Question about HP LaserJet 4200 Printer
Why does my computer stall before printing
On one particular program, when I hit print the program locks up& it takes between 5-12 seconds to print.
Hi Lea, It sounds like you might need to download an updated driver for your printer. That should fix it, if that is the problem.
Posted on Feb 14, 2012
How would one use the "print screen" option with an Acer Aspire 6920? This is a very helpful feature on a computer. Thanks
Hi zacwynn
You can press on Print Screen (or PrtSc ) key on your keyboard .Then you open MS Paint and press ctrl + V and you will be able to take snapshots of your screen
The Print Screen key is located on above the +/= and Backspace keys .
Aug 26, 2011 | Acer Aspire 6920 Notebook PC
How do you clear the print jobs so that you are not printing the same things over and over
How to Clear Out a Stalled Print Job In order to stop a stalled print job, perform the following steps in order:
  1. Stop the Print Spooling service.
    • Click Start.
    • Click Run.
    • Type cmd.
    • Hit Enter.
    • At the command prompt, type net stop spooler and hit the Enter key.
  2. Delete the stalled print job.
    • Open My Computer.
    • Go to C:\Windows\system32\spool
      • Delete any files you find in this folder (but do not delete any folders!).
    • Go to C:\Windows\system32\spool\printers
  3. Restart the Print Spooling service.
    • Return to the command prompt used in step 1.
    • Type net start spooler and hit the Enter key.
Once you have restarted the Print Spooler, the jammed print job will be cleared from memory. Now you can go back and re-print all the jobs that were held up.
Feb 15, 2011 | HP Office Equipment & Supplies
I've connected the Zonet PS to my Linksys router and the light on the router is green. The PS wizard does not see it from either my wired PC or wireless laptop. Is there a setting on the Linksys router I...
ZPS2102, ZPW1000, ZPS1000 :: Trouble shooting tips for finding the print server using the utility
supporting troubleshooting links
? A: Please check the connection link light.
Temporarily disable all firewalls on your system even the Windows XP firewall
(for instruction to disable XP firewall, please go to http://support.microsoft.com/kb/283673 )
Power cycle the print sever by unplug the power at the back (10 second).
The print server default IP is 192.168.5.1
Set the computer which has the print server utility installed to have an IP of 192.168.5.2
(Test ping the print server / 192.168.5.1 --
If print server is respond to ping, using web browser with the address of 192.168.5.1 will also beable to configure the print server)
Run the utility/hit the refresh button to find the print server again.
The CD has two installation methods:
1. The Auto run will run the utility.
2. By manually install the program into your system. (Browse CD to the folder: manual installation.)
It is recommended to use the 2nd method and run the PSAdmin utility from the system's programs after the installation is completed.
If it still could not find the print server, direct connect your computer to the print server using cross over cable and run the utility again to find the print server.
When it finds the print server, change the print server IP(192.168.5.1) to a unique static IP your router can accept. Put the print server back to the network, change back your computer's IP accordingly and try ping the print server with the new IP or run the utility again.
For wireless print server, it is recommended to use Ad-hoc connection from a wireless computer to connect to the print server first. (follow the Quick Installation Guide booklet that came with the box on page 8)
Jan 30, 2011 | Zonet ZPS2102 Print Server
How to clear the memory on a Samsung ML-2855ND?
    • Click Start.
    • Click Run.
    • Type cmd.
    • Hit Enter.
    • Open My Computer.
Sep 16, 2010 | Samsung ML-2855ND Laser Printer
Yesterday I printed a page and could not print second page, so i shut everything down, this morning i turned on my computer and the printer started up & started printing & ran till out of paper....
Disconnect the printer power plug from the wall for 2 mins and plug it back in and turn the printer on and turn on your PC and see if that helps. The printer has a memory which stores information you may have sent to the printer. If you kept hitting the print button then it may have saved all those print commands in memory and it is printing that out. That is what happens most of the time at my office. So you need to erase the memory by turning off the printer from the wall. Hope this helps
Aug 14, 2010 | HP Office Equipment & Supplies
When selecting a printing task,If I ask for one copy,the machine continues to print even after hitting the cancel printing. Second*lets say there are two pages to be printed the first oage will print,the...
Hello. Try to unplug the printer from the power outlet for about 10-15 seconds to refresh itself. If that doesn't resolve the problem, it might be software communication issue. You can uninstall then reinstall the software. If you're computer is running on Windows, uninstall by going to Start Menu > Programs/All Programs > Lexmark Series folder > Tools/Uninstall. Reboot pc. Reinstall software. If your using Macintosh, go in the Lexmark folder and Uninstall. Reinstall software. Hope this helps.
Mar 17, 2010 | Lexmark C533DN InkJet Printer
Print screen key doesnt work
try the print screen key on their computer keyboard. This will usually take the screen shot and place it into the computer clipboard. Once in the clipboard, a user can almost always paste that screen shot into a graphic program.
Then go to start, run, type in clipbrd and then hit enter.
May 05, 2009 | A4tech A4 Tech KBS-8 Multimedia Anti-RSI...
PRINTING PROBLEMS
Maybe I can help;
I'll assume you have a windows operating system.
There are two ways to print, one is hitting the print icon wherever that may be in the current program and the second is to use the longer method of going to: file/print.. which takes to you to the print setup box.
This may be where you need to set the print properties for this particular document.
The first method uses whatever your default printing setup is.. such as which printer, portrait mode,
draft or best quality....etc.
If you always use the same print setup you can set this in; start/settings/control panel/printers/
Your default printer will have a check next to it.
Hope this helps
Dec 30, 2008 | HP Computers & Internet
Recieving fax no printout, all other printing processes ok
When you say all other printing processes are ok, I am assuming you can make copies and print from the computer. If so...then are the blank faxes coming from several different fax machines or are they coming from one particular fax machine. If one particular fax machine, then the problem is probably on their end. I need to go backwards a second....when you receive a fax does the machine spit out a blank page or no paper is fed at all..it just receives the fax? Is the machine programmed to just receive faxes to memory to be printed out later? It doesn't make sense for it to print or copy but not to print a fax. If problem persist try a different fax modem.
May 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP LaserJet 4200 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
