lamp is OK
did you reset the lamp timer? just a guess
Posted on Feb 08, 2008
  • 6 Answers
SOURCE: Mitsubishi WD-62628 power shuts off!
I have the same issue have not done the repair yet but here is a link to photos of the various boards and the problem caps:
http://www.fixya.com/support/t155026-
flickering_blue_picture
Posted on Feb 16, 2008
  • 116 Answers
SOURCE: Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Posted on Mar 05, 2008
Why is my television shutting off?
Could be an overload problem,have a TV technician check it out.
Jul 21, 2014 | Mitsubishi WD-65737 Home Theater
MY TV KEEPS SHUTTING OFF MISTIBISHI 60
if its shutting off I would say something is wrong, what is model number of set?
Sep 02, 2012 | Mitsubishi Televison & Video
Mitsubishi WS-A65 shuts off after 5-10 mins of operation. Any suggestions?
no errror found? It is shutting off for some reason, did the error test it should have?
Apr 17, 2012 | Mitsubishi Televison & Video
Mitsubishi 65" LCD (1080P, DLP) keeps shutting down until it "warms up". After shutting down the power led flashes yellow for a minute or so, at which time I power it up again. This cycle repeats 1 to 4...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV may require service.
Jul 27, 2010 | Mitsubishi LT-40133 40 in. LCD HDTV
My television is cutting off and takes forever to restart. the green light stays on. I have tried to reset the tv. same ol thing. replaced the lamp its not that. a big blue screen pops up before shutting...
Hello! If you haven't replaced the lamp before, I recommend you do it, since it's already 4 years old. If you already replaced it, there is a possibility you might be having a ballast issue. The ballast is the board in charge of sending all the power to the lamp so it can light up. www.discount-merchant.com/?Click=48427 These part are not that expensive and will get your TV up and running.
Nov 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
TV keeps shutting off automatically
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
Jan 28, 2009 | Pioneer Elite PRO-111FD 50 in. Plasma TV
TV WILL NOT COME ON
Your tv is probably going into a "protection mode" this means something inside the set had failed. This is the tv's way of shutting down before more damage can occur. This could mean many different things that could have gone wrong with this unit. Your best bet is to call your local dealer and have them come out and look at it for you. Tearing apart tv's is very dangerous! Some sets have up to 30,000 volts on the anode! GOOD LUCK!
Aug 17, 2008 | Mitsubishi WS-65712 65" Rear Projection...
Push the menu and inputs buttons on the set in both together and hold for 8 seconds this should make the led flash a two digit code. Let me know what happens after doing this test.
Apr 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
