Question about ViewSonic N3000W 30 in. HD-Ready LCD Television
ViewsSonic n3000w sound working, but picture is not
My viewsonic n3000w LCD TV's picture is not working. I turn it on, it blinks the ViewSonic logo for about 1 second, then goes black. I cannot see anything, even the menus or volume controls. The sound works fine and I have tried all of the inputs. Through my research, I've found that either the inverter board is kaput, the powersupply could have problems, or that the inputs could be damaged. I am wondering how much the cost would be to have it diagnosed, and possibly how much the replacement parts would cost. Otherwise, it may meet it's fate on the parking lot 3 stories down. Thanks for all the help in advance!
    Problem Solver:
  • 6 Answers
Your inverter is bad. i think there's 8 transformers.. one for each backlight.. one of them is sorted and is bad.. if you know something about electrics you can try to find one transformer or you can try to find the whole inverter.. good place for parts is http://www.lcdparts.net
Posted on Oct 30, 2008
  • nikosyr Nov 02, 2008
    Just got one n3000w in my hands that has the same problem.. i will try to fix the inverter. i'll post more after it works.
  • nikosyr Dec 07, 2008
    Hi. i got my viewsonic work. there were about 20 bad capacitors in the mainboard. you need ESR meter to measure which ones are "dead".. good cap has like 1ohm esr but rhere were about 10 caps that had 10-13ohm esr.. after i changed them it started to work.
Viewsonic N2060w no picture but sound My Viewsonic was working fine yesterday, now when i Turn on there is power going to the TV but no picture on the screen?
LCD backlight has gone out , you can verify this by holding a flash light up to the scene to see image , www.partstore.com or www.shopjimy.com where you can buy the part and put it in yourself would save you money
Oct 04, 2011 | ViewSonic N2060w 20 in. LCD Television
Can be related to a possible fault in the inverter board , failure of the back light . Please check the power to the board and check the back light circuit.
DVI-HDMI work but there is no sound
DVI input has no sound as normal you can use a RCA connection to get sound from the freeview box
Apr 21, 2017 | ViewSonic N3000W 30 in. HD-Ready LCD...
Trying to hook up my PS3 to my Viewsonic N3000W to enable me to watch HD BluRay Discs. There is no HDMI socket at the rear of the telly. Disc plays but HD picture quality looks the same as ordinary DVD....
Your TV has a DVI input connector, but no HDMI as you noted. Adapters (fondly called "dongles") are available to convert from the DVI connector to an HDMI jack so you can connect your HDMI source. Search for "dvi to hdmi adapter" with your favorite search engine and you will find them.
As for settings, this set has 720p resolution. Make sure your source is set accordingly, and you should be set to get the best quality you can with the connections available.
Please take a moment to give this solution a fixya rating if you've found it what you needed, and thanks for asking here!
Mar 05, 2009 | ViewSonic N3000W 30 in. HD-Ready LCD...
Viewsonic N3000w LCD TV randomly shuts off...
It seems that the power fails quite often with this one burning the Inverter boards transformers. OZ960G chip may not be broken, so try getting a new power from somewhere. Measure the transformers. suppose to be somewhat 5 ohms. tolerance is +-1.5 ohm. of more, replace.
Nov 21, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Viewsonic w3250n no sound, no picture, beeping
Hi, Any other indicators aside from the beeping sound like blinking leds/lights? For the time being try to do a hard reset, unplug the LCD TV from the mains for a couple of hours and thereafter try again with a known good outlet.. If still a no go, post back, Good luck and kind regards.
Aug 26, 2007 | ViewSonic NextVision N3200w 32 in....
Thick multicoloured stripes accross the screen
Some condesator gone bad.. remote control IR eye needs 5V voltage but now it's not there so i think you need to replace bad condesator.
May 30, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
ViewSonic N3000W 30 in. HD-Ready LCD Television Logo
299 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
