My Philips Pronto TSU7500 LCD Remote is Dead. New Battery, but no sound and no screen. Blue Lights show it is charging when in dock, but no communication with PC.
  • 3 Answers
SOURCE: Creative Zen Vision M - Dead Machine
unfortunately,the best solution is to send it back to creative for them to check it out. this sometimes happens when the player has been unused for too long and battery "under charges", which there is a solution.but seeing as u used it under normal conditions,that cant be the problem
Posted on Jun 13, 2008
  • 164 Answers
SOURCE: 32 in. LCD Flat Screen Blank Screen
Is it under warrentee?
It sounds like the main fuse inside blew. Does the outlet work at all?
If not, reset the circuit breaker or if it is on a power strip, reset the strip trip switch.
Posted on Feb 18, 2009
Fix it Matt
  • 14 Answers
SOURCE: Neet battery cover for Philips TSU600 Pronto remote control
Battery Covers sell worldwide at Rogers for around $3-$10. Also, cheaper 50c ones are sold on EBay, Kijiji, and Craigslist.
Posted on May 03, 2009
SOURCE: Harmony 880 universal remote re-charging problem
I took the rubber feet off(4) from the underside of the cradle - removed the four screws and separated the top half of the cradle from the bottom. This exposes the two long thin charging arms and points All one piece). I then took some doubled sided tape, similar to what you use to put up temporary 3m picture hooks and cut four small pieces about 1/8th in square. Join two of the pieces back to back to make one piece (double original thickness), then raise one of the long charging arms gently and place the piece of double sided tape under the head of the arm (ie under the very end where the rounded point is, that sticks though the cradle when reassembled (there are two of these). Do this to the other arm.
Why - by inserting the doublesided tape you permanently raise the arms without bending them - ie they will now stay in that position and not bend out of shape, losing contact again . With the cradle reassembled, put the remote back in the cradle you will have more direct contact with the two charging pins. FIXED!!!!!!!! Good luck1
Posted on Jun 20, 2009
SOURCE: 4210 and 4230 won't charge-new batteries.
I've been having the same problem myself. The charger is apparently built into the roomba main board. From what I've read there are two MOSFETs U2 & U4 that can go out and require replacement to fix the problem. More info here
Posted on Jul 08, 2009
DSU9300 docking station not charging?
If you can measure the voltage from the charging unit to see if voltage is there, other possible reason and more common batteries are bad.
Dec 05, 2012 | Philips pronto universal home remote...
Harmony 890 just went dead. Nothing. Nada. Not
I have an 890 also. I've found that the remote doesn't always charge when it the charger. I have to put a rubber band around it and make sure it shows that the the battery symbol on the display is showing that it charging. Or the battery isn't taking a charge anymore and I'd try to replace it. Doesn't really hold a charge very long either.
Oct 27, 2009 | Logitech Harmony 890 LCD Remote Control
May 03, 2009 | Philips TSU6000 LCD Touchscreen Remote...
Frozen Pronto
Thankyou for the offer, but I finally fixed it.
I searched high and low on the Internet and finally found a document that led me to believe it was WIFI problem. I reset (switched off and on) the WIFI receiver, and removed/replaced the battery in the remote control and hey presto. it worked and is still working.
Sep 11, 2008 | Philips Pronto TSU9400 LCD Touchscreen...
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
