Question about Kodak M522 Digital Camera
Camera is not working with battery
Camera only works when its plug into the power
  • 734 Answers
Clean the battery contacts. All batteries give out fumes and coat the contacts. Never leave batteries in the camera when you stop using it.
Posted on Feb 15, 2012
Why will the camera power on when plugged in, but will not power on when useing batteries?, the batteries are new
Batteries are new but are you sure that they are good? Did you test them for voltage and amperage? Weak batteries will often not work in older digital cameras because they needs lots of power from good, strong battery.
Aug 31, 2015 | Polaroid PhotoMax PDC 640 Digital Camera
Camera will power-up only when connected to DC
Have you checked the batteries to make sure they are still viable?
Oct 11, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
My video camera (SDR-H18) wont charge...the battery lights up when charging but when i put it in the camera the camera wont turn on...whats the problem?
It sounds like a bad battery. If you have another battery, or a direct power plug for the camera, try those to determine if the camera itself functions. If so, you can safely assume the battery is the problem. If the power plug works but not a different battery, you may have dirty or corroded contacts where the battery attaches to the camera. If changing the battery works, the old one should be returned if under warranty, recycled if not, or you could leave it on the charger for several hours to see if it can complete a charge at all. If not, get a new battery.
May 05, 2011 | Panasonic SDR-H18 USB Hard Drive
NIKON D70 Camera not working after battery change
You may just have two bad batteries, or maybe your charger is bad.
You should have a DC power adapter with the camera, plug that in and see if the camera works longer with it.
You should also have an adapter to use CR02 batteries with the camera. You can buy three of the CR02 batteries at the drugstore (they are NOT rechargeable) and see if the camera works.
If any of these things work, you have bad batterie.
If they don't work, then there is likely some kind of short in the camera and you will need to send it to a service `center or your local camera shop. You might also just take it there and see if they have a known good D70 battery they could try for you.
Jul 14, 2009 | Nikon D70s Digital Camera
My Digilife DDV-A700HD will not power up. I have
I had the same problem with my camera so I had to replace the battery. I could not find the replacement battery that was in the camera. So I did a search and found out that the fuji np- 60 3.7v 1050w worked in the camera. I order the battery and now my camera works just find. I hope this help.
Jun 05, 2009 | Cameras
Will not power on with battery
the battery is dead or that power circut has a problem, but make sure you have a goo battery
Oct 16, 2008 | Sony Handycam DCR-SR40 Camcorder
PROBLEM WITH PENTAX OPTIO E10
It could be that the battery can't hold a charge anymore.
You will probably have to get a new battery.
Make sure the camera is working fine and that youre able to take pictures with the power cord plug in. If that works it isn't the camera, it's the battery.
Jun 20, 2008 | Pentax Optio E10 Digital Camera
No Power
most likely you have blown the battery probally putting too many volts into the camera and you might need to get a new battery. i had the same proble with my portabe dvd player and a new battery worked.
Mar 03, 2008 | JVC Cybercam GR-DX95 Mini DV Digital...
Power cord and battery's support NO power to Video Camera
This incident happens often and damages the camcorder's power board. Replacing power board and some adjustment should resolved the problem. Your cost may run from $175-$225 in US for this model. Whenever you are transfering and connecting to pc, it is recommended to connect AC adapter power for this. Do not rely on a charged battery. Good luck.
Mar 17, 2007 | Canon Optura 50 Mini DV Digital Camcorder
Overseas Use
Yes. The power supplies and battery chargers supplied with all Powershot Digital Cameras are designed to work on input voltages from 100-240 volts (50/60 Hz). The only item that you may need is a plug adapter that allows you to plug the U.S. type power supply or battery charger into the foreign type wall outlet. Plug adapters should be easily available at a local electronics store.
Aug 31, 2005 | Canon PowerShot S10 Digital Camera
Kodak M522 Digital Camera Logo
66 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
